Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 12-06-2017, 07:35   #1 (permalink)
Member: 2689353
Thanks Meter: 4
Fix "factory startup service please wait for power off button" + red screen Sony XA U
Fix "factory startup service please wait for power off button" + red screen Sony XA Ultra teamviewer
Old 12-06-2017, 08:03   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,126
its can be fix via writing script file.........
Old 12-07-2017, 13:14   #3 (permalink)
Member: 15156
Thanks Meter: 73
Charge battery full n flash again
The Following User Says Thank You to osmanabu For This Useful Post:
Old 12-08-2017, 20:21   #4 (permalink)
Member: 2344598
Sonork: holm615
Thanks Meter: 80
that is right pro no more
Old 12-09-2017, 15:58   #5 (permalink)
hans salim's Avatar
Member: 292087
Sonork: 1575183
Thanks Meter: 194
my battery is 100% but still im getting red screen i tried 3 different firmware but still same
Old 12-09-2017, 17:36   #6 (permalink)
naderhacker's Avatar
Member: 4365
Thanks Meter: 39
try method 2
- solutions to this "problem" :
charge battery to at least 65%, reflash phone fully ( app,fsp,eLabel,CDF ), put phone on flat surface,power on it and do not touch, until "power off" button appears
OR
after flashing, write next script, this will signal factory startup service that it is successfully completed all steps
tawrite:000208B350000000
OR
disable factory startup service application in phone using standard android ways.
The Following 7 Users Say Thank You to naderhacker For This Useful Post:
Old 12-10-2017, 10:38   #7 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,126
You can solve via by writing script which post before , charged battery wont work for all models , before full flash just write the script and check
Old 01-24-2018, 16:42   #8 (permalink)
Member: 1558861
Sonork: aftabmiraj15
Thanks Meter: 4
help me please sam issue
Old 01-25-2018, 14:31   #9 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
Originally Posted by naderhacker View Post
try method 2
OR
OR
Yes this is really solution, batter must be 65% otherwise phone will not powered on
Old 07-03-2018, 16:24   #10 (permalink)
Member: 2177146
Thanks Meter: 20
how to fix this error pls
Old 07-03-2018, 21:03   #11 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
... and you are writing pure nonsense.
Flashed yesterday some older xperia, battery 17%,
powered on normally, when showed factory service bla bla,
waited until big POWER OFF text appeared, clicked on it,
phone powered off.
After power on, all works normal.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 07-04-2018, 01:04   #12 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 363
Write the script is needed to fix this issue (at least on latest models) or as alternative, root the phone and remove the service
Old 07-05-2018, 07:17   #13 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,126
phone powered off.
b.r.
Alex
hello sir
some latest xperia phones after flash you need Morethen 50% to run startup apps ,
best regrads
Old 07-06-2018, 01:33   #14 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Originally Posted by Mr.3. View Post
hello sir
best regrads
well I dunno about those latest ones, all previous i flashed started normally,
even with low battery. (Z3, Z3c, E5, etc)
Some of them worked with, some without script writing ...
b.r.
Alex
__________________
Old 01-04-2022, 11:17   #15 (permalink)
Member: 87188
Thanks Meter: 226
I had to use a script: tawrite:000208B350000000
Anti theft service and factory startup service they disturbed each other.
Now that I managed to turn off anti theft, i want to switch back factory startup service to finish your thing.
Is there a sprict that cancels this: tawrite:000208B350000000 ?
(I know SW doesn't change it back to its original state.)
Page generated in 0.23681 seconds with 8 queries
