Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
10-28-2014, 09:28 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: karnataka
Member: 1574088 Status: Offline Sonork: 1647365 Thanks Meter: 74 | sony e3 hard reset solution sony e3 hard reset file ,, use this file flash with flash tool file link D2203_d2202 hard reset - Download - 4shared 100% working for d2202 and d2203 |
The Following 3 Users Say Thank You to Ganeshg24 For This Useful Post: |
11-19-2014, 09:13 | #3 (permalink) |
Member: 1574088 Status: Offline Sonork: 1647365 Thanks Meter: 74 | but there no model number d2202 in the setool but there no model number d2202 in the setool use flash tool ,,https://docs.google.com/uc?id=0B8HYFIy2LVm5OUVxczI0WEdIbjg&export=download |
The Following 2 Users Say Thank You to Ganeshg24 For This Useful Post: |
11-22-2014, 12:02 | #4 (permalink) |
Insane Poster Join Date: Mar 2008 Location: india
Member: 737502 Status: Offline Thanks Meter: 11 | mr ganesh thanks a lot for shareing i had downloaded this tool also having D2203_d2202 hard reset.ftf file 22/031/2014 16:31:13 - INFO - <- This level is successfully initialized 22/031/2014 16:31:13 - INFO - Flashtool Version 0.9.0.0 built on 2012-07-19 22:57:15 22/031/2014 16:31:13 - INFO - You can drag and drop ftf files here to start flashing them 22/031/2014 16:31:14 - INFO - Device disconnected 22/031/2014 16:31:27 - INFO - Selected D2203_d2202 hard reset.ftf 22/031/2014 16:31:27 - INFO - Preparing files for flashing 22/031/2014 16:31:29 - INFO - Please connect your device into flashmode. 22/031/2014 16:31:37 - INFO - Device connected in flash mode 22/031/2014 16:31:37 - INFO - Opening device for R/W 22/031/2014 16:31:37 - INFO - Reading device information 22/031/2014 16:31:37 - INFO - Phone ready for flashmode operations. 22/031/2014 16:31:37 - INFO - Start Flashing 22/031/2014 16:31:37 - INFO - Flashing loader i tried many times it stops here please guide thanks |
12-01-2014, 22:07 | #5 (permalink) | |
Insane Poster Join Date: May 2004 Age: 49
Member: 65522 Status: Offline Thanks Meter: 10 | Quote:
The Following User Says Thank You to Gortaur For This Useful Post: |
12-03-2014, 12:46 | #6 (permalink) | |
Member: 1574088 Status: Offline Sonork: 1647365 Thanks Meter: 74 | Quote:
use this latest flash tool https://docs.google.com/file/d/0ByK8...d4M1RzOUU/edit | |
02-06-2015, 18:32 | #8 (permalink) |
No Life Poster Join Date: Dec 2009 Location: INDIA Age: 36
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | Thanks sir g its great job i have done it 1.download firmware as shown on link and extract it D2203_d2202 hard reset - Download - 4shared 2. download flash tool as shown link and install it https://docs.google.com/file/d/0ByK8...OUU/edit?pli=1 3. install drivers ggsetup-2.2.0.10 4. put firmware in flash tool c-flashtool-firmware delete already input flash file in firmware folder and put in D2203_d2202 hard reset.ftf 5.open flash tool and click on flash device and select flash mode and ok and after flash 6. flash tool shown 4 options 1st unplug the device etc 7.now turn off your device and connect with pc by pressing volume down and conect micro usb cable your device is ok done now start it it power on with long process 3 or 5 mint but dont worry your devce is ok check it i have done it 06/031/2015 22:31:21 - INFO - Device connected in flash mode 06/031/2015 22:31:45 - INFO - Selected Bundle for Sony Xperia E3 (D2203). FW release : 18.4.C.1.29. Customization : DE 06/031/2015 22:31:45 - INFO - Preparing files for flashing 06/031/2015 22:31:49 - INFO - Please connect your device into flashmode. 06/031/2015 22:31:50 - INFO - Opening device for R/W 06/031/2015 22:31:50 - INFO - Reading device information 06/031/2015 22:31:50 - INFO - Phone ready for flashmode operations. 06/031/2015 22:31:50 - INFO - Current device : D2202 - MQ4820D15956 - 1287-4608_R6B - 1286-1545_18.4.A.1.25 - GLOBAL-HSPA_18.4.A.1.25 06/031/2015 22:31:50 - INFO - Start Flashing 06/031/2015 22:31:50 - INFO - Processing loader.sin 06/031/2015 22:31:50 - INFO - Checking header 06/031/2015 22:31:50 - INFO - Flashing data 06/031/2015 22:31:51 - INFO - Processing of loader.sin finished. 06/031/2015 22:31:51 - INFO - Loader : S1_Root_f82d - Version : LOADER_RELEASE_MSM8X26_31_AID_4 / Boot version : S1_Boot_MSM8x26_LA1.0_307 / Bootloader status : ROOTABLE 06/031/2015 22:31:51 - INFO - No bootdelivery to send 06/031/2015 22:31:51 - INFO - Processing userdata.sin 06/031/2015 22:31:51 - INFO - Checking header 06/031/2015 22:31:51 - INFO - Flashing data 06/032/2015 22:32:23 - INFO - Processing of userdata.sin finished. 06/032/2015 22:32:23 - INFO - Ending flash session 06/032/2015 22:32:23 - INFO - Flashing finished. 06/032/2015 22:32:23 - INFO - Please unplug and start your phone 06/032/2015 22:32:23 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 06/032/2015 22:32:23 - INFO - Device connected in flash mode 06/032/2015 22:32:54 - INFO - Device disconnected 06/035/2015 22:35:09 - INFO - Device connected with USB debugging off 06/035/2015 22:35:09 - INFO - For 2011 devices line, be sure you are not in MTP mode 06/037/2015 22:37:05 - INFO - Device disconnected |
The Following 2 Users Say Thank You to mr.luckytarun For This Useful Post: |
03-13-2015, 16:21 | #11 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | follow this post for all xperia http://forum.gsmhosting.com/vbb/f778...flash-1872872/ |
05-18-2015, 06:50 | #13 (permalink) |
Member: 1195083 Status: Offline Sonork: QQ:3208821449 Thanks Meter: 1,348 | sony experia D2212 I have done pattern lock with this file [IMG][/IMG] |
The Following User Says Thank You to mr.luckytarun For This Useful Post: |
