Fix "factory startup service please wait for power off button" + red screen Sony XA U Fix "factory startup service please wait for power off button" + red screen Sony XA Ultra teamviewer |
its can be fix via writing script file......... |
Charge battery full n flash again |
my battery is 100% but still im getting red screen i tried 3 different firmware but still same |
try method 2 - solutions to this "problem" : charge battery to at least 65%, reflash phone fully ( app,fsp,eLabel,CDF ), put phone on flat surface,power on it and do not touch, until "power off" button appears OR after flashing, write next script, this will signal factory startup service that it is successfully completed all steps Code: tawrite:000208B350000000 OR disable factory startup service application in phone using standard android ways. |
You can solve via by writing script which post before , charged battery wont work for all models , before full flash just write the script and check |
help me please sam issue |
how to fix this error pls |
Flashed yesterday some older xperia, battery 17%, powered on normally, when showed factory service bla bla, waited until big POWER OFF text appeared, clicked on it, phone powered off. After power on, all works normal. b.r. Alex |
Write the script is needed to fix this issue (at least on latest models) or as alternative, root the phone and remove the service |
hello sir some latest xperia phones after flash you need Morethen 50% to run startup apps , best regrads |
even with low battery. (Z3, Z3c, E5, etc) Some of them worked with, some without script writing ... b.r. Alex |
I had to use a script: tawrite:000208B350000000 Anti theft service and factory startup service they disturbed each other. Now that I managed to turn off anti theft, i want to switch back factory startup service to finish your thing. Is there a sprict that cancels this: tawrite:000208B350000000 ? (I know SW doesn't change it back to its original state.) |
