Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
09-22-2014, 20:13 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,374 | Tutorial Create sony ftf flash files by yur own (firmware Downloader included) Tutorial Create sony ftf flash files by yur own Firmware Downloader 5.0.0 Note: uncheck unpack automatiacally Flash tool Download [/B][/SIZE][/COLOR] http://forum.gsmhosting.com/vbb/f778...htool-2445248/ Thread is closed since OP is no longer active New thread created with updated links Last edited by ~Leo~; 08-02-2018 at 21:30. |
The Following 45 Users Say Thank You to jamesjerss For This Useful Post: |
09-24-2014, 23:03 | #6 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1687437 Status: Offline Thanks Meter: 7 | 100% work this Tutorial with me i have attached the screenshot of my work 100% successful flash This Credit TO jamesjerss who made this Tutorial for us to make work easy Thanks alot Brother |
The Following User Says Thank You to murad312 For This Useful Post: |
09-26-2014, 14:16 | #7 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Athens
Member: 1020935 Status: Offline Sonork: 100.1604039 Thanks Meter: 28 | Hi jamesjerss Thanks for Reply i did try as you posted but i thing my phone in not connecting as flash mode 26/003/2014 16:03:26 - INFO - <- This level is successfully initialized 26/003/2014 16:03:26 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00 26/003/2014 16:03:31 - INFO - Device disconnected 26/003/2014 16:03:38 - INFO - Selected Xperia Z Ultra C6833 / 1276-0119_14.4.A.0.108 / 3 UK 26/003/2014 16:03:38 - INFO - Preparing files for flashing 26/005/2014 16:05:59 - INFO - Please connect your device into flashmode. 26/008/2014 16:08:20 - INFO - Device connected with USB debugging off 26/008/2014 16:08:20 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/008/2014 16:08:37 - INFO - Device disconnected 26/008/2014 16:08:38 - INFO - Device connected with USB debugging off 26/008/2014 16:08:38 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:05 - INFO - Device disconnected 26/009/2014 16:09:11 - INFO - Device connected with USB debugging off 26/009/2014 16:09:11 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:16 - INFO - Device disconnected 26/009/2014 16:09:17 - INFO - Device connected with USB debugging off 26/009/2014 16:09:17 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:25 - INFO - Device disconnected 26/009/2014 16:09:29 - INFO - Device connected with USB debugging off 26/009/2014 16:09:29 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:53 - INFO - Device disconnected 26/010/2014 16:10:00 - INFO - Device connected with USB debugging off 26/010/2014 16:10:00 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/010/2014 16:10:03 - INFO - Device disconnected 26/010/2014 16:10:07 - INFO - Device connected with USB debugging off 26/010/2014 16:10:07 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/010/2014 16:10:42 - INFO - Device disconnected 26/010/2014 16:10:50 - INFO - Device connected with USB debugging off 26/010/2014 16:10:50 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/010/2014 16:10:53 - INFO - Device disconnected 26/010/2014 16:10:54 - INFO - Device connected with USB debugging off 26/010/2014 16:10:54 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:03 - INFO - Device disconnected 26/011/2014 16:11:08 - INFO - Device connected with USB debugging off 26/011/2014 16:11:08 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:14 - INFO - Device disconnected 26/011/2014 16:11:15 - INFO - Device connected with USB debugging off 26/011/2014 16:11:15 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:21 - INFO - Device disconnected 26/011/2014 16:11:24 - INFO - Device connected with USB debugging off 26/011/2014 16:11:24 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:32 - INFO - Device disconnected 26/011/2014 16:11:37 - INFO - Device connected with USB debugging off 26/011/2014 16:11:37 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:47 - INFO - Flash canceled 26/012/2014 16:12:55 - INFO - Device disconnected 26/013/2014 16:13:10 - INFO - Device connected with USB debugging off 26/013/2014 16:13:10 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/013/2014 16:13:36 - INFO - Device disconnected |
The Following User Says Thank You to !!AS!! For This Useful Post: |
09-28-2014, 11:58 | #10 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,374 | |
The Following 3 Users Say Thank You to jamesjerss For This Useful Post: |
10-11-2014, 14:39 | #14 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,374 | Quote:
Sent from my GT-I9500 using Tapatalk | |
10-13-2014, 13:58 | #15 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1749874 Status: Offline Sonork: 100.1663210QQ:20249255921 Thanks Meter: 437 | Sony Xperia E3 Dual D2212 FTF Create Done 10000% working Br Sachin Patel |
The Following 4,294,967,295 Users Say Thank You to sachinpatel For This Useful Post: |
