Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 09-22-2014, 21:13   #1 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,067
Thumbs up Tutorial Create sony ftf flash files by yur own (firmware Downloader included)
Firmware Downloader 5.0.0
Note: uncheck unpack automatiacally
Flash tool Download
Video Tutorial Here
The Following 43 Users Say Thank You to jamesjerss For This Useful Post:
Old 09-22-2014, 23:36   #2 (permalink)
chandan_123's Avatar
Member: 801212
Sonork: 100.1657902
Thanks Meter: 642
can i flash downloded file via setool.
The Following User Says Thank You to chandan_123 For This Useful Post:
Old 09-23-2014, 00:05   #3 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,067
No better create vit tis tool nd flash via flash tool. To create ftf file oly take 5min.
The Following 2 Users Say Thank You to jamesjerss For This Useful Post:
Old 09-23-2014, 21:15   #4 (permalink)
Member: 1100311
Sonork: 100.1624110
Thanks Meter: 23
can i used octopus firmware in this tool
i try but not success
Old 09-23-2014, 23:18   #5 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,067
No post yur prob vit details . den i vil help yu to fix it
Old 09-25-2014, 00:03   #6 (permalink)
Member: 1687437
Thanks Meter: 6
100% work this Tutorial with me
i have attached the screenshot of my work
100% successful flash
This Credit TO jamesjerss who made this Tutorial for us to make work easy
Thanks alot Brother
File Type: jpg 10708422_528885820578516_206345743_n.jpg (39.6 KB, 758 views)
The Following User Says Thank You to murad312 For This Useful Post:
Old 09-26-2014, 15:16   #7 (permalink)
Member: 1020935
Sonork: 100.1604039
Thanks Meter: 26
Hi jamesjerss Thanks for Reply i did try as you posted but i thing my phone in not connecting as flash mode
26/003/2014 16:03:26 - INFO - <- This level is successfully initialized
26/003/2014 16:03:26 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00
26/003/2014 16:03:31 - INFO - Device disconnected
26/003/2014 16:03:38 - INFO - Selected Xperia Z Ultra C6833 / 1276-0119_14.4.A.0.108 / 3 UK
26/003/2014 16:03:38 - INFO - Preparing files for flashing
26/005/2014 16:05:59 - INFO - Please connect your device into flashmode.
26/008/2014 16:08:20 - INFO - Device connected with USB debugging off
26/008/2014 16:08:20 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/008/2014 16:08:37 - INFO - Device disconnected
26/008/2014 16:08:38 - INFO - Device connected with USB debugging off
26/008/2014 16:08:38 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/009/2014 16:09:05 - INFO - Device disconnected
26/009/2014 16:09:11 - INFO - Device connected with USB debugging off
26/009/2014 16:09:11 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/009/2014 16:09:16 - INFO - Device disconnected
26/009/2014 16:09:17 - INFO - Device connected with USB debugging off
26/009/2014 16:09:17 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/009/2014 16:09:25 - INFO - Device disconnected
26/009/2014 16:09:29 - INFO - Device connected with USB debugging off
26/009/2014 16:09:29 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/009/2014 16:09:53 - INFO - Device disconnected
26/010/2014 16:10:00 - INFO - Device connected with USB debugging off
26/010/2014 16:10:00 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/010/2014 16:10:03 - INFO - Device disconnected
26/010/2014 16:10:07 - INFO - Device connected with USB debugging off
26/010/2014 16:10:07 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/010/2014 16:10:42 - INFO - Device disconnected
26/010/2014 16:10:50 - INFO - Device connected with USB debugging off
26/010/2014 16:10:50 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/010/2014 16:10:53 - INFO - Device disconnected
26/010/2014 16:10:54 - INFO - Device connected with USB debugging off
26/010/2014 16:10:54 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/011/2014 16:11:03 - INFO - Device disconnected
26/011/2014 16:11:08 - INFO - Device connected with USB debugging off
26/011/2014 16:11:08 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/011/2014 16:11:14 - INFO - Device disconnected
26/011/2014 16:11:15 - INFO - Device connected with USB debugging off
26/011/2014 16:11:15 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/011/2014 16:11:21 - INFO - Device disconnected
26/011/2014 16:11:24 - INFO - Device connected with USB debugging off
26/011/2014 16:11:24 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/011/2014 16:11:32 - INFO - Device disconnected
26/011/2014 16:11:37 - INFO - Device connected with USB debugging off
26/011/2014 16:11:37 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/011/2014 16:11:47 - INFO - Flash canceled
26/012/2014 16:12:55 - INFO - Device disconnected
26/013/2014 16:13:10 - INFO - Device connected with USB debugging off
26/013/2014 16:13:10 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/013/2014 16:13:36 - INFO - Device disconnected
The Following User Says Thank You to !!AS!! For This Useful Post:
Old 09-27-2014, 23:51   #8 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,067
hmm den hard luck yur mob must b hard bricked
Old 09-28-2014, 07:43   #9 (permalink)
Member: 1910376
Thanks Meter: 41
bro tell me version off flash tool
Old 09-28-2014, 12:58   #10 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,067
In my post i used old version flashtool-0.9.13.0
New version
flashtool-0.9.18.1
The Following 3 Users Say Thank You to jamesjerss For This Useful Post:
Old 09-28-2014, 13:35   #11 (permalink)
Member: 1020935
Sonork: 100.1604039
Thanks Meter: 26
So there is no way to fix it ??
Old 09-28-2014, 13:42   #12 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,067
Did yu check yur battery .. if yur battery has no charge it vil not detect by pc.
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 10-11-2014, 15:35   #13 (permalink)
Member: 1734313
Sonork: 100.1620886
Thanks Meter: 55
@james bro...
pls guide me....
what is the main use of self making ftf files than already made ftf files.......
Old 10-11-2014, 15:39   #14 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,067
Originally Posted by mobirepair View Post
@james bro...
pls guide me....
selfmaking nd already made files are same oly . smbdy coverting to ftf nd uploading for public download nothing diff n files
Sent from my GT-I9500 using Tapatalk
Old 10-13-2014, 14:58   #15 (permalink)
sachinpatel's Avatar
Member: 1749874
Sonork: 100.1663210QQ:20249255921
Thanks Meter: 436
Sony Xperia E3 Dual D2212 FTF Create Done
10000% working
Sachin Patel
The Following 4,294,967,295 Users Say Thank You to sachinpatel For This Useful Post:
Page generated in 0.23083 seconds with 8 queries
