Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 05-13-2016, 22:33   #16 (permalink)
Member: 1502852
Insanely Impossible
Originally Posted by redada View Post
Hi all!
I´ve registered just to share this.
wcelgsm's method is absolutelly right and it worked for me, he had some problems explaining it though.
The thing is basically that you have to create a Play Store account, activate my xperia theft protection, this time with your new created account, counting with 15-20 seconds time gaps.
For that you have to turn off and on again your device several times and in some steps you have to be really quick. Once the device is on your hands, you can deactivate mxtp again.
Steps:
- Turn on and click following in all the first setting steps quickly. The block screen jumps and then you connect to wifi on it. Turn off.
- Turn on and go quickly to settings > users, change to guest, so that you have full time to create a new Play Store account with your email and password. Change back to owner and turn off.
- Turn on and create a settings shortcut on the desktop so that you access faster in the next setps, you´ll really need it. Turn off.
- Turn on and go to settings > security and activate my xperia protection.
Shurely you´ll need several attemps until you get it and you may expend one attemp just studying the steps.
What you´re gonna find when you click activate is an acceptance button, a screen to insert your email, a screen to insert your pass and a final acceptance screen (if I remember right).
There are a couple of moments when the system is thinking stealing your yet tiny time. I´d recomend you use a short email and pass account, even if you have to create one to later change it. At the end, the system keeps thinking while the block screen comes back. You turn off and on and try to make the same but when you try to activate my xperia, the device seems to be thinking (doing nothing or stuck) and that you´re gonna lose an attempt, but it actually means that it´s creating your account in myxperia dot sonymobile dot com.
The blocking screen may jump again and this may take a couple of turn off and ons, but then when you turn on the device and it is unblocked.
- You receive an email from myxperia dot sonymobile dot com, at this point the device is on your hands, with the mxtp on, but controled by you. You can now deactivate it or on.
- Now you can reset to factory settings and configure it as you wish, so that you are sure the old account is no longer in the system (as you wish).
Hope it works for all of you and enjoy it, and hope I have explained it a bit clearer, at least enough to achieve it.
Thank you so much wcelgsm!
I was hard to understand but something was telling me your method was right and was the answer, after trying almost everything else!
Ive manage to make most of the step up to when sony send the email of activation. Problem is each time i try to deactivate the my xperia theft protection the screen block kicks in exactly the second i am about to confirm the deactivation. No matter how fast or how many shortcut I do I end up the same. The screen takes sooooo much to load and once it does i have 1 to two seconds before the screens blocks. Any ideas?
The Following User Says Thank You to lilizblack For This Useful Post:
Old 05-20-2016, 22:42   #17 (permalink)
Member: 2575526
Thanks Meter: 2
Hi
I want to unlock sony mobiles password like pattern pin
Without box
Help me
Tnks
The Following 2 Users Say Thank You to Ahmad_aria For This Useful Post:
Old 05-29-2016, 21:41   #18 (permalink)
yarra's Avatar
Member: 493205
Sonork: 100.1581647
Thanks Meter: 524
i have way to remove mxp without box . tested by me i will explain it
- first make software for phone
- turn on the phone and when it be on the activation secreen for first time it take long time
to mxp screen to appear . so very quickly active the phone then go to usb debbuging make it on . i tried many times and then i did .
- now restart the phone and connect it to pc and root it with iroot or king root ....itc .
- the phone will restar after root done .
- connect again to pc and open vroot tool in your pc .
- go to system filles in your phones via vroot tool and dellet my xperia app.
- restart the phone
- the phone will work without mxp and fully work .. anjoy
this way tested by me on 2 phones m4 aqua and c4 .
The Following 3 Users Say Thank You to yarra For This Useful Post:
Old 06-04-2016, 16:09   #19 (permalink)
Member: 2289682
Thanks Meter: 21
- restart the phone
Sir. no need to unlock the bootloader?
Sent from my Nexus 4 using Tapatalk
The Following User Says Thank You to audicargo For This Useful Post:
Old 06-04-2016, 16:58   #20 (permalink)
Member: 945056
Sonork: 100.1617497
Thanks Meter: 4
kingo root and vroot cant root this phone e2305 sony
can you help
The Following User Says Thank You to shephie For This Useful Post:
Old 07-08-2016, 16:18   #21 (permalink)
Member: 2532234
you cant root it cuz u have 15 sec until the protected screen pops up
The Following User Says Thank You to Brandon Smith For This Useful Post:
Old 07-20-2016, 02:23   #22 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 330
Is there any tool available to bypass MXTP?
The Following User Says Thank You to technomak For This Useful Post:
Old 07-28-2016, 23:36   #23 (permalink)
Member: 2124329
Thanks Meter: 38
First sorry for my bad English but that is not my contry language
Today i Bypassed Myxperia protection on Sony xperia m4 Aqua successful i will give instruction...THIS WORK ONLY ON ANDROID 5.0 and 5.1!!!
You have 15 seconds before the lock comes on your screen
1.You have to go in settings and make reset ,when you click the reset button wait few second and it will reset even if show the lock just press the reset button few times
2.When it reset you will have to activate it (insert language,connect to wifi)
for 15 second(you can restart the device if you coudnt make it in first time
3.When you activate it when you boot the device and unlock the screen there will be ,a google play icon you will have to click it and insert fast your gmail and password...when you insert the gmail successful you will have to go to settings>security and activate Myxperia protection when you do thath reboot your device and go fast in setting about and look for update for android 6.0
4.Connect the device on Sony PC Companion and when it show your phone click Software update(NOT REPAIR!!!)when you click it it will start download the new firmware
5.After the update is successful your phone will be bypassed and it going to use your gmail go in setting and activate then deactivate the myxperia protection
6.Now you are free to make restore again and the phone will be usble and like new )
At every step you will need to reboot your device because it will lock at every 15 second and you will have to be very fast at inserting the gmail and password!
Sorry again for bad English if that help you press the Thanks button and if you want you can make ,a donate at my paypall
The Following User Says Thank You to spowse For This Useful Post:
Old 08-08-2016, 18:46   #24 (permalink)
Member: 2604200
Thanks Meter: 3
no working network .......
The Following User Says Thank You to kang85 For This Useful Post:
Old 08-21-2016, 04:22   #25 (permalink)
Member: 2614341
Sonork: 1674918
Thanks Meter: 2
how to remove sony xperia e6553 protected
The Following User Says Thank You to BunnyR... For This Useful Post:
Old 11-09-2016, 16:09   #26 (permalink)
Member: 2503572
Hi all!
Steps:
THANKS so much , my phone after 3 month come me back with this way
The Following User Says Thank You to splander91 For This Useful Post:
Old 12-10-2016, 21:20   #27 (permalink)
Member: 194436
Thanks Meter: 12
thanks
iy work pafectly thank very much
Hi all!
Steps:
The Following User Says Thank You to mobile world For This Useful Post:
Old 12-10-2016, 21:21   #28 (permalink)
Member: 194436
Thanks Meter: 12
thank you
thank you very much it works
Originally Posted by wcelgsm View Post
Remove protected screen sony
MXTP new lock Sony
The time ranges from 25 to 15 seconds, depending on the model. The xperia M4 is what it is as long (easier)
then you must be fast in every procedure and when the time runs out the lock screen and then shown it takes
restart to continue or repeat step not finished.
1. Format the first device
2- set the language for the access to add guest mode on the screen
it is normal the screen is black and not display the language options then restart up to show the initial settings options.
complete the settings (language settings etc ..) should complete until the end that opens the menu
the end time will show the protective screen to restart unit to continue, or go to the next step.
3- In the protected screen enable one wifi network, after already one authenticates Wi-Fi network does not restart the machine and knife Step 3
4- Enable guest mode. click on 2x power at the blue screen puche you notify and click on the doll (top right)
the end time will show the protective screen device restart and continue!
5- Add new account to PlayStory
6- Make a shortcut menu settings to the first screen, so already point
7- Attention latter step can only be done once. If the time runs out to repeat.
reset the machine go into menu and reset the device starts again from step 1
Please settings and click on safety and open the proteção_my_experia, click Enable, and then click Disable protection.
8 in this step the device already has no lock but the bill is still in the device.
9- knife login with the new account, enable and disable, then knife a total device reset the menu
settings, backup and reset
(sorry the English)
https://www.youtube.com/watch?v=e_o86PR3oFE
Old 12-26-2016, 21:18   #29 (permalink)
Member: 2664965
Thanks Meter: 16
Thank you it's Work 100%100 for me in Xperia M4
The Following User Says Thank You to summergsm For This Useful Post:
Old 12-29-2016, 21:23   #30 (permalink)
chopwell20's Avatar
Member: 1852580
Thanks Meter: 74
Originally Posted by DemnZ View Post
Confirm , works on Xperia Z3+ like a charm . Thanks bro !
Confirmed working on Z3+ ( Xperia Z3+ E6553 ) software version 6.0.1 ( 32.2.A.5.11 )
Android Version Nougat 7.0
only additional steps were as dated 29-12-2016 i flashed new fresh firmware with pc companion then followed the above step once i was in just reset to factory from settings not from recovery then .... it was again on authenthicate but this time it was locked with my own gmail id so after wifi connection entered my gmail and bo0o0om working
The Following 4 Users Say Thank You to chopwell20 For This Useful Post:
Page generated in 0.46792 seconds with 7 queries
