LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
10-13-2015, 19:09 | #31 (permalink) |
Freak Poster Join Date: Aug 2007 Location: USA
Member: 575293 Status: Offline Thanks Meter: 40 | Once I got the browser up I started to play around, the browser did not have a address bar to allow me to type in any html. I played around some more and clicked on anything that would take me to Google. I did so much that did not work, let me tell you what did work. Since I couldnt get the apk from the sd I tried to download it, nothing worked because unknown sources was not ticked. I figured let me try to root it using TowelRoot, that opened up the task window asking which browser I wanted, tried Chrome and that didnt help, went back and tried the Metro browser and BOOM! I had access, with the help of bstryder007 sending me the apk and helping try to figure this out, he sent me the bypass apk to Yahoo, in the Metro browser Yahoo let me install the apk and now I have access. I was able to tick the dual window option, unknown sources, pin, everything BUT restore or add new Google account. This is where Im stuck and need help with, how can I restore if there is no option and add a new account. When I tried to delete it says you need an account, I click add then it goes back to "this phone has an account already". Credit bstryder007 helped me until 3am with this. |
10-13-2015, 20:49 | #32 (permalink) | |
Member: 575293 Status: Offline Thanks Meter: 40 | Quote:
Using BillA's method works after I was able to gain access to the browser and download the shortcut apk. You might want to bypass everything I did after you get the browser to work and use BillA's method, I dont see why it wont work. | |
10-14-2015, 09:59 | #33 (permalink) |
No Life Poster Join Date: May 2013 Location: Earth
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | hello bro Billa,i want to knw how to install the apk file when the phone has been locked to the account,or does it work through otg cable. |
10-15-2015, 03:14 | #35 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
If you've selected the "MasterClearActivity" and it's grayed out then it may have been patched in the latest version 10N. Let me know your model and firmware version. | |
10-22-2015, 11:53 | #43 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | But why write what isn't True? Explain Here what you have done with Octopus, any Option for REMOVE GOOGLE ACCOUNT... I can suppose what you have thinked of do with Octopus, but will be good that YOU explain here if have done really. BR allumts |
10-22-2015, 12:50 | #45 (permalink) |
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | bro, there are differnce between user lock(gmail account lock) and frp lock(google activation lock)which only exist on android lollipops.so if octopus can solve this problem u can help us with some videos,logs or nice explanation on hw to do dat |
