Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 09-13-2013, 21:12   #1 (permalink)
The_Rasmus's Avatar
Member: 1792564
Thanks Meter: 109
[TOOL] Backup TA v9.7 for Windows [20130818]
Backup TA can backup and restore the TA partition of the device. When you create a backup before unlocking for the first time, then you will be able to restore to full factory state (including a locked bootloader). This means all DRM keys intact, Bravia Engine working in Album and last but not least your warranty when needed .
READ: At the bottom of this post is the FAQ. Here you will find answers on the most asked questions. Read them before posting any question in this thread. When you post a question which is already answered in the FAQ, I will ignore you and smile .
Also when you want my support, tell me which device and version of Backup TA you're using and attach the complete output. I can not help you without this and besides it's really not so much to ask in return, now is it? No effort without effort.
This tool only works under Windows. Mac and Linux will not be supported. Using this tool is at your own risk.
Download
Changelog
Source (released under MIT license)
Stable releases do have a version tag like this: v1.0 (example)
Beta releases do have a version tag like this: v1.0b2 (example).
SUPPORTED DEVICES
Confirmed:
Sony Xperia Z Ultra
Sony Xperia Z
Sony Xperia ZL
Sony Xperia ZQ
Sony Xperia ZR
Sony Xperia ION
Sony Xperia S
Sony Xperia SL
Sony Xperia SP
Sony Xperia Acro S
Sony Xperia T
Sony Xperia TL
Sony Xperia TX
Sony Xperia M
Sony Xperia V
Sony Xperia P
Sony Xperia L
Sony Xperia U
Sony Xperia Sola
Sony Xperia Miro
Sony Xperia Tipo
Sony Xperia J
Sony Xperia E
Sony Xperia Tablet Z
Most likely:
All Sony Xperia models
Not supported:
All Sony Ericsson Xperia models
GUIDE
1. Download the latest version of Backup TA.
2. Extract the ZIP file to a folder location of your choosing.
3. Navigate to the folder location of Backup TA.
4. Make sure no other script or application which is using ADB is running.
5. Make sure the device is booted in normal mode, the way you normally use it.
6. Run Backup-TA.bat
7. Read the license.
8. Choose one of the menu options.
9. Follow the instructions given by the tool.
FAQ
Q: Is my device supported?
A: Look at the supported devices list above this FAQ. When it is not listed, try to make a backup it will tell you if your device is supported.
Q: Do I need root for this?
A: Yes, you do need root for this to work.
Q: Can I use someone else's backup?
A: No, this will hard-brick your device.
Q: Does it bring back my DRM keys when I already unlocked my device?
A: Not without a backup of the TA before it was ever unlocked.
Q: Can I restore my TA while running a non-stock ROM or kernel?
A: Yes, but it will soft-brick your device and you need Sony PC Companion or Flashtool to fix it by flashing stock firmware. Best is to first return to a complete stock ROM and kernel before restoring the TA.
Q: Will a restore relock the bootloader?
A: Yes, it will relock the bootloader like it was never unlocked.
Q: What is 'restore dry-run'?
A: When you do a dry-run restore it will performs a regular restore with the exception that it will not write anything to your device. This is helpful to test a backup before restoring and very advisable.
The Following 6 Users Say Thank You to The_Rasmus For This Useful Post:
Old 06-07-2014, 15:15   #2 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 39
i had problem with xperia z c6602 baseband unknown and imei blank
i try to restore other one xperia z ta file..
now phone black...cant flash....
flashtool "Reading device information" stuck
Can you please help me
Old 06-19-2014, 07:33   #3 (permalink)
Member: 693055
Thanks Meter: 14
i am also fatching same problem i got the solution sony.yt/topic/7324-english-tutorial-how-to-unbrick-and-update-boot-in-sony-xperia-z-c6602-c6603-c6606-c6616/Hello,
but i dont know where is test point of the C6602 Please try this method to unbrick u r xperia z and also inform me here.
Thanks & Regards
Old 06-19-2014, 15:41   #4 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 39
thank you.....
cant download file..
Old 06-20-2014, 12:20   #5 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 39
Also Can't find testpoint
Sent from my iPhone using Tapatalk
Old 06-20-2014, 12:39   #6 (permalink)
Member: 2207379
Thanks Meter: 4
thank you.....
Why you can't dowload? i can dowload it, choose v9.11 and zip file.
Have fun!
Old 06-20-2014, 13:58   #7 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 39
can u show me c6602 testpoint?
Old 06-23-2014, 06:51   #8 (permalink)
Member: 2209430
Can you some screenshot sir for this?
Old 06-23-2014, 15:12   #9 (permalink)
rubymunna's Avatar
Member: 550683
Sonork: 100.1649601
Thanks Meter: 39
Old 12-26-2014, 10:55   #10 (permalink)
mike_shinoda's Avatar
Member: 2136780
Thanks Meter: 67
New Repair Packs By Babak Nuri
Old 07-12-2015, 22:01   #11 (permalink)
Member: 2309104
Thanks Meter: 5
don't work for my xperia m2
Old 08-15-2015, 22:02   #12 (permalink)
Member: 2444656
HI, my friends recently i bought an xpreia Z3 D6603 through internet and after i receive it i noticed that it cant get 4G network first i didnt know whats the problem because im in good coverage area, but after i check the phones info i surprised with the all Zeros imei, and now i dont know how to fix this. please help i really like this phone with his 20.7mp camera and his like-bravia-tv screen.
i've tried all "traditional methods", exept only imei repair or to be more precise "imei writing"
5$ paypal for the effective answer even if it contain a complicated repair process
thanks,
Old 10-17-2016, 13:37   #13 (permalink)
Member: 2189612
thank you.....
The Following User Says Thank You to eltiaar For This Useful Post:
Page generated in 0.33831 seconds with 7 queries
