Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
11-19-2015, 10:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Bangladesh Age: 40
Member: 1910629 Status: Offline Sonork: 100.1653190 Thanks Meter: 65 | sony mt27i flash after no network sony Erickson mt27i old v2.37 customer upgrade i flash 4.0 then no service problem i try many flash but same IMEI ok. baseband ok how to solve |
11-21-2015, 05:19 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | check your ics release, it should be matching to your region, And after downloading correct version, flash using flashtool, wipe everything. |
The Following User Says Thank You to -Mosin- For This Useful Post: |
11-21-2015, 08:05 | #4 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | Try this old firmware MT27i_6.0.B.3.184_CE.FTF Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
The Following User Says Thank You to gsm_masud7 For This Useful Post: |
11-22-2015, 06:30 | #6 (permalink) | |
Member: 1910629 Status: Offline Sonork: 100.1653190 Thanks Meter: 65 | Quote:
i flash ur file . but no network what to do> | |
11-22-2015, 08:53 | #7 (permalink) |
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | You can find this under *Settings > Mobile Network > Network Operators > Search Network ,Check Here is Available Network or No ?? if Here Not Available Network Hardware Problems Check Network ic Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
