Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
11-05-2014, 13:53 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Sony Xperia SP C5303 / C5306 / M35h Dead Boot Repair Sony Xperia SP C5303 / C5306 / M35h Dead Boot Repair Bricked phone symptoms:
Test mode point Posted By NikkyM Firstly connect turned off bricked phone to your PC. If phone will be detected in device manager as: Code: qhusb_dload device If your phone can't be detected at all, you must find testpoint. Disassemble your phone remove battery and connect each golden point on main board one by one to metal shield and attach usb cable. If your phone will be detected in device manager as flash device or something like that you've found testpoint. Don't forget to take a picture of main board and mark testpoint nd post here Download All FilesHere Download and run this s1tool: Download boot firmware for your Sony Xperia SP (extract it from rar): In S1tool choose S1 EMERGENCY mode, press Flash button, select Sony Xperia SP boot firmware .sin_file_set file, Press Testpoint READY button and if your phone is detected as qhusb_dload device, just attach usb cable. If not, perform all steps from point 3 (connect testpoint to GND and attach USB cable). When drivers will be installed and phone will be detected, program will ask you to disconnect testpoint. Disconnect testpoint from GND and press Testpoint READY button. After that phone will load emergency s1 loader, re-enumerate usb, load s1 loader and flash selected boot firmware. Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... 0808010600900000 0D0F50424C5F446C6F6164564552322E30 162001000100 17004001000100E1507E00 PRODUCT DETECTED: "SONY MSM8960-3 Pro OEM1 Fused" 1801000F43240892D02F0DC96313C81351B40FD5029ED98FF9 EC7074DDAE8B05CDC8E1 PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" Emergency loader uploaded ... RUNNING S1_PRELOADER VER "R5G008" LOADER AID: 0001 DEVICE ID: 2078EB03 FLASH ID: "00FE/004E003F" LOADER VERSION: "R5G008" WRITING PACKAGES ... Processing package C:\Users\Administrator\Desktop\S1Boot_R11B023_HWID 7E50E1.SIN_FILE_SET Processing ACPU files PROCESSING: boot.sin no update files in package FINISHED Elapsed:29 secs. After Repair Done Flash vit firmware. Source:sony.yt PLEASE DON'T SAY THANKSJUST PRESS BUTTON BUTTON Last edited by wgmmmx1; 04-22-2022 at 10:23. |
The Following 19 Users Say Thank You to jamesjerss For This Useful Post: |
11-07-2014, 20:20 | #8 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
11-17-2014, 17:14 | #9 (permalink) |
Crazy Poster Join Date: Apr 2013 Location: Austria
Member: 1925325 Status: Offline Thanks Meter: 14 | Thanks, and Photo: Xperia SP C5303 [/URL] [/URL] Last edited by NikkyM; 11-17-2014 at 17:24. |
The Following 2 Users Say Thank You to NikkyM For This Useful Post: |
01-18-2015, 19:00 | #12 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2329987 Status: Offline Thanks Meter: 0 | not work for my sp c5302, s1 tool shownig 'Waiting for phone ...' Same here, not work for my sp c5302, s1 tool shownig 'Waiting for phone ...' but in device manager 'qhusb_dload device' is showing in Universal Serial Bus devices area. any solution? pls help me my phone is dead Sorry for my bad English. Thanks in advance |
01-28-2015, 19:03 | #13 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Romania Age: 40
Member: 327867 Status: Offline Thanks Meter: 12 | Error Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro and Sony Xperia phone PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW Waiting for phone ... PROCEDURE STOPPED BY USER supported phone was not detected Elapsed:27 secs. TO CONNECT NEXT PHONES X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY PRESS AND HOLD "BACK" BUTTON... ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro and Sony Xperia phone PRESS AND HOLD "Volume Down" BUTTON... PLEASE ATTACH TURNED OFF PHONE NOW Waiting for phone ... PROCEDURE STOPPED BY USER supported phone was not detected Elapsed:86 secs. DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... 0808010600900000 0D0F50424C5F446C6F6164564552322E30 162001000100 17004001000100E1507E00 PRODUCT DETECTED: "SONY MSM8960-3 Pro OEM1 Fused" 1801000F43240892D02F0DC96313C81351B40FD5029ED98FF9 EC7074DDAE8B05CDC8E1 PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" Emergency loader uploaded ... RUNNING S1_PRELOADER VER "R5G008" LOADER AID: 0001 FATAL ERROR [ Found_memory_not_supported_by_this_loader, err: 0074 ] LOADER NOT RESPONDING Elapsed:19 secs. |
02-02-2015, 05:12 | #14 (permalink) |
Freak Poster Join Date: Feb 2004 Location: BY Age: 49
Member: 52495 Status: Offline Thanks Meter: 25 | Welcome to S1 tool. That is small and crippled subset of SETOOL2 service tool. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use DLOAD protocol ... 0808010600900000 0D0F50424C5F446C6F6164564552322E30 162001000100 17004001000100E1507E00 PRODUCT DETECTED: "SONY MSM8960-3 Pro OEM1 Fused" 1801000F43240892D02F0DC96313C81351B40FD5029ED98FF9 EC7074DDAE8B05CDC8E1 PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" Emergency loader uploaded ... And wait... Dont re-enumerate usb |
