Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 04-08-2014, 21:36   #16 (permalink)
danisajee's Avatar
Member: 755480
Sonork: 100.1609798
Thanks Meter: 233
Stuck at fatching unlock data
Old 04-09-2014, 05:56   #17 (permalink)
Member: 1884036
Sonork: 100.1636857
Thanks Meter: 18
[QUOTE=ateebgulzar;10225141]bro i have in my hand Sony Xperia ST26i i have tried a lot of times please can you help with me not possible advance thanks[/Q
Old 04-09-2014, 18:10   #18 (permalink)
Member: 1418734
Sonork: umais rasheed
my boot loader unlock is not allowed...what should i do? plz helpp...i want to unlock my phone...attemp is 0
Old 04-10-2014, 09:54   #19 (permalink)
arimob's Avatar
Member: 147694
Thanks Meter: 69
Does this unlock the carrier newtork code allready
Old 04-10-2014, 13:11   #20 (permalink)
Member: 923032
Sonork: 321321
Thanks Meter: 17
stuck at fetching unlock data
Also have the same problem.
Old 04-10-2014, 15:07   #21 (permalink)
Registered User
Member: 744205
Thanks Meter: 13
not working stuck on fetching unlock data...
Old 04-13-2014, 07:10   #22 (permalink)
Temporary banned !!
Member: 860323
Sonork: google
Thanks Meter: 10
its from long time stak on fetching unlock data on sony lt26
Old 04-14-2014, 23:41   #23 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@All
Manually install ADB Drivers for Phone to detect, then use Fastboot drivers for S1. You can find these drivers in SeTool folder on your PC.
Good Luck
Old 04-16-2014, 21:29   #24 (permalink)
Member: 310418
Thanks Meter: 13
he guys, on lt30p SE the solution is not working or im doing something wrong . ;(, please give me step by step clue ;D
Old 04-21-2014, 07:32   #25 (permalink)
Member: 2171932
Sonork: www.sonork.com
sir can i ask what prob can solve this tools.............
Old 04-21-2014, 08:26   #26 (permalink)
Member: 1899191
Sonork: 100.1625109
Thanks Meter: 136
Originally Posted by GSMWorld View Post
SONY Bootloader Unlock
Help you to unlock the Bootloader first so that you could root and flash any custom recovery.
1. Make it safe and simple.
2. Have it done in an official way.
3. Support as many SONY devices as possible.
4. Automatically retrieve unlock code and eveything
Kingo Sony Bootloader Unlock - CNET Download.com
Enable USB Debugging
1. Connect your device to PC via USB cable. It is highly recommended that you use the original cable and plug it into the motherboard port.
2. Select your Android version and then follow the instructions as shown to enable USB Debugging.
3. After that, kingo will automatically install the device driver and establish connection with your device. Please be patient.
Read the Notifications
1. It is IMPORTANT that you read the notifications carefully to avoid trouble later on .
2. You have to be fully aware of the CONSEQUENCES before unlocking your Bootloader.
3. Which includes your WARRANTY CLAIM being voided and USER DATA being wiped off.
Click to Unlock
1. Click "Unlock" to start when you are ready.
2. It will take a few minutes before the whole process is complete.
3. During this course, please do not disconnect, move or touch your device in any way.
Unlock Succeeded!
1. Normally the unlocking process will go fine and succeed at last. Click "Finish" and wait for your device reboots itself so that your phone will be more stable.
2. If it fails, unfortunately, please contact us. And we will see what we can do to solve it.
i understand what u say it
but bro can u tell me y we need this
y we do this
where u need this?
kindly tell it about its importent?
Old 04-27-2014, 22:18   #27 (permalink)
Crazy Poster
Member: 2110024
Sonork: Djaber213
Thanks Meter: 5
is it solve blocked counter?
Old 05-10-2014, 15:18   #28 (permalink)
Member: 1423754
Sonork: nighthing
Thanks Meter: 23
hello i am having sony xperia m model c1905 bootloder unlock allowed but its fails to unlock any help?
Old 05-29-2014, 16:07   #29 (permalink)
Member: 2195460
Sonork: yanstar
Originally Posted by Ron2pet View Post
What phones can be unlocked?
To check if you phone can be unlocked, follow the steps below:
First, you should confirm that it is possible to unlock the boot loader of your phone by checking the service menu. In your phone, open the dialler and enter *#*#7378423#*#* to access the service menu.
In your phone, tap Service info > Configuration > Rooting Status. If Bootloader unlock allowed says Yes, then you can continue with the next step. If it says No, or if the status is missing, your device cannot be unlocked.
is there any other way to unlock my mk16a phone?
Old 07-07-2014, 09:56   #30 (permalink)
manule's Avatar
Member: 786607
Thanks Meter: 66
my phone not boot in fastboot wt19i
Page generated in 0.20391 seconds with 8 queries
