Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
03-14-2014, 08:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Uttar Pradesh India
Member: 656277 Status: Offline Thanks Meter: 187 | xperia z1 c6902 pattern lock pattern lock in this set touch broken not work know pattern lock but toch not working so can't do this i want to save it's data any solution plz help m it's very urgent |
03-15-2014, 06:24 | #4 (permalink) |
Member: 656277 Status: Offline Thanks Meter: 187 | i want to update it by sony update service but in it 3 types z1 shows for updating xperia z1 [SOL23] , xperia [SO-01F] , xperia Z1 Z1s [C6916] which model select for updating ?????????? plz guide m |
11-08-2016, 12:09 | #5 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | when insert a usb cable in to pc and than pc demand a driver for installing so see there yor phone model type .....like c6902 for sony xperia z1 |
11-12-2016, 07:49 | #6 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1738539 Status: Offline Thanks Meter: 11 | For your problem,the HDBox is exact the best solution. You can operate the Android phone even with the broken touch. And transfer the info such contact. Here is their product link--http://hdb-team.com/product/hdbox/ Besides those,the box work on iphone and iMac also. |
11-12-2016, 08:35 | #7 (permalink) |
Member: 1738539 Status: Offline Thanks Meter: 11 | Forgot to mention that HDBox can also pre-auth your computer to your phone. Meaning that after you use HDBoxirect Control method to activate the ADB in phone, you can also use HDBox:Pre-Auth option to pre-load your computer public ADB key into your phone. So, when you connect your phone to computer you will be able to use ADB directly without having to tap on the phone screen, which in your case it is imposible. |
11-20-2016, 18:22 | #8 (permalink) |
Junior Member Join Date: Oct 2016 Location: Poland
Member: 2635679 Status: Offline Thanks Meter: 0 | Hi, if on the phone you have important data and do not want to lose it proposes to connect the adapter with micro usb to usb then connect an ordinary mouse from the computer, the screen appears the cursor and you can unlock your phone using mouse movements on the screen then after unlocking run debugging phone you are connecting to a computer and do a backup of the entire phone. |
