Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 12-31-2015, 06:51   #1 (permalink)
Member: 31027
Thanks Meter: 179
EASY Bypass( MXTP ) my Xperia Theft Protection $
HI ALL
NOW YOU CAN Bypass( MXTP ) my Xperia Theft Protection
BUT you can only bypass to use phone and send sms without play store .....
https://www.youtube.com/watch?v=MoiQ...ture=*********
http://www.youtube.com/watch?v=MoiQhA51SCE&feature
HAPPY NEW YEAR
The Following 12 Users Say Thank You to elsokary For This Useful Post:
Old 12-31-2015, 07:12   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
and after restart the phone once again ? then ?
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 12-31-2015, 07:18   #3 (permalink)
Member: 31027
Thanks Meter: 179
The Following 2 Users Say Thank You to elsokary For This Useful Post:
Old 01-03-2016, 12:44   #4 (permalink)
.::AssAnovic.::'s Avatar
Member: 162611
Thanks Meter: 315
Thank you it's Work 100%100 for me in Xperia M4 ........
The Following 2 Users Say Thank You to .::AssAnovic.:: For This Useful Post:
Old 01-03-2016, 16:03   #5 (permalink)
Member: 694980
Thanks Meter: 91
so convidade does not eliminate the account, just open an option and the device can still be tracked and you can still be delete.
there is a 100 % guest mode shape should be repeated when you restart . NOTE the aparlho can still be tracked and can be delete.
a 100 % non MXTP (no guest mode , No risk screening , No risk of being erased )
The Following 2 Users Say Thank You to wcelgsm For This Useful Post:
Old 01-03-2016, 16:08   #6 (permalink)
Member: 694980
Thanks Meter: 91
Remove protected screen sony
MXTP new lock Sony
The time ranges from 25 to 15 seconds, depending on the model. The xperia M4 is what it is as long (easier)
then you must be fast in every procedure and when the time runs out the lock screen and then shown it takes
restart to continue or repeat step not finished.
1. Format the first device
2- set the language for the access to add guest mode on the screen
it is normal the screen is black and not display the language options then restart up to show the initial settings options.
complete the settings (language settings etc ..) should complete until the end that opens the menu
the end time will show the protective screen to restart unit to continue, or go to the next step.
3- In the protected screen enable one wifi network, after already one authenticates Wi-Fi network does not restart the machine and knife Step 3
4- Enable guest mode. click on 2x power at the blue screen puche you notify and click on the doll (top right)
the end time will show the protective screen device restart and continue!
5- Add new account to PlayStory
6- Make a shortcut menu settings to the first screen, so already point
7- Attention latter step can only be done once. If the time runs out to repeat.
reset the machine go into menu and reset the device starts again from step 1
Please settings and click on safety and open the proteção_my_experia, click Enable, and then click Disable protection.
8 in this step the device already has no lock but the bill is still in the device.
9- knife login with the new account, enable and disable, then knife a total device reset the menu
settings, backup and reset
(sorry the English)
https://www.youtube.com/watch?v=e_o86PR3oFE
The Following 5 Users Say Thank You to wcelgsm For This Useful Post:
Old 01-04-2016, 21:44   #7 (permalink)
Member: 379165
Thanks Meter: 50
Can you please make a full procedure video?
The Following User Says Thank You to halaxi For This Useful Post:
Old 01-04-2016, 23:18   #8 (permalink)
Member: 379165
Thanks Meter: 50
Can't login to play store because screen protect after 15sec.other possibility?
Old 01-04-2016, 23:44   #9 (permalink)
Member: 379165
Thanks Meter: 50
I have only 15sec. It is not possible to login to play store. What can I do to block the protection screen. Help please
The Following 3 Users Say Thank You to halaxi For This Useful Post:
Old 02-16-2016, 19:15   #10 (permalink)
Member: 1176823
Thanks Meter: 38
MXTP new lock Sony
(sorry the English)
bro can you explain it clearly....the video shows nothing....tnx
The Following User Says Thank You to ecp27 For This Useful Post:
Old 03-10-2016, 12:47   #11 (permalink)
SandyBridge's Avatar
Member: 2399672
Thanks Meter: 187
MXTP new lock Sony
(sorry the English)
Cut the crap.
Share solution; otherwise no need for such worthless videos!
The Following User Says Thank You to SandyBridge For This Useful Post:
Old 04-02-2016, 22:02   #12 (permalink)
Member: 2554666
Thanks Meter: 14
Hi all!
I´ve registered just to share this.
wcelgsm's method is absolutelly right and it worked for me, he had some problems explaining it though.
The thing is basically that you have to create a Play Store account, activate my xperia theft protection, this time with your new created account, counting with 15-20 seconds time gaps.
For that you have to turn off and on again your device several times and in some steps you have to be really quick. Once the device is on your hands, you can deactivate mxtp again.
Steps:
- Turn on and click following in all the first setting steps quickly. The block screen jumps and then you connect to wifi on it. Turn off.
- Turn on and go quickly to settings > users, change to guest, so that you have full time to create a new Play Store account with your email and password. Change back to owner and turn off.
- Turn on and create a settings shortcut on the desktop so that you access faster in the next setps, you´ll really need it. Turn off.
- Turn on and go to settings > security and activate my xperia protection.
Shurely you´ll need several attemps until you get it and you may expend one attemp just studying the steps.
What you´re gonna find when you click activate is an acceptance button, a screen to insert your email, a screen to insert your pass and a final acceptance screen (if I remember right).
There are a couple of moments when the system is thinking stealing your yet tiny time. I´d recomend you use a short email and pass account, even if you have to create one to later change it. At the end, the system keeps thinking while the block screen comes back. You turn off and on and try to make the same but when you try to activate my xperia, the device seems to be thinking (doing nothing or stuck) and that you´re gonna lose an attempt, but it actually means that it´s creating your account in myxperia dot sonymobile dot com.
The blocking screen may jump again and this may take a couple of turn off and ons, but then when you turn on the device and it is unblocked.
- You receive an email from myxperia dot sonymobile dot com, at this point the device is on your hands, with the mxtp on, but controled by you. You can now deactivate it or on.
- Now you can reset to factory settings and configure it as you wish, so that you are sure the old account is no longer in the system (as you wish).
Hope it works for all of you and enjoy it, and hope I have explained it a bit clearer, at least enough to achieve it.
Thank you so much wcelgsm!
I was hard to understand but something was telling me your method was right and was the answer, after trying almost everything else!
The Following 14 Users Say Thank You to redada For This Useful Post:
Old 04-08-2016, 12:34   #13 (permalink)
Member: 2414390
Thanks Meter: 3
Thanks!
I would be thanks both to wcelgsm and redada for the procedure and the "clearification".
You both saved me from a big trouble!
K.
The Following 3 Users Say Thank You to Krakatoa For This Useful Post:
Old 04-13-2016, 13:42   #14 (permalink)
Member: 379165
Thanks Meter: 50
Originally Posted by redada View Post
Hi all!
Steps:
you try it with a xperia Z4 or Z5 ?
Old 05-13-2016, 16:39   #15 (permalink)
Member: 897164
Thanks Meter: 101
MXTP new lock Sony
(sorry the English)
Confirm , works on Xperia Z3+ like a charm . Thanks bro !
The Following 2 Users Say Thank You to DemnZ For This Useful Post:
Page generated in 0.38094 seconds with 9 queries
