Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 10-15-2013, 07:23   #1 (permalink)
Member: 1115725
Sonork: 100.1653957
Sony experia st18i blank screen problem
hi
I have Sony experia St18i which have a very strange problem.
phone is working very fine till I lock the phone with lock button.
when I lock the phone screen goes blank and I am able to do call's and screen touch is also working fine.when I do not lock the phone it's work perfectly.I can't understand what to do.
sorry for my English
please give my any solution Thanks.
Old 10-15-2013, 07:36   #2 (permalink)
Member: 1736467
Sonork: 1613563
Thanks Meter: 46
try to update with flashtool.
if u have protector on it. remove it.
The Following User Says Thank You to Rocks.com. For This Useful Post:
Old 10-26-2013, 00:21   #3 (permalink)
senses's Avatar
Member: 548988
Sonork: 100.1624541
Thanks Meter: 10
Originally Posted by shamsh_007 View Post
hi
hi,
Updating with flashtool solves your problem, or what is the true solution.
regards
Old 10-28-2013, 09:54   #4 (permalink)
Member: 979896
more info of the same problem
I have the same problem.
Flashtool, custom kernels, different stock and custom ROMs... doesnt solve it.
I've seen schematic pictures which fuse to jump or what to clean, but the difference is mine has backlight, and after some time the phone will start normal (with screen good and usable). I can work weeks on it without going to deep_sleep (power button). Also I don't have equipment to rehot ic, check fuse and no technical knowledge for hardware.
I took a lot of dmesg and logcats and i can see errors in kernel but one unusual line that caught my eye is: <simple_remote_pf simple_remote_pf.0: simple_remote_pf_button_handler - Button callback not registered> when starting xperia ray and when pressed power button while its on.
If you need more info just ask.
Page generated in 0.11455 seconds with 8 queries
