Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 04-19-2013, 22:39   #1 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 247
Question st21i Tipo - Emergency mode. Invalid sim. No network.
Main problem with this phone is just one and only:
There is no network.
Only emergency mode. Invalid sim.
When i try to manual register on network says:
Your SIM does not allow to be registered with this network.
But Phone before was not locked and used to work fine with all simcards.
By the way, phone does not asks for network code.
So just to be clear: It is not locked.
This happend after changing a few custom roms.
Things that are already done to solve this problem are:
-Flashed boot with Octoplus.
-Flashed firmware with SeTool2
-Flashed Firmware with Flashtool
-Flashed Firmware with Octoplus suite
-Repair TA with Octoplus suite
i am out of options.
btw,
I need to relock bootloader on Sony Tipo ST21i to be able to flash back to stock,
and everything that i find on net for this purpose is guide below,
but this guide doesn't seems to work with mine st21i. Error occured.
How to relock bootloader on ST21i ?
a) download latest XPERIA Flashtool from here
b) install it somewhere to you computer
c) download these file and and paste it to folder „Firmware“ included in the XPERIA Flashtool
d) open the Flashtool, click on Flash, mark relock ftf file and click on ok
e) turn off your phone, and when Flashtool shows pop up window, connect phone to PC with holding volume down button
f) after few seconds is your bootloader locked again, as a next step you have to update your firmware via Sony Update Service
The Following User Says Thank You to unlock.mk For This Useful Post:
Old 04-21-2013, 12:59   #2 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 247
Bump, anyone has had this problem, or can help here ?
Old 04-22-2013, 09:16   #3 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 247
Anyone has idea about first post problem ?
Old 08-03-2013, 08:28   #4 (permalink)
Member: 1555770
Sonork: 1603764
Thanks Meter: 5
we have same issue after entering network code no network
Old 10-17-2013, 10:33   #5 (permalink)
Member: 1409328
xperia tipo no network after entering unloock code
anyone have idea ?
am also have same problem.
Old 10-27-2013, 14:04   #6 (permalink)
Member: 704971
Thanks Meter: 4
i think its sim ways problem .mine ex was same as above but the phone says insert sim.anybody have sim ways plz rep.or if its softwere prob then help.
Old 11-05-2013, 01:15   #7 (permalink)
kammy6000's Avatar
Member: 467279
Thanks Meter: 42
You have corrupted your radio modules
relock the boot and try official sony pc suite to repair
Old 01-06-2014, 06:53   #8 (permalink)
Member: 867234
Thanks Meter: 7
sony st21i no sim problem. please need sim way circuit
Old 04-08-2014, 12:30   #9 (permalink)
Member: 2088075
Thanks Meter: 49
sony t21i pattern lock ...
Old 06-04-2014, 17:23   #10 (permalink)
Member: 1396837
Sonork: 100.1657369
Thanks Meter: 17
Smile
btw,
Sony st21 have two options
firmware file separately
st21i2 xperia tipo dual
st21 xperia tipo
Old 07-16-2014, 09:57   #11 (permalink)
teletalk's Avatar
Member: 926215
Sonork: 100.1650776
Thanks Meter: 95
i have sony xperia tipo dual sim phone and in this phone have a 1 problem that dual sim option is not click able and i try to put only sim 1 ......phone work great and if put only sim 2 ,,,,,, phone work good but when both sim is available in the phone the sim 2 option is not showing
well i try many time to flashing with flashtool but no success and diffrent firmware also but no success after that i try to update with sony update
service and phone is update very well but the sim 2 is not work i think may be this situation is creat by me using this code *#*#7378423#*#*
MY SONY TIPO DUAL ST21I2 SHOWS THIS
[X] NETWORK 0
[X] NETWORK SUBNET 0
[X] SERVICE PROVIDER 0
[X] CORPORATE 0
[X] SIM 0
this phone is working nicely since 1 year but this is accidentally lock and i confused with this problem please help me
Old 07-25-2014, 07:56   #12 (permalink)
selvam1155's Avatar
Member: 1644200
Thanks Meter: 51
first confirme model st21i or st21i2
Old 07-25-2014, 08:18   #13 (permalink)
Member: 1494304
Sonork: 100.1606186
Thanks Meter: 108
i have encounter same problem
st21i flash the phone with st21i2_xperia_tipo_dual...phone alive but it shows invalid
the i try to flash again with st21_xperia_tipo, all are working fine, imei is back
just download st21 on setool support
goodluck
Old 08-26-2014, 11:17   #14 (permalink)
teletalk's Avatar
Member: 926215
Sonork: 100.1650776
Thanks Meter: 95
i try all possible attempts like flashing with different type of firmwares and original also and relock boot loader and than update with Sony update service but no result so if any one have any idea please share...............
Old 08-30-2014, 14:42   #15 (permalink)
joseck's Avatar
Member: 648607
Sonork: 100.1638674
Thanks Meter: 23
mine solved ,software problem......
Page generated in 0.25729 seconds with 9 queries
