Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
12-31-2015, 06:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: EGYPT Age: 44
Member: 31027 Status: Offline Thanks Meter: 179 | EASY Bypass( MXTP ) my Xperia Theft Protection $ NOW YOU CAN Bypass( MXTP ) my Xperia Theft Protection BUT you can only bypass to use phone and send sms without play store ..... https://www.youtube.com/watch?v=MoiQ...ture=********* HAPPY NEW YEAR Last edited by aZimBahar; 12-31-2015 at 07:58. Reason: Youtube Enabled |
The Following 12 Users Say Thank You to elsokary For This Useful Post: |
12-31-2015, 07:12 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | and after restart the phone once again ? then ? |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
01-03-2016, 16:03 | #5 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Brasil
Member: 694980 Status: Offline Thanks Meter: 91 | so convidade does not eliminate the account, just open an option and the device can still be tracked and you can still be delete. there is a 100 % guest mode shape should be repeated when you restart . NOTE the aparlho can still be tracked and can be delete. a 100 % non MXTP (no guest mode , No risk screening , No risk of being erased ) |
01-03-2016, 16:08 | #6 (permalink) |
Member: 694980 Status: Offline Thanks Meter: 91 | Remove protected screen sony MXTP new lock Sony The time ranges from 25 to 15 seconds, depending on the model. The xperia M4 is what it is as long (easier) then you must be fast in every procedure and when the time runs out the lock screen and then shown it takes restart to continue or repeat step not finished. 1. Format the first device 2- set the language for the access to add guest mode on the screen it is normal the screen is black and not display the language options then restart up to show the initial settings options. complete the settings (language settings etc ..) should complete until the end that opens the menu the end time will show the protective screen to restart unit to continue, or go to the next step. 3- In the protected screen enable one wifi network, after already one authenticates Wi-Fi network does not restart the machine and knife Step 3 4- Enable guest mode. click on 2x power at the blue screen puche you notify and click on the doll (top right) the end time will show the protective screen device restart and continue! 5- Add new account to PlayStory the end time will show the protective screen device restart and continue! 6- Make a shortcut menu settings to the first screen, so already point the end time will show the protective screen device restart and continue! 7- Attention latter step can only be done once. If the time runs out to repeat. reset the machine go into menu and reset the device starts again from step 1 Please settings and click on safety and open the proteção_my_experia, click Enable, and then click Disable protection. 8 in this step the device already has no lock but the bill is still in the device. 9- knife login with the new account, enable and disable, then knife a total device reset the menu settings, backup and reset (sorry the English) https://www.youtube.com/watch?v=e_o86PR3oFE |
The Following 5 Users Say Thank You to wcelgsm For This Useful Post: |
01-04-2016, 23:44 | #9 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 379165 Status: Offline Thanks Meter: 50 | I have only 15sec. It is not possible to login to play store. What can I do to block the protection screen. Help please |
The Following 3 Users Say Thank You to halaxi For This Useful Post: |
02-16-2016, 19:15 | #10 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: Manila
Member: 1176823 Status: Offline Thanks Meter: 38 | Quote:
The Following User Says Thank You to ecp27 For This Useful Post: |
03-10-2016, 12:47 | #11 (permalink) | |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | Quote:
Share solution; otherwise no need for such worthless videos! | |
The Following User Says Thank You to SandyBridge For This Useful Post: |
04-02-2016, 22:02 | #12 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2554666 Status: Offline Thanks Meter: 14 | Hi all! I´ve registered just to share this. wcelgsm's method is absolutelly right and it worked for me, he had some problems explaining it though. The thing is basically that you have to create a Play Store account, activate my xperia theft protection, this time with your new created account, counting with 15-20 seconds time gaps. For that you have to turn off and on again your device several times and in some steps you have to be really quick. Once the device is on your hands, you can deactivate mxtp again. Steps: - Turn on and click following in all the first setting steps quickly. The block screen jumps and then you connect to wifi on it. Turn off. - Turn on and go quickly to settings > users, change to guest, so that you have full time to create a new Play Store account with your email and password. Change back to owner and turn off. - Turn on and create a settings shortcut on the desktop so that you access faster in the next setps, you´ll really need it. Turn off. - Turn on and go to settings > security and activate my xperia protection. Shurely you´ll need several attemps until you get it and you may expend one attemp just studying the steps. What you´re gonna find when you click activate is an acceptance button, a screen to insert your email, a screen to insert your pass and a final acceptance screen (if I remember right). There are a couple of moments when the system is thinking stealing your yet tiny time. I´d recomend you use a short email and pass account, even if you have to create one to later change it. At the end, the system keeps thinking while the block screen comes back. You turn off and on and try to make the same but when you try to activate my xperia, the device seems to be thinking (doing nothing or stuck) and that you´re gonna lose an attempt, but it actually means that it´s creating your account in myxperia dot sonymobile dot com. The blocking screen may jump again and this may take a couple of turn off and ons, but then when you turn on the device and it is unblocked. - You receive an email from myxperia dot sonymobile dot com, at this point the device is on your hands, with the mxtp on, but controled by you. You can now deactivate it or on. - Now you can reset to factory settings and configure it as you wish, so that you are sure the old account is no longer in the system (as you wish). Hope it works for all of you and enjoy it, and hope I have explained it a bit clearer, at least enough to achieve it. Thank you so much wcelgsm! I was hard to understand but something was telling me your method was right and was the answer, after trying almost everything else! |
The Following 14 Users Say Thank You to redada For This Useful Post: |
04-08-2016, 12:34 | #13 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2414390 Status: Offline Thanks Meter: 3 | Thanks! I would be thanks both to wcelgsm and redada for the procedure and the "clearification". You both saved me from a big trouble! K. |
The Following 3 Users Say Thank You to Krakatoa For This Useful Post: |
04-13-2016, 13:42 | #14 (permalink) | |
Member: 379165 Status: Offline Thanks Meter: 50 | Quote:
you try it with a xperia Z4 or Z5 ? | |
The Following User Says Thank You to halaxi For This Useful Post: |
05-13-2016, 16:39 | #15 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: Azerbaijan Age: 53
Member: 897164 Status: Offline Thanks Meter: 101 | Quote:
Confirm , works on Xperia Z3+ like a charm . Thanks bro ! | |
The Following 2 Users Say Thank You to DemnZ For This Useful Post: |
