Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 01-13-2013, 13:36   #1 (permalink)
Member: 772651
Sony Ericsson XPERIA X10 mini Android hard reset
Sony Ericsson XPERIA X10 mini hard reset via software update
Update Xperia X10 mini firmware with PC companion software
Force a restart of the phone if the phone hangs and can't be restarted normally.
Update your phone. Even if you have the latest software, updating your phone can improve
software stability and solve other problems.
Resetting the phone
Resetting the phone deletes all data, including downloaded applications, and resets the
phone back to its initial state, the state before you turned on the phone for the first time.
Make sure to back up important data you have on the phone before you reset the phone.
To reset the phone
1 From the Home screen, drag upwards.
2 Find and tap Settings > SD card, USB Mass Storage & phone storage > Factory
data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
There is also a RESET button on the back side of the device (under the IMEI sticker in the lower left corner) under the battery cover.
Download PC companion and install
Install PC companion on your PC computer. Follow instruction. For firmware update you need a micro USB cable. When the pc recognizing your txt it will install the necessary driver files.
After your txt connected press Start / in Support Zone
You can also use Sony Ericsson update service tool
PC Suite is out of date use PC companion software instead
If nothing works: As last resort do a Sony Ericsson txt phone repaire with PC Suite. Use this method to hard reset AFTER INSTALLATION----> TOOLS > PHONE REPAIR
Software - Sony Smartphones (UK)
The Following 2 Users Say Thank You to ajit bs For This Useful Post:
Old 01-13-2013, 14:08   #2 (permalink)
Temporary banned !!
Member: 1702642
Sonork: m_4_mubashar@yahoo.com
give me linke pc suite
Old 01-15-2013, 06:01   #3 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
no need to install pc suite just download latest update service stup
Old 01-15-2013, 06:02   #4 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Download Update Service 2.11.12.5 Free - Update the software stability of your Sony Ericsson phone - Softpedia
The Following User Says Thank You to sharpgsm For This Useful Post:
Old 01-15-2013, 06:11   #5 (permalink)
vpjoby's Avatar
Member: 306716
Sonork: 100.1625142
Thanks friend....................................
Old 01-15-2013, 07:41   #6 (permalink)
mubasharsoft's Avatar
Member: 1608878
Sonork: 100.1608233
thanks for sharing ............................................
Old 01-15-2013, 07:46   #7 (permalink)
tejaram's Avatar
Member: 1681461
Sonork: 100.1637223
Thank You For This Useful Post
wbr ; tejaram
Old 03-27-2013, 11:54   #8 (permalink)
Member: 555040
Thanks for sharing bro........
Old 05-14-2013, 18:00   #9 (permalink)
Member: 1866877
Sonork: nessybee
thanks for sharing brooii.
Page generated in 0.34331 seconds with 10 queries
