Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
07-19-2017, 00:53 | #18 (permalink) |
Freak Poster Join Date: Feb 2007 Age: 43
Member: 454914 Status: Offline Thanks Meter: 54 | C6902 Pattern Reset Done! log Code: 18/030/2017 19:30:41 - INFO - Device connected in flash mode 18/031/2017 19:31:04 - INFO - Device disconnected 18/032/2017 19:32:59 - INFO - Selected Bundle for Sony Xperia Z1(C6902). FW release : Xperia Z1 HSPA+. Customization : Format 18/032/2017 19:32:59 - INFO - Preparing files for flashing 18/033/2017 19:33:00 - INFO - Please connect your device into flashmode. 18/033/2017 19:33:08 - INFO - Device connected in flash mode 18/033/2017 19:33:09 - INFO - Opening device for R/W 18/033/2017 19:33:09 - INFO - Reading device information 18/033/2017 19:33:09 - INFO - Phone ready for flashmode operations. 18/033/2017 19:33:09 - INFO - Opening TA partition 2 18/033/2017 19:33:09 - INFO - Current device : C6902 - BH902D3A0G - 1276-7828_R5C - 1272-6084_14.4.A.0.157 - GLOBAL-HSPA_14.4.A.0.157 18/033/2017 19:33:09 - INFO - Closing TA partition 18/033/2017 19:33:09 - INFO - Start Flashing 18/033/2017 19:33:09 - INFO - Processing loader.sin 18/033/2017 19:33:09 - INFO - Checking header 18/033/2017 19:33:09 - INFO - Flashing data 18/033/2017 19:33:09 - INFO - Loader : S1_Root_6732 - Version : MSM8974_23 / Boot version : S1_Boot_MSM8974_Rhine1.2_LA1.04_19 / Bootloader status : ROOTABLE 18/033/2017 19:33:09 - INFO - Max packet size set to 512K 18/033/2017 19:33:09 - INFO - USB buffer size set to 512K 18/033/2017 19:33:17 - INFO - Found a template session. Using it : C:\Users\Gibe\.flashTool\devices\C69XX\default.fsc 18/033/2017 19:33:17 - INFO - Opening TA partition 2 18/033/2017 19:33:17 - INFO - Writing TA unit 00002774. Value : 01 18/033/2017 19:33:17 - INFO - Closing TA partition 18/033/2017 19:33:17 - WARN - partition is excluded from bundle 18/033/2017 19:33:17 - INFO - Opening TA partition 2 18/033/2017 19:33:17 - WARN - dbi is excluded from bundle 18/033/2017 19:33:17 - WARN - emmc_appsboot is excluded from bundle 18/033/2017 19:33:17 - INFO - Closing TA partition 18/033/2017 19:33:17 - INFO - Opening TA partition 2 18/033/2017 19:33:17 - WARN - Unit 2127 not found in bundle 18/033/2017 19:33:17 - WARN - Unit 2301 not found in bundle 18/033/2017 19:33:17 - INFO - Closing TA partition 18/033/2017 19:33:17 - INFO - Opening TA partition 2 18/033/2017 19:33:17 - WARN - s1sbl is excluded from bundle 18/033/2017 19:33:17 - WARN - sbl1 is excluded from bundle 18/033/2017 19:33:17 - WARN - tz is excluded from bundle 18/033/2017 19:33:17 - INFO - Closing TA partition 18/033/2017 19:33:17 - INFO - Opening TA partition 2 18/033/2017 19:33:17 - WARN - cache is excluded from bundle 18/033/2017 19:33:17 - WARN - apps_log is excluded from bundle 18/033/2017 19:33:17 - WARN - kernel is excluded from bundle 18/033/2017 19:33:17 - WARN - fotakernel is excluded from bundle 18/033/2017 19:33:17 - WARN - rpm is excluded from bundle 18/033/2017 19:33:17 - INFO - Closing TA partition 18/033/2017 19:33:17 - INFO - Opening TA partition 2 18/033/2017 19:33:17 - INFO - Processing userdata.sin 18/033/2017 19:33:17 - INFO - Checking header 18/033/2017 19:33:17 - INFO - Flashing data 18/033/2017 19:33:48 - WARN - system is excluded from bundle 18/033/2017 19:33:48 - WARN - amss_fs_1 is excluded from bundle 18/033/2017 19:33:48 - WARN - amss_fs_2 is excluded from bundle 18/033/2017 19:33:48 - WARN - amss_fsg is excluded from bundle 18/033/2017 19:33:48 - INFO - Closing TA partition 18/033/2017 19:33:48 - INFO - Opening TA partition 2 18/033/2017 19:33:48 - WARN - Unit 2404 not found in bundle 18/033/2017 19:33:48 - WARN - Unit 2212 not found in bundle 18/033/2017 19:33:48 - INFO - Closing TA partition 18/033/2017 19:33:48 - INFO - Opening TA partition 2 18/033/2017 19:33:48 - INFO - Closing TA partition 18/033/2017 19:33:48 - INFO - Opening TA partition 2 18/033/2017 19:33:48 - WARN - elabel is excluded from bundle 18/033/2017 19:33:48 - INFO - Closing TA partition 18/033/2017 19:33:48 - INFO - Opening TA partition 2 18/033/2017 19:33:48 - INFO - Writing TA unit 00002725. Value : 32 30 31 37 2D 30 37 2D 31 38 20 31 39 3A 33 33 3A 34 38 00 18/033/2017 19:33:48 - INFO - Writing TA unit 00002774. Value : 00 18/033/2017 19:33:48 - INFO - Closing TA partition 18/033/2017 19:33:48 - INFO - Ending flash session 18/033/2017 19:33:48 - INFO - Flashing finished. 18/033/2017 19:33:48 - INFO - Please unplug and start your phone 18/033/2017 19:33:49 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings Last edited by Deepesh Sharma; 08-08-2017 at 05:23. Reason: warp code |
08-07-2017, 16:31 | #21 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear @ronyd9, Here It's Xperia L C2105_15.3.A.1.17_lock remove.ftf File : DOWNLOAD All Credit Goes To Uploader. |
The Following 2 Users Say Thank You to MyGSM World For This Useful Post: |
08-08-2017, 11:10 | #24 (permalink) | |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Quote:
08-25-2017, 10:24 | #25 (permalink) |
Junior Member Join Date: Jun 2001 Location: Dublin
Member: 5078 Status: Offline Thanks Meter: 1 | Sony Xperia E5 F3311 FTF Hi Guys, Would some kind person have the ftf file for a sony xperia e5 F3311 please. cheers & tia T |
The Following User Says Thank You to techi For This Useful Post: |
08-25-2017, 11:11 | #26 (permalink) | |
Sony_Xperia_E5_F3311_37.0.A.2.108_1306-1005_Customized_SA.zip Download | |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
09-09-2017, 11:13 | #28 (permalink) |
Freak Poster Join Date: Jun 2013 Location: South Africa
Member: 1961231 Status: Offline Thanks Meter: 36 | i downloaded and install flashtool-0.9.22.3-windows.exe after install i use it 2 or 3 times also but then its not opening and shows error compatibility error 64 bit. my windows is 32 bit and there is no option to select 32 or 64 bit when i install it. its automatically installed 64bit. please help |
09-09-2017, 15:37 | #30 (permalink) |
Member: 5078 Status: Offline Thanks Meter: 1 | still not removed pattern I still could not remove pattern lock Model sony F3311 Sent from my ONEPLUS A3003 using Tapatalk Last edited by Deepesh Sharma; 09-09-2017 at 17:00. Reason: merge post |
