Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 11-05-2014, 13:53   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Sony Xperia SP C5303 / C5306 / M35h Dead Boot Repair
Bricked phone symptoms:
  • can't power on after flash,
  • no lcd or led reaction for power button,
  • no lcd or led reaction for charger,
  • no lcd or led reaction if phone is connected to PC,
  • your PC can't detect your phone with vol-,
  • phone does not vibrate when holding vol+ and power together.
Repair steps:
Test mode point Posted By NikkyM
Firstly connect turned off bricked phone to your PC. If phone will be detected in device manager as:
qhusb_dload device
You are lucky and this is the end of the first step for you. Just disconnect phone.
If your phone can't be detected at all, you must find testpoint. Disassemble your phone
remove battery and connect each golden point on main board one by one to metal shield and attach usb cable. If your phone will be detected in device manager as flash device or something like that you've found testpoint. Don't forget to take a picture of main board and mark testpoint nd post here
Download All FilesHere
Download and run this s1tool:
Download boot firmware for your Sony Xperia SP (extract it from rar):
In S1tool choose S1 EMERGENCY mode, press Flash button, select Sony Xperia SP boot firmware .sin_file_set file,
Press Testpoint READY button
and if your phone is detected as qhusb_dload device, just attach usb cable. If not, perform all steps from point 3 (connect testpoint to GND and attach USB cable).
When drivers will be installed and phone will be detected, program will ask you to disconnect testpoint. Disconnect testpoint from GND and press Testpoint READY button.
After that phone will load emergency s1 loader, re-enumerate usb, load s1 loader and flash selected boot firmware.
Welcome to S1 tool.
That is small and crippled subset of SETOOL2 service tool.
SELECT FIRMWARE PACKAGES
YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON
CHECKING PACKAGES ...
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
will use DLOAD protocol ...
0808010600900000
0D0F50424C5F446C6F6164564552322E30
162001000100
17004001000100E1507E00
PRODUCT DETECTED: "SONY MSM8960-3 Pro OEM1 Fused"
1801000F43240892D02F0DC96313C81351B40FD5029ED98FF9 EC7074DDAE8B05CDC8E1
PROCESSING ...
REMOVE TESTPOINT NOW, THEN PRESS "READY"
Emergency loader uploaded ...
RUNNING S1_PRELOADER VER "R5G008"
LOADER AID: 0001
DEVICE ID: 2078EB03
FLASH ID: "00FE/004E003F"
LOADER VERSION: "R5G008"
WRITING PACKAGES ...
Processing package
C:\Users\Administrator\Desktop\S1Boot_R11B023_HWID 7E50E1.SIN_FILE_SET
Processing ACPU files
PROCESSING: boot.sin
no update files in package
FINISHED
Elapsed:29 secs.
After Repair Done Flash vit firmware.
Source:sony.yt
PLEASE DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
The Following 19 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-07-2014, 13:19   #2 (permalink)
Member: 217891
Thanks Meter: 237
i think that work too with c6603 i not test it but in other forum somone test and work
Old 11-07-2014, 13:57   #3 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Yes yu can fix but yu need Boot files for c6603
i vil make thread for Sony Xperia z Series
The Following 2 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-07-2014, 14:28   #4 (permalink)
Member: 2278142
Sonork: 100.1623070
Thanks Meter: 15
Sir i cant under stand how to connect test poin step by step
any pic sare plz
Old 11-07-2014, 15:08   #5 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
Nice very nice plz sare z serise boot file and prosses how to do
Old 11-07-2014, 15:10   #6 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
any pic sare plz
No test pic picrs for now yu hav to find yur self as i mentioned above
Old 11-07-2014, 16:12   #7 (permalink)
Member: 2278142
Sonork: 100.1623070
Thanks Meter: 15
ok i will try to test any fone then i will post soon
Old 11-07-2014, 20:20   #8 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
http://forum.gsmhosting.com/vbb/f778...epair-1877259/
Old 11-17-2014, 17:14   #9 (permalink)
Crazy Poster
Member: 1925325
Thanks Meter: 14
Thanks,
and Photo: Xperia SP C5303
[/URL]
[/URL]
The Following 2 Users Say Thank You to NikkyM For This Useful Post:
Old 12-11-2014, 13:33   #10 (permalink)
Member: 2106857
Sonork: 100.1651678
Thanks Meter: 27
how to repair dead boot sony D6503
Old 12-13-2014, 14:49   #11 (permalink)
Member: 1899665
Thanks Meter: 5
Not work for sp c5302 other way plz my phone is dead
Old 01-18-2015, 19:00   #12 (permalink)
Member: 2329987
not work for my sp c5302, s1 tool shownig 'Waiting for phone ...'
Same here,
but in device manager 'qhusb_dload device' is showing in Universal Serial Bus devices area.
any solution? pls help me
my phone is dead
Sorry for my bad English.
Thanks in advance
Old 01-28-2015, 19:03   #13 (permalink)
Member: 327867
Thanks Meter: 12
Error
Welcome to S1 tool.
TO CONNECT NEXT PHONES
X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro
LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY
PRESS AND HOLD "BACK" BUTTON...
ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro
and Sony Xperia phone
PRESS AND HOLD "Volume Down" BUTTON...
PLEASE ATTACH TURNED OFF PHONE NOW
PROCEDURE STOPPED BY USER
supported phone was not detected
Elapsed:27 secs.
Elapsed:86 secs.
ATTACH TESTPOINT
0808010600900000
162001000100
PROCESSING ...
LOADER AID: 0001
FATAL ERROR [ Found_memory_not_supported_by_this_loader, err: 0074 ]
LOADER NOT RESPONDING
Elapsed:19 secs.
Old 02-02-2015, 05:12   #14 (permalink)
slav-on's Avatar
Member: 52495
Thanks Meter: 25
Welcome to S1 tool.
ATTACH TESTPOINT
0808010600900000
162001000100
PROCESSING ...
And wait...
Dont re-enumerate usb
Old 03-01-2015, 16:50   #15 (permalink)
Member: 251872
Thanks Meter: 309
hi
icant find boot file for c5503
i use c6603 bootfile but cant write the bootfile
Page generated in 0.25708 seconds with 8 queries
