Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
12-12-2015, 15:24 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | what is this error sony c6603 with flash tool 12/001/2015 15:01:49 - INFO - No proxy found for IE. Trying next one 12/001/2015 15:01:49 - INFO - No proxy found for firefox. Trying next one 12/001/2015 15:01:49 - INFO - No proxy found for java. Trying next one 12/001/2015 15:01:49 - INFO - Syncing devices from github 12/001/2015 15:01:50 - INFO - Scanning devices folder for changes. 12/002/2015 15:02:00 - INFO - Pulling changes from github. 12/002/2015 15:02:01 - INFO - Devices sync finished. 12/002/2015 15:02:06 - INFO - Device disconnected 12/002/2015 15:02:23 - INFO - Selected Bundle for Sony Xperia Z (C6603). FW release : 10.7.A.0.222. Customization : UA 12/002/2015 15:02:23 - INFO - Preparing files for flashing 12/002/2015 15:02:28 - INFO - Please connect your device into flashmode. 12/021/2015 15:21:28 - INFO - Device connected in flash mode 12/021/2015 15:21:29 - INFO - Opening device for R/W 12/021/2015 15:21:29 - INFO - Reading device information 12/021/2015 15:21:29 - INFO - Phone ready for flashmode operations. 12/021/2015 15:21:29 - INFO - Opening TA partition 2 12/021/2015 15:21:29 - INFO - Current device : C6603 - YT9108KHN2 - 1270-5695_R2E - 1269-5309_10.7.A.0.222 - GLOBAL-LTE_10.7.A.0.222 12/021/2015 15:21:29 - INFO - Closing TA partition 12/021/2015 15:21:29 - INFO - Start Flashing 12/021/2015 15:21:29 - INFO - Processing loader.sin 12/021/2015 15:21:29 - INFO - Checking header 12/021/2015 15:21:29 - INFO - Flashing data 12/021/2015 15:21:29 - INFO - Loader : S1_Root_5ca3 - Version : APQ8064_39 / Boot version : S1_Boot_Lagan_1.1_10 / Bootloader status : ROOTABLE 12/021/2015 15:21:29 - INFO - Max packet size set to 512K 12/021/2015 15:21:30 - INFO - Making a TA backup 12/021/2015 15:21:30 - INFO - Opening TA partition 1 12/021/2015 15:21:30 - INFO - Start Dumping TA partition 1 12/021/2015 15:21:30 - INFO - Finished Dumping TA partition 1 12/021/2015 15:21:30 - INFO - TA partition 1 saved to C:\Users\kadersong\.flashTool\registeredDevices\YT 9108KHN2\s1ta\2015-12-12_03-21-30\1.ta 12/021/2015 15:21:30 - INFO - Closing TA partition 12/021/2015 15:21:30 - INFO - Opening TA partition 2 12/021/2015 15:21:30 - INFO - Start Dumping TA partition 2 12/021/2015 15:21:31 - INFO - Finished Dumping TA partition 2 12/021/2015 15:21:31 - INFO - TA partition 2 saved to C:\Users\kadersong\.flashTool\registeredDevices\YT 9108KHN2\s1ta\2015-12-12_03-21-30\2.ta 12/021/2015 15:21:31 - INFO - Closing TA partition 12/021/2015 15:21:31 - INFO - Parsing boot delivery 12/021/2015 15:21:31 - INFO - No flash script found. Using 0.9.18 flash engine 12/021/2015 15:21:31 - INFO - Opening TA partition 2 12/021/2015 15:21:31 - INFO - Writing TA unit 00002774. Value : [01] 12/021/2015 15:21:31 - INFO - Closing TA partition 12/021/2015 15:21:31 - INFO - Processing partition-image.sin 12/021/2015 15:21:31 - INFO - Checking header 12/021/2015 15:21:31 - INFO - Flashing data 12/021/2015 15:21:31 - INFO - Phone boot version : S1_Boot_Lagan_1.1_10. Boot delivery version : S1_Boot_Lagan_1.1_10 12/021/2015 15:21:31 - INFO - Boot delivery up to date. Nothing to do 12/021/2015 15:21:31 - INFO - Opening TA partition 2 12/021/2015 15:21:31 - INFO - Closing TA partition 12/021/2015 15:21:31 - INFO - Opening TA partition 2 12/021/2015 15:21:31 - INFO - Processing amss_fs_1.sin 12/021/2015 15:21:31 - INFO - Checking header 12/021/2015 15:21:31 - INFO - Flashing data 12/021/2015 15:21:31 - INFO - Processing amss_fs_2.sin 12/021/2015 15:21:31 - INFO - Checking header 12/021/2015 15:21:31 - INFO - Flashing data 12/021/2015 15:21:31 - INFO - Processing amss_fs_3.sin 12/021/2015 15:21:31 - INFO - Checking header 12/021/2015 15:21:31 - INFO - Flashing data 12/021/2015 15:21:32 - INFO - Processing cache.sin 12/021/2015 15:21:32 - INFO - Checking header 12/021/2015 15:21:32 - INFO - Flashing data 12/021/2015 15:21:33 - INFO - Processing fotakernel.sin 12/021/2015 15:21:33 - INFO - Checking header 12/021/2015 15:21:33 - INFO - Flashing data 12/021/2015 15:21:35 - INFO - Processing kernel.sin 12/021/2015 15:21:35 - INFO - Checking header 12/021/2015 15:21:35 - INFO - Flashing data 12/021/2015 15:21:36 - INFO - Processing rpm.sin 12/021/2015 15:21:36 - INFO - Checking header 12/021/2015 15:21:36 - INFO - Flashing data 12/021/2015 15:21:37 - INFO - Closing TA partition 12/021/2015 15:21:37 - INFO - Opening TA partition 2 12/021/2015 15:21:37 - INFO - Processing system.sin 12/021/2015 15:21:37 - INFO - Checking header 12/021/2015 15:21:37 - INFO - Flashing data 12/021/2015 15:21:46 - ERROR - Processing of system.sin finished with errors. 12/021/2015 15:21:46 - INFO - Ending flash session 12/021/2015 15:21:46 - ERROR - 12/021/2015 15:21:46 - ERROR - Error flashing. Aborted 12/021/2015 15:21:46 - INFO - Flashing finished. 12/021/2015 15:21:46 - INFO - Please unplug and start your phone 12/021/2015 15:21:46 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 12/021/2015 15:21:46 - INFO - Device connected in flash mode 12/021/2015 15:21:47 - INFO - Device disconnected 12/021/2015 15:21:48 - INFO - Device connected in flash mode 12/021/2015 15:21:56 - INFO - Device disconnected |
12-12-2015, 16:34 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | you can flash by sony pc suite Here Is Download Link PC-Companion Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
05-27-2016, 15:20 | #3 (permalink) |
Junior Member Join Date: Feb 2016 Location: JHUMRI TELAIYA (INDIA)
Member: 2534580 Status: Offline Thanks Meter: 0 | 27/040/2016 07:40:17 - INFO - Flashing data 27/040/2016 07:40:18 - INFO - Loader : S1_Root_bb35 - Version : MT6589_12 / Boot version : 2.14.J.2.6 / Bootloader status : NOT_ROOTABLE 27/040/2016 07:40:18 - INFO - Max packet size set to 512K 27/040/2016 07:40:18 - INFO - Making a TA backup 27/040/2016 07:40:18 - INFO - Opening TA partition 1 27/040/2016 07:40:18 - INFO - Start Dumping TA partition 1 27/041/2016 07:41:02 - INFO - Closing TA partition 27/041/2016 07:41:02 - ERROR - 27/041/2016 07:41:02 - ERROR - Error dumping TA. Aborted 27/041/2016 07:41:02 - INFO - Opening TA partition 2 27/041/2016 07:41:18 - INFO - Ending flash session 27/041/2016 07:41:18 - ERROR - 27/041/2016 07:41:18 - ERROR - Error flashing. Aborted 27/041/2016 07:41:18 - INFO - Device connected in flash mode 27/041/2016 07:41:19 - INFO - Device disconnected |
