Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 12-23-2015, 09:42   #46 (permalink)
Member: 2500193
i can't find the testpiont with my xperia z3v(d6708)...
Old 02-22-2016, 15:43   #47 (permalink)
Member: 1456426
Sonork: 100.1625000
Thanks Meter: 104
jamesjerss any idia
Old 04-22-2016, 18:45   #48 (permalink)
Member: 1101680
sony d6603 boot repair
how to dead boot repair sony d6603 boot repair
i want this file Xperia C6602 & C6603 Dead Boot Repair File.rar
Old 04-22-2016, 20:46   #49 (permalink)
Member: 1510211
Thanks Meter: 17
Somebody can tell me what is the GND in this phone?
Old 04-23-2016, 05:01   #50 (permalink)
Member: 1510211
Thanks Meter: 17
I have this problems:
SELECT FIRMWARE PACKAGES
YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON
CHECKING PACKAGES ...
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
will use Sahara protocol ...
REMOVE TESTPOINT NOW, THEN PRESS "READY"
PROCESSING ...
SERIAL NUMBER : C24AF405
HARDWARE ID 00000000E1007B00 NOT SUPPORTED
HARDWARE ID : 00000000E1007B00
NOT SUPPORTED HASH :CC3153A80293939B90D02D3BF8B23E0292E452FEF662C7499 8421ADAD42A380F
Elapsed:31 secs.
Old 04-26-2016, 13:47   #51 (permalink)
Member: 2560266
I need to repair my dead Xperia z1 comact. No boot. Black screen with red led
Old 05-05-2016, 16:54   #52 (permalink)
Member: 102849
Solution is here
THIS THERAD
Old 05-18-2016, 09:11   #53 (permalink)
Member: 2417044
Thanks Meter: 95
D6603 Dead After Flash By Sony ftf Flash tool
Flash fully complete
But Device still off and no response
sometimes only Connect With pc a Boot Repair Driver
Kindly Can You Help me??
I need Your Valuable Help
Thanks i Advance
Old 08-04-2016, 12:55   #54 (permalink)
ssatcom's Avatar
Member: 17098
Thanks Meter: 51
SIGNED MODE (USING SERVER)
CFG:100000000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
llbug: [] open error: "The system cannot find the path specified"
FAILED TO SETUP PHONE
Elapsed: 11 secs.
Old 01-28-2017, 16:35   #55 (permalink)
Member: 1987780
Sonork: 100.1668635
Thanks Meter: 7
ATTACH TESTPOINT
PROCESSING ...
SERIAL NUMBER : 7FA0D105
HARDWARE ID 00000000E1107B00 NOT SUPPORTED
HARDWARE ID : 00000000E1107B00
Elapsed:13 secs.
Old 01-30-2017, 13:45   #56 (permalink)
Member: 2678914
Sonork: DOU
I have solution qhsusb_bulk it no dead boot
you must keep the volum+ and power only 30sec
after reflas it
the problem solved
Old 08-28-2017, 19:10   #57 (permalink)
Member: 2702587
Sonork: 1680225
Thanks Meter: 25
sony xperia z1s c6916 flash after dead please solution
Page generated in 0.30465 seconds with 7 queries
