Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 07-12-2013, 09:42   #1 (permalink)
reactos's Avatar
Member: 323137
Thanks Meter: 235
Emma Xperia Flash tool
You need to have unlocked bootloader it can be done here: Unlocking the boot loader | Sony Xperia
To install the flash tool, follow the steps below:
Download the Flash tool for Xperia devices. http://dl-developer.sonymobile.com/t...r_Xperia_3.zip
Unzip the file you downloaded and place it somewhere on your computer.
In the unzipped folder, run Emma.exe. During the installation, make sure you remember the installation path:
Default path in Windows 64 bit is: “C:\Program Files (x86)\Sony Mobile\Emma\”
Default path in Windows 32 bit is: “C:\Program Files\Sony Mobile\Emma\”
Copy the Customization.ini file. You find it in the Flash_tool_for_Xperia_X.zip.
Paste the Customization.ini file into the installation folder. The installation folder is the folder named Emma in the installation path examples on point 3.1 and 3.2 above.
Click Start > All programs > Sony Mobile > Emma (if you used the default installation path from step 3 above) to start the flash tool
When you have installed the flash tool for Xperia™, you can flash standard Sony software on your unlocked Xperia™ device. Note! When you flash software onto your device, your user data and content will be erased. Make sure to properly back up all information.
This is how you flash software on your phone:
1. Computer: Open Emma from the Start menu of your computer.
2. Connect a USB cable to your computer.
3. Phone: Turn off your phone.
4. Connect your phone to the USB cable while holding the flash key (for example Volume down). The flash key varies between models. For a complete key mapping, see the list in the bottom of this thread.
Screenshot showing the flash tool when a phone is connected.
5. Computer: Select the software you want to flash in the Service list. The tool automatically detects the phone model and lists available software versions, which are called Services in this flash tool.
6. Click on Apply Service. The phone will now be flashed.
7. Phone: When you have flashed your device, you can disconnect your phone from the computer. The first time you start your device after you have flashed it, the boot-up might take a little longer than normal.
Xperia Tablet Z (SGP321 and SGP311) – volume down
Xperia go (ST27i) – back
Xperia neo V (MT11i) – volume down
Xperia ray (ST18i) – volume down
Xperia P (LT22i) – volume down
Xperia ZL (C6503) – volume down
Xperia Z (C6603) – volume down
Xperia PLAY (R800i) – back
Xperia E dual (C1605)– volume down
Xperia E (C1505) – volume down
Xperia T (LT30p) – volume down
Xperia S (LT26i) – volume down
Xperia arc (LT15i) – back
Xperia arc S (LT18i) – back
The Following User Says Thank You to reactos For This Useful Post:
Old 08-30-2013, 11:00   #2 (permalink)
Member: 641245
Thanks Meter: 2
username and pass please......
The Following User Says Thank You to pl4c3bo_09 For This Useful Post:
Old 08-30-2013, 15:05   #3 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 219
...only unlocket fones??
cheers
The Following User Says Thank You to carlos32 For This Useful Post:
Old 09-28-2013, 20:39   #4 (permalink)
Member: 1867589
Thanks Meter: 2
i have problem ...sony ZL C6502 ,,,network & WIFI no work,,,help me
The Following User Says Thank You to cyber phones For This Useful Post:
Old 09-28-2013, 20:56   #5 (permalink)
Member: 1805459
file 404 - Not Found
Old 09-30-2013, 05:25   #6 (permalink)
Member: 1740134
Thanks Meter: 52
New link for Emma flash tool.
http://dl-developer.sonymobile.com/t...r_Xperia_4.zip
The Following 2 Users Say Thank You to nokiaa2 For This Useful Post:
Old 01-23-2014, 23:14   #7 (permalink)
GSM MOBILES's Avatar
Member: 1624770
Sonork: 1640429
Thanks Meter: 69
whats user name and password
Old 02-03-2014, 14:09   #8 (permalink)
Member: 1434768
Sonork: HAPPY22
Thanks Meter: 3
plz give me user name & password
Old 04-23-2014, 06:36   #9 (permalink)
Member: 1921116
sir plz user and password only for i time
Old 04-23-2014, 07:17   #10 (permalink)
.....::::GsmAdeel:::::.....'s Avatar
Member: 767472
Sonork: 100.1609877
Thanks Meter: 582
Which Model Suported...........
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post:
Old 11-17-2014, 08:56   #11 (permalink)
trustunlockc's Avatar
Member: 1440837
Sonork: 3535
Thanks Meter: 34
Pls username and password
Old 11-17-2014, 10:59   #12 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
no need u/p
just do it
Old 12-03-2014, 11:44   #13 (permalink)
siddhu nokia's Avatar
Member: 1166487
Sonork: 100.1673527
Thanks Meter: 5
plz user name password
Old 02-13-2015, 10:14   #14 (permalink)
Member: 1262626
Thanks Meter: 8
Originally Posted by net.tarik View Post
no need u/p
just do it
thanks for advance....very usefull and no need username and pasword
Old 02-13-2015, 10:56   #15 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,347
Dear Friend,
Is It Work On Windows XP ?
Page generated in 0.38504 seconds with 7 queries
