Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
08-17-2016, 21:01 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: south africa Age: 39
Member: 1813139 Status: Offline Thanks Meter: 45 | Help plz failed error 228.01 03 04 08 0A 0C 229.04 08 0C 01 030 I FLASH ON SETOOL AFTER I TRY TO REPAIR IN Xperia Companion REPAIR ID DONE BUT PROBLEM IS SAME [ATTACH][/ATTACH] |
The Following User Says Thank You to yasirsw For This Useful Post: |
08-17-2016, 22:07 | #2 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2609438 Status: Offline Thanks Meter: 13 | Try to flash with Flashtool and in Firmware selector tick all options under the “Wipe” pane. http://www.xperiablog.net/2016/03/12...erifirm-guide/ |
08-19-2016, 20:34 | #4 (permalink) |
Member: 2609438 Status: Offline Thanks Meter: 13 | Try this workaround, you must disable the following system application: com.sonyericsson.startupflagservice 2 https://www.youtube.com/watch?v=W-bOYFLRhPQ&t=0s https://talk.sonymobile.com/t5/Xperi...-2/td-p/860449 |
12-14-2016, 07:37 | #5 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Inside NCK Dongle
Member: 1370010 Status: Offline Thanks Meter: 57 | i have tested one of this problem.... solution flash via setool using this 2 file at the support APP-SW_Tuba_GLOBALDS-LTE1D_33.2.B.3.81_1300-9504_S1-SW-LIVE-CF2A-PID1-0005-MBR FSP_Tuba_Customized-SA_GENERIC_33.2.B.3.81_1302-4393_R5A_S1-SW-LIVE-CF2A-PID1-0005-MMC problem will solved without error.... |
10-30-2017, 14:46 | #9 (permalink) |
Freak Poster Join Date: May 2014 Location: Al-Bakistan
Member: 2191194 Status: Offline Thanks Meter: 75 | sony f3311 factory startup service solved pro solvd with this file ver 37.0.A.2.108 downloded from setool sport... APP-SW_Bassoon_GLOBAL-LTE1A_37.0.A.2.108_1301-9750_S1-SW-LIVE-8C38-PID1-0005-MBR FSP_Bassoon_Customized-SA_GENERIC_37.0.A.2.108_1306-1005_R1A_S1-SW-LIVE-8C38-PID1-0005-MMC |
The Following User Says Thank You to ..Ali Abbas.. For This Useful Post: |
11-17-2017, 15:09 | #10 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
it didnt work on G3121 device.. still failed.. | |
12-18-2017, 09:29 | #11 (permalink) |
No Life Poster Join Date: Aug 2007 Location: earth
Member: 570373 Status: Offline Thanks Meter: 230 | thanks ..Ali Abbas.. APP-SW_Bassoon_GLOBAL-LTE1A_37.0.A.2.108_1301-9750_S1-SW-LIVE-8C38-PID1-0005-MBR FSP_Bassoon_Customized-SA_GENERIC_37.0.A.2.108_1306-1005_R1A_S1-SW-LIVE-8C38-PID1-0005-MMC workkkkkkk |
The Following User Says Thank You to naizer For This Useful Post: |
