Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 11-07-2014, 20:17   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Sony Xperia Z C6602 / C6603 / C6606 / C6616 Dead Boot Repair
Bricked phone symptoms:
  • can't power on after flash,
  • no lcd or led reaction for power button,
  • no lcd or led reaction for charger,
  • no lcd or led reaction if phone is connected to PC,
  • your PC can't detect your phone with vol-,
  • phone does not vibrate when holding vol+ and power together.
Download and run this s1tool: Download
Download Boot repair File Here
Test point Image For C6602
Note : For Other models find test point nd post here
Repair procedure:
Firstly connect turned off bricked phone to your PC. If phone will be detected in device manager as
qhusb_dload device
you are lucky and this is the end of the first step for you. Just disconnect phone.
If your phone can't be detected at all, you must find testpoint. Disassemble your phone
remove battery and connect each golden point on main board one by one to metal shield and attach usb cable. If your phone will be detected in device manager as flash device or something like that you've found testpoint. Don't forget to take a picture of main board and mark testpoint nd post here
In S1tool choose S1 EMERGENCY MODE, press Flash button, select correct APPSW .sin_file_set file (or you can select whole firmware if you have it in order APPSW, FSP, Elabel .
Press Testpoint READY button
and if your phone is detected as qhusb_dload device, just attach usb cable. If not, perform all steps from point 1 (connect testpoint to GND and attach USB cable).
When drivers will be installed and phone will be detected, program will ask you to disconnect testpoint. Disconnect testpoint from GND and press Testpoint READY button.
After that phone will load emergency s1 loader, re-enumerate usb, load s1 loader, update boot in your phone and flash selected firmware.
After done flash vit full firmware using Fastboot
Credits goes to :juriji
Source: Sony.yt
DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
The Following 33 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-08-2014, 12:50   #2 (permalink)
Member: 210589
Sonork: 100.1624235
Thanks Meter: 21
what about xperia z(L36H)
The Following User Says Thank You to ashishkama For This Useful Post:
Old 11-08-2014, 12:54   #3 (permalink)
Member: 210589
Sonork: 100.1624235
Thanks Meter: 21
Welcome to S1 tool.
That is small and crippled subset of SETOOL2 service tool.
SELECT FIRMWARE PACKAGES
YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON
CHECKING PACKAGES ...
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
PROCEDURE STOPPED BY USER
Elapsed:78 secs.
TO CONNECT NEXT PHONES
X10 Xperia,E10 Mini,E15 Xperia X8,U20 Mini Pro
LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY
PRESS AND HOLD "BACK" BUTTON...
ST18 Xperia RAY,ST15 Xperia Mini,SK17 Xperia Mini Pro
and Sony Xperia phone
PRESS AND HOLD "Volume Down" BUTTON...
PLEASE ATTACH TURNED OFF PHONE NOW
Waiting for phone ...
supported phone was not detected
Elapsed:97 secs.
ATTACH TESTPOINT
Elapsed:62 secs.
ATTACH TESTPOINT
Elapsed:37 secs.
Elapsed:0 secs.
Elapsed:114 secs.
ATTACH TESTPOINT
will use DLOAD protocol ...
0808010600900000
0D0F50424C5F446C6F6164564552322E30
162000000000
17004000000000E1907100
180100CC3153A80293939B90D02D3BF8B23E0292E452FEF662 C74998421ADAD42A380F
PHONE NOT SUPPORTED IN THIS MODE
Elapsed:48 secs.
ATTACH TESTPOINT
Elapsed:284 secs.
GETTING THIS ERROR
Old 11-08-2014, 15:19   #4 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Xperia z C6602 & L26H Same only
yur mob not detected by pc install tis driver Download
here
Try test point method if drivers detected as
SEMC Flash Device yu can flash the boot files
Old 11-12-2014, 06:42   #5 (permalink)
Member: 1595163
Thanks Meter: 51
[QUOTE=jamesjerss;10664325]
Sony Xperia C2105 dead boot please detect as qcomdevice 900080
Old 11-12-2014, 07:30   #6 (permalink)
Member: 779950
Thanks Meter: 153
Bro need help for lt30i(xperia T) dead boot repair...
Br...
The Following User Says Thank You to AAJETH For This Useful Post:
Old 11-12-2014, 16:23   #7 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Br...
Note : This method vil not work on al chipset devices
Some chipsets oly tested MSM8974,MSM8960,MSM8274
If yu wanna give a try 1st find test point above mentioned how to find it
flash vit below given file
Xperia_L_C2105_S1 _BOOT_FILE
or boot repair using supported jtag boxes
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 11-21-2014, 09:30   #8 (permalink)
Member: 70361
Thanks Meter: 20
@jamesjerss
is there any possibility to find test point for xperia m C190x C200x (4&5) i'll provide you pictures of mainboard , and what happen when i activate tespoint , i try all point in mainboard but i dont know what changes are made , the phone is qdload state at the first time.
Old 11-21-2014, 11:31   #9 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Originally Posted by rafik23 View Post
@jamesjerss
You can find test point yur self connect each golden point on main board one by one to metal shield and attach usb cable If driver detected in device manger as flash device or something like that you've found testpoint.
Wen yu short the test point yur mob go into emergency mode
Driver vil detect n others device if not installed yu can manually update.
After that yu can flash Boot files or full firmwares using s1 tool.
But not supported all devices yu can try Yu can use setool flash files
james
Old 11-21-2014, 22:15   #10 (permalink)
Member: 70361
Thanks Meter: 20
is this correct ?
after searching a lot of couple hours and tries, i think finding test point for xperia m just to confirm by experts !!!!
after connecting test point and gnd the green led light on for 2 second and s1tool detect VID_0FCE&PID_D18E and switch back to ZEUS Flash device.
is this the symptom for the testpoint !???
i dont know never use testpoint ....
Old 11-22-2014, 09:33   #11 (permalink)
Member: 70361
Thanks Meter: 20
The Following User Says Thank You to rafik23 For This Useful Post:
Old 11-22-2014, 12:42   #12 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Yes seems lik yu found the test point
Now try vit s1 tool
Connecting in Testmode Look the s1 tool screen shot there yu can se how to cnnt it
james
Old 11-22-2014, 14:30   #13 (permalink)
Member: 70361
Thanks Meter: 20
21/11/2014 18:01:52 DETACH USB CABLE FROM PHONE
21/11/2014 18:01:52 REMOVE BATTERY FROM PHONE
21/11/2014 18:01:52 ATTACH TESTPOINT
21/11/2014 18:01:52 PRESS "READY", THEN ATTACH USB CABLE TO PHONE
21/11/2014 18:01:52
21/11/2014 18:02:07 llbug: [\\?\USB#VID_0FCE&PID_D18E#8&1561cb62&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: "Un périphérique attaché au système ne fonctionne pas correctement"
it detected as VID_0FCE&PID_D18E but after two second it return to ZEUS flash device
but when it try to install driver for VID_0FCE&PID_D18E and be used by PC the green led take a long time and VID_0FCE&PID_D18E disconnect after 10 or 20 second while it' used by PC ( trying install drivers) , i think the s1tool what i'm using dont accept xperia m release 08.07.2014
Old 11-22-2014, 15:03   #14 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Yes as i mention before not support all devices
Check this yur mob gng into fastboot mode or not hold vol up nd cnnt USB
james
Old 11-22-2014, 15:25   #15 (permalink)
Member: 70361
Thanks Meter: 20
james
there is no fastboot mode no flashmode only qhsusb dload
the mob hard bricked
Page generated in 0.28172 seconds with 9 queries
