Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 07-07-2017, 11:33   #1 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,074
Exclamation Information "FSC" scripts messages [ FAQ ] About newer Flashtools & Flashing
INFORMATION : FSC
A FSC script is a Flashing Template used From the 0.9.19 flashtools engine, which is actually designated to flash Xperias of seventh and eighth generation, this means, Z3+ (Z4) C5ultra and newer. This happens because of some modifications to the S1 protocol made by Sony, starting in those devices. Provided that, to use the new flashing engine,
script comes pre-installed from Flashtools 0.9.19.8. If you open it, you can see it's actually a series of steps, predefined, like opening TA partition 2, set flashing status, closing it, etc.
The problem here is that, this script was created from a USB Log generated by using Emma to flash a 18.3.1.C.1.17 firmware, which means this script is for KitKat, not Lollipop.
This means that, for example, the upload of the sin images is not done in the same exact order as it was intended to be (instead of uploading first the TAs, it uploads the dbi and appsboot, etc), and, as in KitKat there was no Apps_log, Flashtools will skip it flash even though you told it to flash the sin, and lastly, in case it messes up something, it makes a backup of your TA state before starting to flash, and then restore it back when all flashes finishes.
Being that said, I personally consider that using a KitKat FSC to flash a Lollipop FTF is, at least, DANGEROUS. So, I'd definetly recommend you to delete it if you don't plan to use it, or be really careful and click always on NO when the program prompts if we want to use it.
"FSC" scripts messages : To be safe regarding FSC scripts and various kind of bricks that make the RIL break without any apparent reason,
If you find bellow massage during flashing process
PHP Code:
"A FSC script is found: default.fsc. Do you want to add it?"
in this case : press " NO"
It is recommended to be safe
PHP Code:
"Those data are not in the FSC script and will be skipped"
press "yes" it is safe to flash this ftf haven't seen any problem till now ...!
__________________
To get Instant help use "search" & follow "sticky thread"..!!!
By respecting/following forum rules,
You will be respected .!
Best Wishes :
.:::Roy:::.
The Following 5 Users Say Thank You to gsm mithun roy For This Useful Post:
Page generated in 0.28604 seconds with 7 queries
