Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 11-06-2014, 14:39   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,324
Sony Xperia Z1 C6902 / C6903 Dead Boot Repair
SonyXperiaZ1C6902 / C6903DeadBoot Repair
Bricked phone symptoms:
  • can't power on after flash,
  • no lcd or led reaction for power button,
  • no lcd or led reaction for charger,
  • no lcd or led reaction if phone is connected to PC,
  • your PC can't detect your phone with vol-,
  • phone does not vibrate when holding vol+ and power together.
Download and run this s1tool: Download
Download Boot repair FileHere
Test point Image
In S1tool choose MSM8974 emergency mode, press Flash button, select correct APPSW .sin_file_set file
Press Testpoint Ready button
If your phone is in emergency mode just attach usb cable. If not perform all steps again (connect testpoint to GND and attach USB cable)
When drivers will be installed and phone will be detected, program will ask you to disconnect testpoint. If your phone is in emergency mode, just press Testpoint READY button. If no, disconnect testpoint from GND and press Testpoint READY button.
After that phone will load emergency s1 loader, re-enumerate usb, load s1 loader, update boot in your phone and flash selected firmware. When it's done and you have flashed all firmware parts (APPSW, FSP, ELABEL), phone will be fixed. If not, you must reflash it fully with Sony Update Service, Sony PC Companion or any other flasher like current Flashtool version
Note : if yu see Hardware id :xxxxxxxxxxx not supported
Credits : Juriji
Source:Sony.yt
DON'T SAY THANKSJUST PRESS BUTTON
BUTTON
The Following 37 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-13-2014, 02:56   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 694
plz pic test poin cabel i have no cabel i want see how image this cabel
Old 11-13-2014, 08:49   #3 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,324
You don't need any special cable, just short the test point to ground and connect with normal usb . If all goes well Driver will be detected.
Old 11-22-2014, 17:45   #4 (permalink)
Member: 1642247
I have made a tool for converting TA.img (raw ta partition backup) to s1tool flash format aka SYN_FILE_SET, enjoy if you find tool useful! Link -> DOWNLOAD
The Following User Says Thank You to cardsharing For This Useful Post:
Old 11-29-2014, 02:37   #5 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
when i wish to boot repair my c6902 it gives me that error
what mistake i do ?
any idea about that?
i think its drivers problem .if i am correct then please share correct drivers for me
Old 11-29-2014, 02:56   #6 (permalink)
ms phone's Avatar
Member: 1119242
Sonork: 100.1638541
Thanks Meter: 108
what mistake i do ?
your phone not in emergency download
in dektop manager zeus flash detectd
The Following User Says Thank You to ms phone For This Useful Post:
Old 11-29-2014, 12:06   #7 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
how to see this device in device manager to identify that drivers are properly installed or not ..and to make sure that tp is properly not connected..
The Following User Says Thank You to MYUNLOCKING For This Useful Post:
Old 11-29-2014, 12:08   #8 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,481
To work with this tool,device should make ZEUS device,but windows7 mostly take this driver as qualcomm,so if in device manager your device detect as qualcomm,uninstall your device and install ZEUS driver.
Old 12-01-2014, 13:35   #9 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
can you tell me where to uninstall this device from device manager?
i cant seen in ports and in usb devices tab in device manager
where it was?
Old 12-01-2014, 13:54   #10 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
also share drivers for this device please
Old 12-01-2014, 14:42   #11 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,324
where it was?
1st connect testpoint to GND and attach USB cable if any driver detected yur device must b n emergency mode nd yu can se driver detected n device manager .
james
Old 12-01-2014, 15:36   #12 (permalink)
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
all done but device not shown in device manager.. and this error occurs..
i was try to another fresh pc but ig requires usb drivers
can some one share it please?
Old 12-03-2014, 01:09   #13 (permalink)
Member: 74135
Thanks Meter: 8
pls help me to understand about emergency mode, is the phone on or off when plug usb cable?
Old 12-03-2014, 01:45   #14 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 503
where we can download the other boot files like lt15?
Old 12-03-2014, 09:09   #15 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,426
[GUIDE] Z Ultra and Z1 HARD BRICK RECOVERY
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Page generated in 0.35013 seconds with 7 queries
