Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 04-26-2016, 14:40   #1 (permalink)
maxmobilephone's Avatar
Member: 1969978
Sonork: 100.1613242
Thanks Meter: 693
Arrow Pattern unlock. .sony xperia with flash tool
Hello everybody
unlock sony xperia by flash tool
Xperia Ray ST18i_4.1.B.0.587_lock remove from here
WT19a Walkman_4.1.B.0.587_lock remove from here
WT19i Walkman_4.1.B.0.587_lock remove from here
Xperia X10a_3.0.1.G.0.75_lock remove from here
Xperia X10i_3.0.1.G.0.75_lock remove from here
Xperia neo V MT11i_4.1.B.0.587 Lock_Remove from here
Xperia Neo L MT25i_4.1.B.0.631_Lock_Remove from here
Xperia Arc LT15i_4.1.B.0.431Lock_Remove from here
Xperia mini pro SK17i_4.1.B.0.587_lock remove from here
Xperia J ST26i_11.2.A.0.31_lock remove from here
Xperia C C2305_16.0.B.2.16_lock remove from here
Xperia play R800i_4.0.2.A.0.62_lock remove from here
Xperia E C1505_11.3.A.2.33_lock remove from here
Xperia E C1504_11.3.A.2.33_lock remove from here
Xperia E Dual C1604_11.3.A.2.1_lock remove from here
Xperia E Dual C1605_11.3.A.1.39_lock remove from here
Xperia P LT22i_6.2.A.1.100_lock remove from here
Xperia T LT30p_9.2.A.1.199_lock remove from here
Xperia SL LT26ii_6.2.B.1.96_lock remove from here
Xperia V LT25i_9.2.A.2.5_lock remove from here
Xperia L C2104_15.3.A.1.17_lock remove from here
Xperia L C2105_15.3.A.1.17_lock remove from here
Xperia M Dual C2004_15.5.A.1.5_lock remove from here
Xperia M Dual C2005_15.5.A.1.5_lock remove from here
Xperia M C1904_15.4.A.1.9_lock remove from here
Xperia M C1905_15.4.A.1.9_lock remove from here
Xperia E1 D2005_20.1.A.2.13_lock remove from here
Xperia E1 Dual D2105_20.1.B.0.64_lock remove from here
Xperia Sola MT27i_6.1.1.B.1.54 Lock_Remove from here
Xperia U ST25i_6.1.1.B.1.10_lock remove from here
C5502 xperia zr lock remove from here
Xperia T2 Ultra Dual D5322_19.1.1.C.0.56_lock remove from here
Xperia M2 D2306_18.3.C.0.37_lock remove from here
Xperia M2 D2303_18.3.C.0.37_lock remove from here
Xperia M2 Dual D2302_18.3.B.0.31_lock remove from here
Xperia M2 Aqua LTE-A D2403_18.3.C.0.37_lock remove from here
Xperia SP C5303_12.1.A.1.205_lock remove from here
Xperia Sp C5302_12.1.A.1.201 lock Remove from here
Xperia C3 Dual D2502_19.2.A.0.391_lock remove from here
Xperia Ultra C6802 lock remove from here
Z1 C6602_4.3_lock remove from here
Xperia Z Ultra C6833 14.4.A.0.108 Customized UK lock remove from here
Xperia Z1 C6903_14.4.A.0.108_lock remove from here
Xperia Z1 Compact LTE-A D5503_14.4.A.0.108_lock remove from here
Xperia ZL C6503_10.5.1.A.0.283_lock remove from here
Xperia Z LTE C6603_10.5.1.A.0.283_lock remove from here
Xperia X10 mini pro U20i_2.1.1.A.0.6_lock remove from here
Xperia X10 mini pro U20a_2.1.1.A.0.6_lock remove from here
Xperia X10 Mini E10a_2.1.1.A.0.6_lock remove from here
Xperia X10 Mini E10i_2.1.1.A.0.6_lock remove from here
Xperia X8 E15a_2.1.1.A.0.6_lock remove from here
Xperia X8 E15i_2.1.1.A.0.6_lock remove from here
Xperia Tipo ST21i_11.0.A.4.22_lock remove from here
Xperia miro ST23i_11.0.A.5.5_lock remove from here
Xperia E3 D2203_18.4.C.1.26_Lock remove from here
Xpera E3 Dual D2212_18.4.B.1.20_lock remove from here
Xperia E3 D2202_18.5.A.0.26_R7B_lock remove from here
Xperia T3 D5103_18.1.A.1.21_lock remove from here
Xperia T3 D5102_18.2.A.1.18_lock remove from here
Xperia E4 Dual E2115_24.0.B.3.8_R5A lock remove from here
Xperia E4 Dual E2124_24.0.B.3.8_R5A lock remove from here
Xperia E4 E2104 24.0.A.5.14_R4A lock remove from here
Xperia Z2 D6543 Lock Remove from here
Xperia Z3 D6633 lock remove from here
Xperia Z3 Compact LTE-A D5803_23.0.A.2.93_lock remove from here
Xperia Z3 D6653_23.0.A.2.93_lock remove from here
Xperia M4 Aqua E2303, E2353_8GB_26.1.A.2.99_R3A_lock remove from here
Xperia M4 Aqua E2306_16 GB_26.1.A.1.112_R2A_16 GB_lock remove from here
Xperia M4 Aqua Dual E2333, E2363_16GB_26.1.B.1.85_R5A_lock remove from here
Xperia E4g E2043_25.0.B.1.28_R3A_lock remove from here
Xperia E4g E2033_25.0.B.1.28_R3A_lock remove from here
Z2 D6503_23.0.1.A.0.167_R4B_lock remove from here
Xperia Z2 D6502 Lock Remove 23.0.1.A.0.167_R2B from here
Xperia C4 Single sim E5303, E5306, E5353 _27.1.A.1.93_R3A_lock remove from here
Xperia C4 Dual E5333, E5343, E5363 _27.1.B.1.93_R2A_lock remove from here
The Following 16 Users Say Thank You to maxmobilephone For This Useful Post:
Old 04-26-2016, 17:27   #2 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 193
How to check phone firmware version?
phone already locked.....
The Following 2 Users Say Thank You to shaongsm For This Useful Post:
Old 04-28-2016, 15:04   #3 (permalink)
Member: 1969978
Sonork: 100.1613242
Thanks Meter: 693
Originally Posted by shaongsm View Post
How to check phone firmware version ?
All File Is Last Version Bro No Need Check Your Mobile Firmware Version ..
The Following 3 Users Say Thank You to maxmobilephone For This Useful Post:
Old 08-11-2017, 17:54   #4 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 240
i need c4 dual (E5363) latest Flash file.
Page generated in 0.28373 seconds with 8 queries
