Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 11-11-2015, 10:20   #46 (permalink)
md_amin's Avatar
Member: 1217931
Sonork: 100.1604251
Thanks Meter: 267
D2303 M2 Dead Boot Repiar add Pls
Old 11-29-2015, 05:47   #47 (permalink)
MobileCarein's Avatar
Member: 2217517
Sonork: 1660095
Thanks Meter: 24
Welcome to S1 tool.
That is small and crippled subset of SETOOL2 service tool.
SELECT FIRMWARE PACKAGES
YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON
CHECKING PACKAGES ...
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
will use DLOAD protocol ...
0808010600900000
0D0F50424C5F446C6F6164564552322E30
162001000100
17004001000100E1907100
1801001EA8B0C1B209C88CBB3E220F0AC00F6E6520A273D516 B40E7F2EAEB0E5B3DB8B
PHONE NOT SUPPORTED IN THIS MODE
Elapsed:59 secs.
bro no one has answered about this problem
Old 12-02-2015, 11:52   #48 (permalink)
palash_c6's Avatar
Member: 650840
Thanks Meter: 622
Badly need d6616 testpoint image
Old 12-21-2015, 05:44   #49 (permalink)
Member: 2500193
xperia z3v is not supported. what can i do?
Old 01-11-2016, 16:07   #50 (permalink)
Member: 2511098
Thanks Meter: 41
Hi guys i just fixed my sony experia z 6603 and wanted to share the way i did it
after a tried the test point linking them to the metalic shell and to the sd card reader matall part , while connecting the USB cable eachtime the pc didnt reconze my phone , so i put the back cover on ant connected my hpne to the pc (USB 3.0 prt) ,i let it that way for like 30 minutes, meanwhile i was on facebook sudenly i reard the plugnin device sound playing a few seconds later the sony logo showed then the red battery charging logo showerd i let my phone charge for a while on my pc then i turned it on and now its working fine.
try it it may work with u too
Old 03-26-2016, 10:03   #51 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
Thanks Meter: 737
c6606 testpoint needed
Old 04-28-2016, 23:28   #52 (permalink)
Member: 310418
Thanks Meter: 13
any one , here is c6603 i hope with no bot onlu sony logo and black ;(
Old 04-29-2016, 10:27   #53 (permalink)
Member: 310418
Thanks Meter: 13
setool log
RUNNING v 1.1424/01.14/UNI
CARD SERIAL 000816xx
CFG:000000000000
PROCEDURE WAS STOPPED BY USER
FAILED TO SETUP PHONE
Elapsed: 39 seconds
SIGNED MODE (USING SERVER)
CFG:101000000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
RUNNING S1_BOOT VER "S1_Boot_Lagan_1.1.1_1"
ACTIVE_COMP_AID : 0001
HWCONF_AID : 0001
LOADER_AID : 0001
BOOT_AID : 0001
[ llcomm: 00080000,00008000 ]
DEVICE ID: 047E53E2
FLASH ID: "0015/01000004"
LOADER VERSION: "APQ8064_39"
PHONE IMEI : 35576205580346
writing "C:\Documents and Settings\******z Lamparski\Moje dokumenty\Pobrane\10_7_A_0_222.FSP_Yuga_GLOBAL_LTE _1270_8442_S1_SW_ ...
Processing package
10_7_A_0_222.FSP_Yuga_GLOBAL_LTE_1270_8442_S1_SW_L IVE_5CA3_PID1_0002_MMC.R6E.SIN_FILE_SET
Testing package integrity ...
PROCESSING: userdata_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin
PROCESSING: system_S1-SW-LIVE-5CA3-PID1-0002-MMC.sin
PROCESSING: amss_fs_1_S1-MODEMSW-LIVE-5CA3-PID1-0002-MMC.sin
PROCESSING: amss_fs_2_S1-MODEMSW-LIVE-5CA3-PID1-0002-MMC.sin
PROCESSING: amss_fs_3_S1-MODEMSW-LIVE-5CA3-PID1-0002-MMC.sin
Processing UPDATE files
SKIP: simlock.ta
PROCESSING: cust-reset.ta
Writing TA unit 0002/08A4/000E
writing "C:\Documents and Settings\******z Lamparski\Moje dokumenty\Pobrane\R7A.MS_CDF_1270_2726.SIN_FILE_SE T"
Processing package
R7A.MS_CDF_1270_2726.SIN_FILE_SET
PROCESSING: memorystick_red.sin
Elapsed: 449 seconds
CFG:101000000000
HWCONF_AID : 0001
LOADER_AID : 0001
BOOT_AID : 0001
DEVICE ID: 047E53E2
ANDROID LOCK RESET
Unlock DONE
Elapsed: 11 seconds
Old 04-30-2016, 15:33   #54 (permalink)
Member: 1142388
Sonork: 100.1617280
Thanks Meter: 85
sony c6806 after flash my phone is dead need repair guide and file
plase help me argent
br,
gsm_uzzal
Old 05-11-2016, 10:28   #55 (permalink)
Member: 1712884
Thanks Meter: 857
Exclamation c6603 need help
hello
my phone only zeus flash device driver after conect to pc
please help me (upload good driver for me too install)
thanks
Old 06-18-2016, 10:58   #56 (permalink)
Kwesi_Roy_GH's Avatar
Member: 2575234
Thanks Meter: 1,134
Can this phone be network unlocked with setool using this test point method?
Old 07-07-2016, 09:36   #57 (permalink)
chlakh11787's Avatar
Member: 378892
Thanks Meter: 51
Zeus flash device
Originally Posted by Moh3en.pc View Post
hello
thanks
Hay (Zeus flash device driver) is driver for zte smartphone plus reinstall driver flash mode for sony
Old 08-14-2016, 13:29   #58 (permalink)
Member: 1971704
Thanks Meter: 11
Question sony E5363 dead
sony E5363 dead
Can anybody help to DEAD boot repair of SONY E5363
and if possible TEST POINT image
Old 10-13-2016, 16:34   #59 (permalink)
Member: 685001
Thanks Meter: 18
Sir i have sony experia Z japan
SO-02e
after flash this model piece gone in dead mode
No led No power No vibrate
qsusb loader error show
Sir kindley help me how to solve this problem
Old 10-14-2016, 12:10   #60 (permalink)
Member: 685001
Thanks Meter: 18
Sir plz give me SO-02E file
Page generated in 0.25601 seconds with 10 queries
