Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
04-19-2013, 22:39 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | st21i Tipo - Emergency mode. Invalid sim. No network. There is no network. Only emergency mode. Invalid sim. When i try to manual register on network says: Your SIM does not allow to be registered with this network. But Phone before was not locked and used to work fine with all simcards. By the way, phone does not asks for network code. So just to be clear: It is not locked. This happend after changing a few custom roms. Things that are already done to solve this problem are: -Flashed boot with Octoplus. -Flashed firmware with SeTool2 -Flashed Firmware with Flashtool -Flashed Firmware with Octoplus suite -Repair TA with Octoplus suite i am out of options. btw, I need to relock bootloader on Sony Tipo ST21i to be able to flash back to stock, and everything that i find on net for this purpose is guide below, but this guide doesn't seems to work with mine st21i. Error occured. How to relock bootloader on ST21i ? a) download latest XPERIA Flashtool from here b) install it somewhere to you computer c) download these file and and paste it to folder „Firmware“ included in the XPERIA Flashtool d) open the Flashtool, click on Flash, mark relock ftf file and click on ok e) turn off your phone, and when Flashtool shows pop up window, connect phone to PC with holding volume down button f) after few seconds is your bootloader locked again, as a next step you have to update your firmware via Sony Update Service |
The Following User Says Thank You to unlock.mk For This Useful Post: |
01-06-2014, 06:53 | #8 (permalink) |
Junior Member Join Date: Sep 2008 Location: karaikudi
Member: 867234 Status: Offline Sonork: [email protected] Thanks Meter: 7 | sony st21i no sim problem. please need sim way circuit |
06-04-2014, 17:23 | #10 (permalink) | |
Freak Poster Join Date: Sep 2010 Location: Uzbekistan/Namangan/Sardoba
Member: 1396837 Status: Offline Sonork: 100.1657369 Thanks Meter: 17 | Quote:
Sony st21 have two options firmware file separately st21i2 xperia tipo dual st21 xperia tipo | |
07-16-2014, 09:57 | #11 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | i have sony xperia tipo dual sim phone and in this phone have a 1 problem that dual sim option is not click able and i try to put only sim 1 ......phone work great and if put only sim 2 ,,,,,, phone work good but when both sim is available in the phone the sim 2 option is not showing well i try many time to flashing with flashtool but no success and diffrent firmware also but no success after that i try to update with sony update service and phone is update very well but the sim 2 is not work i think may be this situation is creat by me using this code *#*#7378423#*#* MY SONY TIPO DUAL ST21I2 SHOWS THIS [X] NETWORK 0 [X] NETWORK SUBNET 0 [X] SERVICE PROVIDER 0 [X] CORPORATE 0 [X] SIM 0 this phone is working nicely since 1 year but this is accidentally lock and i confused with this problem please help me |
07-25-2014, 08:18 | #13 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Philippines
Member: 1494304 Status: Offline Sonork: 100.1606186 Thanks Meter: 108 | i have encounter same problem st21i flash the phone with st21i2_xperia_tipo_dual...phone alive but it shows invalid the i try to flash again with st21_xperia_tipo, all are working fine, imei is back just download st21 on setool support goodluck |
08-26-2014, 11:17 | #14 (permalink) |
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | i try all possible attempts like flashing with different type of firmwares and original also and relock boot loader and than update with Sony update service but no result so if any one have any idea please share............... |
