Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 06-26-2016, 16:46   #31 (permalink)
Member: 2581214
sir pls help sony ericson U1i SI 1227-0923
Originally Posted by jamesjerss View Post
Yes yu can fix but yu need Boot files for c6603
i vil make thread for Sony Xperia z Series
please just stock on logo .what would be the possible solution plaese help thanks
Old 07-16-2016, 09:55   #32 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
C5303 repair boot successfully
16/07/2016 11:31:54 Welcome S1 Tool [28.02.2015].
16/07/2016 11:31:54 That is small and crippled subset of SETOOL2 service tool.
16/07/2016 11:31:59
16/07/2016 11:31:59 SELECT FIRMWARE PACKAGES
16/07/2016 11:31:59 YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON
16/07/2016 11:32:00 CHECKING PACKAGES ...
16/07/2016 11:32:00
16/07/2016 11:32:00 DETACH USB CABLE FROM PHONE
16/07/2016 11:32:00 REMOVE BATTERY FROM PHONE
16/07/2016 11:32:00 ATTACH TESTPOINT
16/07/2016 11:32:00 PRESS "READY", THEN ATTACH USB CABLE TO PHONE
16/07/2016 11:32:00
16/07/2016 11:33:42 will use DLOAD protocol ...
16/07/2016 11:33:42 0808010600900000
16/07/2016 11:33:42 0D0F50424C5F446C6F6164564552322E30
16/07/2016 11:33:42 162001000100
16/07/2016 11:33:42 17004001000100E1507E00
16/07/2016 11:33:42 PRODUCT DETECTED: "SONY MSM8960-3 Pro OEM1 Fused"
16/07/2016 11:33:43 1801000F43240892D02F0DC96313C81351B40FD5029ED98FF9EC7074DDAE8B05CDC8E1
16/07/2016 11:33:43 PROCESSING ...
16/07/2016 11:33:44 REMOVE TESTPOINT NOW, THEN PRESS "READY"
16/07/2016 11:33:44
16/07/2016 11:34:21 Emergency loader uploaded ...
16/07/2016 11:34:23
16/07/2016 11:34:23 RUNNING S1_PRELOADER VER "R5G008"
16/07/2016 11:34:23 LOADER AID: 0001
16/07/2016 11:34:24 DEVICE ID: CC64EE04
16/07/2016 11:34:24 FLASH ID: "00FE/004E003F"
16/07/2016 11:34:24 LOADER VERSION: "R5G008"
16/07/2016 11:34:24
16/07/2016 11:34:24 WRITING PACKAGES ...
16/07/2016 11:34:24 Processing package
16/07/2016 11:34:24 C:\Documents and Settings\Gsm-Service\Desktop\sony\S1Boot_R11B023_HWID7E50E1.SIN_FILE_SET
16/07/2016 11:34:24
16/07/2016 11:34:24 Processing ACPU files
16/07/2016 11:34:24 PROCESSING: boot.sin
16/07/2016 11:34:27 no update files in package
16/07/2016 11:34:27 FINISHED
16/07/2016 11:34:27 Elapsed:148 secs.
The Following User Says Thank You to sebY7676 For This Useful Post:
Old 08-09-2016, 12:03   #33 (permalink)
Member: 2609438
Thanks Meter: 13
Broken power inductor
Hi all, anyone knows the characteristics of the power inductor indicated in the picture?
Due to a fall, has been fractured and my C5303 will not power on.
Thanks a lot!
Old 09-26-2016, 09:17   #34 (permalink)
Member: 1792542
Sonork: 100.1672411
Thanks Meter: 41
link not work
Sony Xperia SP C5303 / C5306 / M35h Dead Boot Repair
Bricked phone symptoms:
  • can't power on after flash,
  • no lcd or led reaction for power button,
  • no lcd or led reaction for charger,
  • no lcd or led reaction if phone is connected to PC,
  • your PC can't detect your phone with vol-,
  • phone does not vibrate when holding vol+ and power together.
Repair steps:
Test mode point Posted By NikkyM
Firstly connect turned off bricked phone to your PC. If phone will be detected in device manager as:
qhusb_dload device
You are lucky and this is the end of the first step for you. Just disconnect phone.
If your phone can't be detected at all, you must find testpoint. Disassemble your phone
remove battery and connect each golden point on main board one by one to metal shield and attach usb cable. If your phone will be detected in device manager as flash device or something like that you've found testpoint. Don't forget to take a picture of main board and mark testpoint nd post here
Download All FilesHere
Download and run this s1tool:
Download boot firmware for your Sony Xperia SP (extract it from rar):
In S1tool choose S1 EMERGENCY mode, press Flash button, select Sony Xperia SP boot firmware .sin_file_set file,
Press Testpoint READY button
and if your phone is detected as qhusb_dload device, just attach usb cable. If not, perform all steps from point 3 (connect testpoint to GND and attach USB cable).
When drivers will be installed and phone will be detected, program will ask you to disconnect testpoint. Disconnect testpoint from GND and press Testpoint READY button.
After that phone will load emergency s1 loader, re-enumerate usb, load s1 loader and flash selected boot firmware.
Welcome to S1 tool.
ATTACH TESTPOINT
0808010600900000
162001000100
1801000F43240892D02F0DC96313C81351B40FD5029ED98FF9 EC7074DDAE8B05CDC8E1
PROCESSING ...
LOADER AID: 0001
DEVICE ID: 2078EB03
Processing package
C:\Users\Administrator\Desktop\S1Boot_R11B023_HWID 7E50E1.SIN_FILE_SET
FINISHED
Elapsed:29 secs.
After Repair Done Flash vit firmware.
Source:sony.yt
PLEASE DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
cant open link can you resend it sir
Old 10-13-2016, 15:25   #35 (permalink)
Member: 685001
Thanks Meter: 18
Repair steps:
qhusb_dload device
Welcome to S1 tool.
ATTACH TESTPOINT
0808010600900000
162001000100
PROCESSING ...
LOADER AID: 0001
DEVICE ID: 2078EB03
Processing package
FINISHED
Elapsed:29 secs.
Source:sony.yt
BUTTON
Sir i have sony experia Z japan
SO-02e
after flash this model piece gone in dead mode
No led No power No vibrate
qsusb loader error show
Sir kindley help me how to solve this problem
Old 01-06-2017, 15:06   #36 (permalink)
Member: 2246840
Thanks Meter: 3
Please Give me the flash file
Old 04-12-2017, 07:50   #37 (permalink)
Member: 1747434
Sonork: 5400
Thanks Meter: 13
Sony Xperia SP C5303 Dead After Flash
And
I am try to Boot repair by your Gsm forum solution
but next step how to solve ?
plz video guide need
Old 07-25-2017, 14:29   #38 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Repair steps:
qhusb_dload device
Welcome to S1 tool.
ATTACH TESTPOINT
0808010600900000
162001000100
PROCESSING ...
LOADER AID: 0001
DEVICE ID: 2078EB03
Processing package
FINISHED
Elapsed:29 secs.
Source:sony.yt
BUTTON
Link not work please upload again
The Following User Says Thank You to maxpro12 For This Useful Post:
Old 01-21-2018, 18:24   #39 (permalink)
Member: 483105
any working link. please
Old 04-17-2018, 03:53   #40 (permalink)
Member: 1343269
Thanks Meter: 21
please need a good link, and test point pic, thanks
Old 08-13-2018, 21:41   #41 (permalink)
Crazy Poster
Member: 325835
Thanks Meter: 8
link is broken, repost plssss
Old 03-17-2019, 16:05   #42 (permalink)
Member: 310418
Thanks Meter: 13
re...
no filef for xperia c5303... can anyone upload again ?
Old 09-17-2019, 00:01   #43 (permalink)
Member: 2504550
what do I need for connecting to test point? I mean how to connect to pc? special tool or box is needed?
Old 09-17-2019, 22:39   #44 (permalink)
Member: 2504550
Where are those test points and wondering for a video tutorial
Page generated in 0.32528 seconds with 8 queries
