Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
01-07-2015, 08:35 | #2 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, Already Posted Check Here : http://forum.gsmhosting.com/vbb/10779214-post251.html Regards, ________ |
The Following User Says Thank You to ..::CHAIN::.. For This Useful Post: |
05-01-2015, 12:16 | #3 (permalink) |
Freak Poster Join Date: Sep 2006 Location: PHILIPPINES/BRUNEI Age: 44
Member: 343232 Status: Offline Thanks Meter: 22 | not working file...got error 01/002/2015 18:02:02 - INFO - Opening device for R/W 01/002/2015 18:02:02 - INFO - Reading device information 01/002/2015 18:02:02 - INFO - Phone ready for flashmode operations. 01/002/2015 18:02:02 - INFO - Current device : D6603 - BH90FG3J1L - 1288-7827_R7B - 1282-2729_23.0.1.A.5.77 - GLOBAL-LTE_23.0.1.A.5.77 01/002/2015 18:02:02 - INFO - Start Flashing 01/002/2015 18:02:02 - INFO - Processing loader.sin 01/002/2015 18:02:02 - INFO - Checking header 01/002/2015 18:02:02 - ERROR - Processing of loader.sin finished with errors. 01/002/2015 18:02:02 - INFO - Ending flash session 01/002/2015 18:02:02 - ERROR - ERR_SEVERITY="MINOR";ERR_CODE="0017";ERR_DYNAMIC=" 800A0017"; Report Post Reply With Quote |
11-21-2017, 08:37 | #5 (permalink) |
Freak Poster Join Date: Jun 2015 Age: 36
Member: 2409568 Status: Offline Sonork: 100.1652609 Thanks Meter: 25 | d6603 lock remove 100% ok file https://www.4shared.com/rar/tIKvq8hK..._remove_.html? |
The Following 9 Users Say Thank You to rashidurgsm For This Useful Post: |
09-11-2018, 09:50 | #6 (permalink) | |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
Code: 11/033/2018 13:33:24 - INFO - Flashtool Version 0.9.22.3 built on 08-06-2016 22:30:00 11/033/2018 13:33:24 - INFO - Executing search strategies to find proxy selector 11/033/2018 13:33:26 - INFO - No proxy found for IE. Trying next one 11/033/2018 13:33:26 - INFO - No proxy found for firefox. Trying next one 11/033/2018 13:33:26 - INFO - No proxy found for java. Trying next one 11/033/2018 13:33:26 - INFO - Syncing devices from github 11/033/2018 13:33:27 - INFO - Opening devices repository. 11/033/2018 13:33:28 - INFO - Scanning devices folder for changes. 11/033/2018 13:33:42 - INFO - Pulling changes from github. 11/034/2018 13:34:15 - INFO - Quietly closing devices repository. 11/034/2018 13:34:15 - INFO - Quietly closing devices repository. 11/034/2018 13:34:15 - INFO - Devices sync finished. 11/034/2018 13:34:15 - INFO - Loading devices database 11/034/2018 13:34:15 - INFO - Loaded 100 devices 11/034/2018 13:34:15 - INFO - Starting phone detection 11/034/2018 13:34:22 - INFO - Device connected with USB debugging off 11/034/2018 13:34:22 - INFO - For 2011 devices line, be sure you are not in MTP mode 11/035/2018 13:35:57 - INFO - Device disconnected 11/036/2018 13:36:35 - INFO - Flash canceled 11/037/2018 13:37:23 - INFO - Flash canceled 11/037/2018 13:37:46 - INFO - Selected Bundle for Sony Xperia Z3(D6633). FW release : 23.0.F.1.74_R3B. Customization : lock remove 11/037/2018 13:37:46 - INFO - Preparing files for flashing 11/038/2018 13:38:13 - INFO - Please connect your device into flashmode. 11/038/2018 13:38:40 - INFO - Device connected in flash mode 11/038/2018 13:38:41 - INFO - Opening device for R/W 11/038/2018 13:38:41 - INFO - Reading device information 11/038/2018 13:38:41 - INFO - Phone ready for flashmode operations. 11/038/2018 13:38:41 - INFO - Opening TA partition 2 11/038/2018 13:38:41 - INFO - Current device : D6603 - CB5A2491MR - 1288-7914_R2D - 1282-2729_23.5.A.1.291 - GLOBAL-LTE_23.5.A.1.291 11/038/2018 13:38:41 - INFO - Closing TA partition 11/038/2018 13:38:41 - INFO - Start Flashing 11/038/2018 13:38:41 - INFO - Processing loader.sin 11/038/2018 13:38:41 - INFO - Checking header 11/038/2018 13:38:41 - INFO - Flashing data 11/038/2018 13:38:41 - INFO - Loader : S1_Root_9c84 - Version : MSM8974AB_22 / Boot version : S1_Boot_MSM8974AC_LA3.0_M_3 / Bootloader status : ROOTABLE 11/038/2018 13:38:41 - INFO - Max packet size set to 512K 11/038/2018 13:38:41 - INFO - USB buffer size set to 512K 11/039/2018 13:39:00 - INFO - Found a template session. Using it : C:\Users\Syed Mobile\.flashTool\devices\D66XX\default.fsc 11/039/2018 13:39:00 - INFO - Opening TA partition 2 11/039/2018 13:39:00 - INFO - Writing TA unit 00002774. Value : 01 11/039/2018 13:39:00 - INFO - Closing TA partition 11/039/2018 13:39:00 - WARN - partition is excluded from bundle 11/039/2018 13:39:00 - INFO - Opening TA partition 2 11/039/2018 13:39:00 - WARN - dbi is excluded from bundle 11/039/2018 13:39:00 - WARN - emmc_appsboot is excluded from bundle 11/039/2018 13:39:00 - INFO - Closing TA partition 11/039/2018 13:39:00 - INFO - Opening TA partition 2 11/039/2018 13:39:00 - WARN - Unit 2127 not found in bundle 11/039/2018 13:39:00 - WARN - Unit 2301 not found in bundle 11/039/2018 13:39:00 - INFO - Closing TA partition 11/039/2018 13:39:00 - INFO - Opening TA partition 2 11/039/2018 13:39:00 - WARN - rpm is excluded from bundle 11/039/2018 13:39:00 - WARN - s1sbl is excluded from bundle 11/039/2018 13:39:00 - WARN - sbl1 is excluded from bundle 11/039/2018 13:39:00 - WARN - tz is excluded from bundle 11/039/2018 13:39:00 - INFO - Closing TA partition 11/039/2018 13:39:00 - INFO - Opening TA partition 2 11/039/2018 13:39:00 - WARN - cache is excluded from bundle 11/039/2018 13:39:00 - WARN - apps_log is excluded from bundle 11/039/2018 13:39:00 - WARN - kernel is excluded from bundle 11/039/2018 13:39:00 - WARN - fotakernel is excluded from bundle 11/039/2018 13:39:00 - INFO - Closing TA partition 11/039/2018 13:39:00 - INFO - Opening TA partition 2 11/039/2018 13:39:00 - INFO - Processing userdata.sin 11/039/2018 13:39:00 - INFO - Checking header 11/039/2018 13:39:01 - INFO - Flashing data 11/040/2018 13:40:00 - WARN - system is excluded from bundle 11/040/2018 13:40:00 - WARN - amss_fs_1 is excluded from bundle 11/040/2018 13:40:00 - WARN - amss_fs_2 is excluded from bundle 11/040/2018 13:40:00 - WARN - amss_fsg is excluded from bundle 11/040/2018 13:40:00 - INFO - Closing TA partition 11/040/2018 13:40:00 - INFO - Opening TA partition 2 11/040/2018 13:40:00 - WARN - Unit 2212 not found in bundle 11/040/2018 13:40:00 - INFO - Closing TA partition 11/040/2018 13:40:00 - INFO - Opening TA partition 2 11/040/2018 13:40:00 - INFO - Closing TA partition 11/040/2018 13:40:00 - INFO - Opening TA partition 2 11/040/2018 13:40:00 - WARN - Unit 2404 not found in bundle 11/040/2018 13:40:00 - INFO - Closing TA partition 11/040/2018 13:40:00 - INFO - Opening TA partition 2 11/040/2018 13:40:00 - INFO - Closing TA partition 11/040/2018 13:40:00 - INFO - Opening TA partition 2 11/040/2018 13:40:00 - WARN - elabel is excluded from bundle 11/040/2018 13:40:00 - INFO - Closing TA partition 11/040/2018 13:40:00 - INFO - Opening TA partition 2 11/040/2018 13:40:01 - INFO - Writing TA unit 00002725. Value : 32 30 31 38 2D 30 39 2D 31 31 20 31 33 3A 34 30 3A 30 31 00 11/040/2018 13:40:01 - INFO - Writing TA unit 00002774. Value : 00 11/040/2018 13:40:01 - INFO - Closing TA partition 11/040/2018 13:40:01 - INFO - Ending flash session 11/040/2018 13:40:01 - INFO - Flashing finished. 11/040/2018 13:40:01 - INFO - Please unplug and start your phone 11/040/2018 13:40:01 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings | |
12-28-2019, 13:30 | #7 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: kasaragod, Kerala, India
Member: 1812419 Status: Offline Thanks Meter: 156 | Quote:
file working wery well | |
The Following User Says Thank You to aaditigerhill For This Useful Post: |
10-14-2021, 05:55 | #8 (permalink) | |
Insane Poster Join Date: Apr 2020 Location: Mananjary
Member: 2955238 Status: Offline Thanks Meter: 6 | File not work for me Quote:
