Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
06-06-2014, 09:28 | #31 (permalink) |
No Life Poster Join Date: Oct 2009 Location: nepal,kathmandu,New Road
Member: 1139381 Status: Offline Sonork: 1593399 Thanks Meter: 225 | That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro and Sony Xperia phone PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW Waiting for phone ... llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&9da6b9a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:30 secs. DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&15e74722&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:14 secs. TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro and Sony Xperia phone PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW Waiting for phone ... llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&9da6b9a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:9 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro and Sony Xperia phone PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW Waiting for phone ... llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&9da6b9a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:6 secs. TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro and Sony Xperia phone PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW Waiting for phone ... llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&9da6b9a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:3 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&15e74722&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:19 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&15e74722&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:20 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&9da6b9a&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:4 secs. |
07-29-2014, 12:47 | #34 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2230941 Status: Offline Thanks Meter: 0 | I tried its showing Processing.... SIERIAL NUMBER : 00A58E03 HARDWARE ID : 04000100E1207B00 PRODUCT DETECTED : "MSM8274 OEMI FUSED" FAILED TO FIND RESOURCES " MSM8274ROM" Finaly it showing RESOURCES "MSM8274ROM" ERROR when i connect a usb cable. LED RED is not blinking and even not showing? and in Device manager SEMC Flash Device is not displaying. what to do can u help me? |
08-18-2014, 19:28 | #35 (permalink) |
No Life Poster Join Date: Jan 2006 Age: 40
Member: 224075 Status: Offline Thanks Meter: 69 | i just repaird my Z1 now blink at sony logo and ask for software updte it not adetcted by setool, i think its need for charege i will charge it and try later Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE llbug: [\\?\USB#VID_0FCE&PID_D19A#6&177d73e3&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "A device attached to the system is not functioning" Elapsed:13 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCEDURE STOPPED BY USER Elapsed:35 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1221F601 HARDWARE ID : 04000100E1007B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... RUNNING S1_PRELOADER VER "LOADER_RELEASE_MSM8974_23_4_AID_4" LOADER AID: 0004 DEVICE ID: 01F62112 FLASH ID: "0011/01000010" LOADER VERSION: "LOADER_RELEASE_MSM8974_23_4_AID_4" WRITING PACKAGES ... Processing package C:\Users\ahmed\Desktop\Sony Z1 repair\C6903\C6903\14_2_A_0_290.APP_SW_Honami_GENE RIC_1272_6084_S1_SW_LIVE_6732_PID1_0005_MMC.SIN_FI LE_SET WILL UPDATE BOOT TO : 1270-3115 S1_BOOT_MSM8974_LA1.04_15 PARSING: "DEVELOPMENT" value OTP_LOCK_STATUS_1 : UNLOCKED, not match LOCKED PARSING: "TEST_OEM0_007B00E1" value OTP_LOCK_STATUS_1 : LOCKED, match LOCKED value OTP_DATA_1 : 00000100, not match 01000400 value IDCODE_1 : 007B00E1, match 007B00E1 PARSING: "PRECOMMERCIAL_007B00E1" value OTP_LOCK_STATUS_1 : LOCKED, match LOCKED value OTP_DATA_1 : 01000400, match 01000400 value IDCODE_1 : 007B00E1, match 007B00E1 PROCESSING : dbi_S1_Boot_MSM8974_LA1_04_15_AID_4_S1-SDI2-6732-PID1-0004-SDI_S1-BOOT-6732-0004-MMC.sin PROCESSING : emmc_appsboot_S1_Boot_MSM8974_LA1_04_15_AID_4_PLAT FORM-MSM8974-LIVE-HWID007B00E1-SWID09-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : s1sbl_S1_Boot_MSM8974_LA1_04_15_AID_4_PLATFORM-MSM8974-LIVE-HWID007B00E1-SWID65-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : sbl1_S1_Boot_MSM8974_LA1_04_15_AID_4_PLATFORM-MSM8974-LIVE-HWID007B00E1-SWID00-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : tz_S1_Boot_MSM8974_LA1_04_15_AID_4_PLATFORM-MSM8974-LIVE-HWID007B00E1-SWID07-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : Honami_S1BootConfig_MiscTA_130115_1430.ta MINOR ERROR [ Open_TA_failed, err: 001D ] BOOT UPDATED Processing ACPU files PROCESSING: cache_S1-SW-LIVE-6732-PID1-0005-MMC.sin PROCESSING: apps_log_S1-SW-LIVE-6732-PID1-0005-MMC.sin PROCESSING: kernel_S1-SW-LIVE-6732-PID1-0005-MMC.sin PROCESSING: fotakernel_S1-SW-LIVE-6732-PID1-0005-MMC.sin SKIP: partition-image_S1-SW-LIVE-6732-PID1-0005-MBR.sin PROCESSING: rpm_S1-RPMFW-LIVE-6732-PID1-0005-MMC.sin no update files in package FINISHED Elapsed:184 secs. |
09-02-2014, 15:27 | #36 (permalink) |
Member: 224075 Status: Offline Thanks Meter: 69 | i have onther sony Z1 dead when i try to update it to 4.4.4 its dead now ,but when i try to connect it to flash it its detected by computer as SEMC flash device but not detected by setool i try onther working phone its flashed ok by same cable and computer i try more than 3 computers same problem |
09-22-2014, 08:40 | #38 (permalink) |
Insane Poster Join Date: Jan 2006 Location: Ha Noi - Viet Nam
Member: 220723 Status: Offline Thanks Meter: 23 | 22/09/2014 2:31:13 CH will use Sahara protocol ... 22/09/2014 2:31:13 CH REMOVE TESTPOINT NOW, THEN PRESS "READY" 22/09/2014 2:31:13 CH 22/09/2014 2:31:17 CH PROCESSING ... 22/09/2014 2:31:17 CH SERIAL NUMBER : 6B4E6E01 22/09/2014 2:31:18 CH HARDWARE ID 00000000E1207B00 NOT SUPPORTED 22/09/2014 2:31:18 CH HARDWARE ID : 00000000E1207B00 22/09/2014 2:31:18 CH NOT SUPPORTED HASH :CC3153A80293939B90D02D3BF8B23E0292E452FEF662C7499 8421ADAD42A380F 22/09/2014 2:31:18 CH Elapsed:12 secs. |
10-14-2014, 10:48 | #39 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Inside of GsmhostinG
Member: 707582 Status: Offline Sonork: 100.1620432 Thanks Meter: 334 | c6603 xperia Z supported? i have 1 z red light working while connect charger or usb not detecting usb drivers,cant power on |
03-21-2015, 18:48 | #41 (permalink) |
No Life Poster Join Date: May 2005 Location: CANADA Age: 42
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... 0808010600900000 0D0F50424C5F446C6F6164564552322E30 162001000100 17004001000100E1907100 1801001EA8B0C1B209C88CBB3E220F0AC00F6E6520A273D516 B40E7F2EAEB0E5B3DB8B PHONE NOT SUPPORTED IN THIS MODE Elapsed:110 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... 0808010600900000 0D0F50424C5F446C6F6164564552322E30 162001000100 17004001000100E1907100 1801001EA8B0C1B209C88CBB3E220F0AC00F6E6520A273D516 B40E7F2EAEB0E5B3DB8B PHONE NOT SUPPORTED IN THIS MODE Elapsed:13 secs. |
The Following User Says Thank You to nasro_nd For This Useful Post: |
05-04-2015, 15:33 | #42 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2104532 Status: Offline Sonork: www.sonork.com Thanks Meter: 3 | help me repair boot z1 c6902 fail DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : D3B17A03 HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... |
The Following User Says Thank You to mobilecuatui For This Useful Post: |
07-13-2015, 06:36 | #43 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2427307 Status: Offline Thanks Meter: 0 | Xperia Z1 6903 I can't load, please help Welcome S1 Tool [28.02.2015]. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : C94A2502 HARDWARE ID : 00000000E1007B00 PRODUCT DETECTED: "MSM8974 Unfused" HASH :CC3153A80293939B90D02D3BF8B23E0292E452FEF662C7499 8421ADAD42A380F Emergency loader uploaded ... |
07-28-2015, 04:32 | #44 (permalink) |
Insane Poster Join Date: Mar 2014 Location: Cambodia
Member: 2157777 Status: Offline Thanks Meter: 4 | Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : B6C8E001 HARDWARE ID : 04000100E1007B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... ---------------------------------------------------------- Stuck on Waiting Phone My Phone Z ultra C6802 |
10-14-2015, 08:48 | #45 (permalink) |
Freak Poster Join Date: Jul 2003 Location: hk
Member: 33368 Status: Offline Thanks Meter: 8 | C6802 Fix the problem Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 0C052200 HARDWARE ID : 04000100E1007B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... RUNNING S1_PRELOADER VER "LOADER_RELEASE_MSM8974_23_4_AID_4" LOADER AID: 0004 DEVICE ID: 0022050C FLASH ID: "0015/01000001" LOADER VERSION: "LOADER_RELEASE_MSM8974_23_4_AID_4" WRITING PACKAGES ... Processing package F:\sony ericsson\Z Ultra and Z1 HARD BRICK RECOVERY\C6802\14_2_A_0_290.APP_SW_Togari_GENERIC_ 1271_5715_S1_SW_LIVE_6732_PID1_0005_MMC.SIN_FILE_S ET WILL UPDATE BOOT TO : 1270-3115 S1_BOOT_MSM8974_LA1.04_15 PARSING: "DEVELOPMENT" value OTP_LOCK_STATUS_1 : UNLOCKED, not match LOCKED PARSING: "TEST_OEM0_007B00E1" value OTP_LOCK_STATUS_1 : LOCKED, match LOCKED value OTP_DATA_1 : 00000100, not match 01000400 value IDCODE_1 : 007B00E1, match 007B00E1 PARSING: "PRECOMMERCIAL_007B00E1" value OTP_LOCK_STATUS_1 : LOCKED, match LOCKED value OTP_DATA_1 : 01000400, match 01000400 value IDCODE_1 : 007B00E1, match 007B00E1 PROCESSING : dbi_S1_Boot_MSM8974_LA1_04_15_AID_4_S1-SDI2-6732-PID1-0004-SDI_S1-BOOT-6732-0004-MMC.sin PROCESSING : emmc_appsboot_S1_Boot_MSM8974_LA1_04_15_AID_4_PLAT FORM-MSM8974-LIVE-HWID007B00E1-SWID09-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : s1sbl_S1_Boot_MSM8974_LA1_04_15_AID_4_PLATFORM-MSM8974-LIVE-HWID007B00E1-SWID65-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : sbl1_S1_Boot_MSM8974_LA1_04_15_AID_4_PLATFORM-MSM8974-LIVE-HWID007B00E1-SWID00-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : tz_S1_Boot_MSM8974_LA1_04_15_AID_4_PLATFORM-MSM8974-LIVE-HWID007B00E1-SWID07-OEM1-AID4-DEBUG00_S1-BOOT-6732-0004-MMC.sin PROCESSING : Togari_S1BootConfig_MiscTA_130115_1430.ta MINOR ERROR [ Open_TA_failed, err: 001D ] BOOT UPDATED Processing ACPU files PROCESSING: cache_S1-SW-LIVE-6732-PID1-0005-MMC.sin SKIP: apps_log_S1-SW-LIVE-6732-PID1-0005-MMC.sin PROCESSING: kernel_S1-SW-LIVE-6732-PID1-0005-MMC.sin PROCESSING: fotakernel_S1-SW-LIVE-6732-PID1-0005-MMC.sin SKIP: partition-image_S1-SW-LIVE-6732-PID1-0005-MBR.sin PROCESSING: rpm_S1-RPMFW-LIVE-6732-PID1-0005-MMC.sin no update files in package FINISHED Elapsed:36 secs. |
