Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
07-10-2016, 13:57 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | Display Problem Sony Z5 E6603 after change LCD have only backlight powered on, but no picture ? many LCD same problem, and I think also the original one have same probleme now. Best Regards, JAVA Good. |
11-26-2016, 13:57 | #5 (permalink) |
Junior Member Join Date: Jul 2012 Location: lyon (france) Age: 43
Member: 1786863 Status: Offline Thanks Meter: 6 | Hello friends i found the solution for this problem on the forum customer try change the screen and after taht it was showing only colored lines on the screen when power on i use picture of another friend in forum who this one say what he does to solve not just telling " i solve the solution " and desapear when you ask help those are not friendly and shouldn't even post anything ok ok he will reconize him by himself grrrrrr so stupid ! help help help SO you just need to check tow componenent and if not beep in diode mode with your multimeter ( tester ) then trace a wire instead but asume that wire will not brake if again problem and it will burn something else so need to power off phone before plug screen or otherwise if you have replace the componenet always better ! see attached pic ! |
The Following 4 Users Say Thank You to mattiuk For This Useful Post: |
12-06-2016, 09:18 | #6 (permalink) | |
Junior Member Join Date: Jan 2007
Member: 434120 Status: Offline Thanks Meter: 0 | Quote:
Thanks for the picture. That is what I was looking for. Is that a fuse? Could, please, explain me what to measure? The path between those two componens or the components itself? Thanks in advance. | |
