Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
10-09-2013, 15:38 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Manama Bahrain
Member: 1344255 Status: Offline Sonork: 1659066 Thanks Meter: 131 | Sony Xperia ST23i Sony Logo only Done! Sony Xperia ST23i Sony Logo only Done! Status Sony Logo only Tools Flashtool ST23i-11.0.A.5.5 How to install firmware *Do not plug your phone to computer and charge it to 100%! *Go to settings and enable USB Debugging and Unknown Sources. 1. Download ftf from post above depending on model. 2. Install latest Sony PC Companion (needed for drivers). 3. Install latest Flashtool. 4. Go to (C://flashtool/drivers) and install driver file. 5. Copy ftf to (C://flashtool/firmwares) and delete other ftf files in there. 6. Open Flashtool. 7. Click on big lightning button. 8. Choose flashmode. 9. Choose correct ftf (left side), do not touch anything else and click ok. 10. Wait. 11. 1Image will show up on your computer - Turn off your phone. 12. Plug it in USB while holding vol- button. 13. Wait. 14. When flashing finished text appears unplug your phone and turn it on. * It may take a while to turn on (Don't panic). Logs Code: 08/039/2013 12:39:49 - INFO - <- This level is successfully initialized 08/039/2013 12:39:49 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00 08/039/2013 12:39:51 - INFO - Device connected in fastboot mode 08/039/2013 12:39:58 - INFO - Selected Sony Xperia Miro (Mesona) ST23i / 11.0.A.5.5 / Europe 08/039/2013 12:39:58 - INFO - Preparing files for flashing 08/040/2013 12:40:31 - INFO - Please connect your device into flashmode. 08/040/2013 12:40:42 - INFO - Device disconnected 08/040/2013 12:40:49 - INFO - Device connected in fastboot mode 08/041/2013 12:41:02 - INFO - Device disconnected 08/041/2013 12:41:11 - INFO - Device connected in flash mode 08/041/2013 12:41:12 - INFO - Opening device for R/W 08/041/2013 12:41:12 - INFO - Device connected in flash mode 08/041/2013 12:41:12 - INFO - Reading device information 08/041/2013 12:41:12 - INFO - Phone ready for flashmode operations. 08/041/2013 12:41:12 - INFO - Current device : ST23i - YT910062J7 - 1266-4437_R4D - 1261-5091_11.0.A.2.10 - WORLD-i_11.0.A.2.10 08/041/2013 12:41:13 - INFO - Start Flashing 08/041/2013 12:41:13 - INFO - Processing loader 08/041/2013 12:41:13 - INFO - Checking header 08/041/2013 12:41:13 - INFO - Flashing data 08/041/2013 12:41:15 - INFO - Loader : S1_Root_a8a4 - Version : R5D030 / Bootloader status : ROOTABLE 08/041/2013 12:41:15 - INFO - Disabling final data verification check 08/041/2013 12:41:15 - INFO - Processing partition-image.sin 08/041/2013 12:41:16 - INFO - Checking header 08/041/2013 12:41:16 - INFO - Flashing data 08/041/2013 12:41:16 - INFO - Processing kernel.sin 08/041/2013 12:41:16 - INFO - Checking header 08/041/2013 12:41:16 - INFO - Flashing data 08/041/2013 12:41:17 - INFO - Processing fota1.sin 08/041/2013 12:41:17 - INFO - Checking header 08/041/2013 12:41:17 - INFO - Flashing data 08/041/2013 12:41:17 - INFO - Processing fota0.sin 08/041/2013 12:41:17 - INFO - Checking header 08/041/2013 12:41:17 - INFO - Flashing data 08/041/2013 12:41:18 - INFO - Processing amss.sin 08/041/2013 12:41:18 - INFO - Checking header 08/041/2013 12:41:18 - INFO - Flashing data 08/041/2013 12:41:21 - INFO - Processing amss_fsg.sin 08/041/2013 12:41:21 - INFO - Checking header 08/041/2013 12:41:21 - INFO - Flashing data 08/041/2013 12:41:21 - INFO - Processing modem_fs2.sin 08/041/2013 12:41:21 - INFO - Checking header 08/041/2013 12:41:21 - INFO - Flashing data 08/041/2013 12:41:22 - INFO - Processing modem_fs1.sin 08/041/2013 12:41:22 - INFO - Checking header 08/041/2013 12:41:22 - INFO - Flashing data 08/041/2013 12:41:22 - INFO - Processing cache.sin 08/041/2013 12:41:22 - INFO - Checking header 08/041/2013 12:41:22 - INFO - Flashing data 08/041/2013 12:41:24 - INFO - Processing system.sin 08/041/2013 12:41:24 - INFO - Checking header 08/041/2013 12:41:24 - INFO - Flashing data 08/042/2013 12:42:58 - INFO - Processing userdata.sin 08/042/2013 12:42:58 - INFO - Checking header 08/042/2013 12:42:58 - INFO - Flashing data 08/043/2013 12:43:05 - INFO - Ending flash session 08/043/2013 12:43:05 - INFO - Flashing finished. 08/043/2013 12:43:05 - INFO - Please unplug and start your phone 08/043/2013 12:43:05 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 08/043/2013 12:43:06 - INFO - Device connected in flash mode 08/043/2013 12:43:47 - INFO - Device disconnected |
The Following 2 Users Say Thank You to fertxter For This Useful Post: |
12-08-2013, 11:36 | #3 (permalink) |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | |
02-19-2014, 05:43 | #5 (permalink) |
Freak Poster Join Date: Mar 2008 Location: kathmandu,nepal
Member: 729536 Status: Offline Sonork: [email protected] Thanks Meter: 13 | need St23I usb driver |
08-06-2014, 21:41 | #7 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Karachi,Pakistan
Member: 2216261 Status: Offline Sonork: 100.1651103 Thanks Meter: 96 | Please i Need Firmware ( 4shared / mediafire ) another not work |
The Following User Says Thank You to Shoaib.Khan For This Useful Post: |
