LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
06-30-2015, 08:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Everything about LG G2: root, recovery, KDZ, ROM Note - This guide for LG G2 root run Android 4.2.2 / 4.4 to 1 I'll post another update There are ways to Root G2, G2 Box LGViet on many topics also mentioning. However its most simple instructions. - Full Driver Installation here https://docs.google.com/file/d/0B3J7gOQH7ViEVzdsRVp6OWw2dmM/edit?usp=sharing - Enable USB debugging by: Go to Settings / About Phone / Software Information / Click 7 times on the "Create a" / Now turn to the settings you'll add this line: options publisher development. At the developer's option tick USB debugging. Note to pull the tick accessible cab options - Enable installed app unidentified by going to Settings / Security / Source Unknown / select allowed - Plug the cab at LG Software or MTP mode - Download Root tool here: https://drive.google.com/file/d/0B6ojCKMLwcQMYVdmeXhERTF6b2c/edit?usp=sharing - Proceed with the installation and running Tool - Click the text color ROOT CAM. This text appears if you have installed and enabled full usb driver debug. Go here is finished Root stages. LGViet, LG G2 Root, Recovery, KDZ, G2 backup IMEI, ROM for LG G2, G2 ROM Vietnamese. Section 02. Installation Guide Recovery (Recovery permanently) Recovery Permanently for V11: if your ROM version is V11 or more, use this guide. Encouragement to the latest version to ensure the highest reliability. Requires root then be used offline. When the grant Root remember asking OK to accept. Down the run file inflates Recovery.bat / Pass decompression LGViet.com Be sure to choose the right, careful not mistakenly file nhé 6.0.4.4 CWM RECOVERY ENGLISH SEMI-TOUCH: F320K Recovery (6.0.4.4) Download F320L Recovery (6.0.4.4) Download F320S Recovery (6.0.4.4) Download D802 Recovery (6.0.4.4) Download Recovery Permanently for V10: if your ROM version is V10 or less, use this guide. NOTE carefully read the instructions: Download the correct version for your computer. - Currently no flash recovery directly TWR on V11c DC, so if you update OTA or KDZ up V11c please do not use this Recovery. - You can use other ways to still have the Recovery TWR V11c by, only the V11c flash system, or after ota, or KDZ to 11c, the flash back of the V10 is in DC aboot normal TWR. F320K download this file - Download file https://docs.google.com/file/d/0B3J7gOQH7ViENHd4N3RwcHdCYTA/edit?usp=sharing F320S download this file: https://docs.google.com/file/d/0B3J7gOQH7ViEUDhYZnlvMHJsbzA/edit?usp=sharing - This is a permanent recovery, just as the new KDZ loss, very safe and have touch - Unzip the folder G2_recovery - Run the file Recovery.bat - This time on the phone asks you if you agree to run Root or not you press the right button to agree to the installation. - The camera will automatically reboot, set the recovery process is complete, you can use the command adb recovery to enter recovery and backup use, install rom as usual F320L A. If you're in the 10e or 10m, you install TWRP Recovery (here recovery of K / S / L are used to each other).Section 03. Backup IMEI This part is very important, please do right after the root, otherwise there will be days you will pay the price for his subjective. Method 01: Use LG IMEI Backup tool by hoangnova from LGViet https://docs.google.com/file/d/0B3J7gOQH7ViEWUp0VUVGdE5ZRVE/edit?usp=sharing Proceed with the installation and click Backup (backup), file backup IMEI will be created in the folder on the memory sphinxvn. Keep the middle and carefully to prevent the latter needed to. Method 02. If you have installed TWRP Recovery Take into recovery, choose backup, tick the last option in the backup is a backup EFS After the backup is complete, you also take away carefully / Where best to upload it as a precaution. |
06-30-2015, 08:42 | #2 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Frequently Asked Questions. 1. How to hard reset LG G2 Typing Code: adb shell --wipe_data recovery Or Follow the instructions in the form below: 142050n0lwb4ttbbze0tgo.jpg 2. How to enter the Recovery mode by pressing hard (when installed permanently and Recovery) View this clip will get through it immediately. With F320: Power + Volume (+); Until now, the white lines removed his hand from 2 Keys Power and Volume +, right then quickly press many times the volume (-). With D802: Power + Volume (-); Until now, the white lines removed his hand from Power button and Volume 2 -, shortly after quick hands repeatedly press the volume (+). 3. How to enter Download mode? Turn off the machine, hold the Volume + and plug the cab, the machine will automatically boot into download mode 4. G2 firmware Website http://lg-phone-firmware.com/index.php?id_mod=36 5. How to enable adb debug and developer mode Enable USB debugging by: Go to Settings / About Phone / Software Information / Click 7 times on the "Create a" / Now turns out the installation will see the line: The developer's option. |
06-30-2015, 08:45 | #3 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | LG G2 configuration / system partitions and other information. Information: LG G2 has multiple versions, corresponding to the different operators in the world. LG G2 International Codenamed D802 for the international G2 LG G2 of the Korean Network Divided into 3 different versions: - F320 S for SK Telecom - F320 L for telecom network operators LGU + - F320 K for SK Telecom (you're using a K). This is the common line that Vietnamese people tend to use, so every laptop from South Korea more popular items from the US or Canada Configuration: - Change the PIN, have sdcard slot expansion - PIN 2610 mAh - Is the antenna in the right corner, can pull up LG G2 of the US networks In the US market, LG G2 F320 also be divided into multiple versions for each carrier: - VS980 Verizon - LS980 Sprint - AT & T D800 - D801 T-mobile network Configuration: - Do not remove the PIN, no memory card slot - PIN 3000 mAh Moreover: D803 for the Canadian market The system partition of LG G2 Code: adb shell ls leveling /dev/block/platform/msm_sdcc.1/by-name/ 1970-01-01 10:45 lrwxrwxrwx DDR root root -> / dev / block / mmcblk0p4 1970-01-01 10:45 aboot lrwxrwxrwx root root -> / dev / block / mmcblk0p5 1970-01-01 10:45 blus lrwxrwxrwx root root -> / dev / block / mmcblk0p29 1970-01-01 10:45 lrwxrwxrwx root root boot -> / dev / block / mmcblk0p7 1970-01-01 10:45 lrwxrwxrwx cache root root -> / dev / block / mmcblk0p35 1970-01-01 10:45 lrwxrwxrwx carrier root root -> / dev / block / mmcblk0p27 1970-01-01 10:45 dBi lrwxrwxrwx root root -> / dev / block / mmcblk0p3 1970-01-01 10:45 dbibak lrwxrwxrwx root root -> / dev / block / mmcblk0p30 1970-01-01 10:45 drm lrwxrwxrwx root root -> / dev / block / mmcblk0p21 1970-01-01 10:45 encrypt lrwxrwxrwx root root -> / dev / block / mmcblk0p20 1970-01-01 10:45 eri lrwxrwxrwx root root -> / dev / block / mmcblk0p28 FOTA root root lrwxrwxrwx 1970-01-01 10:45 -> / dev / block / mmcblk0p25 1970-01-01 10:45 FSC lrwxrwxrwx root root -> / dev / block / mmcblk0p17 FSG root root lrwxrwxrwx 1970-01-01 10:45 -> / dev / block / mmcblk0p16 Grow root root lrwxrwxrwx 1970-01-01 10:45 -> / dev / block / mmcblk0p39 1970-01-01 10:45 LAF lrwxrwxrwx root root -> / dev / block / mmcblk0p24 1970-01-01 10:45 lrwxrwxrwx root root Misc -> / dev / block / mmcblk0p13 1970-01-01 10:45 lrwxrwxrwx root root modem -> / dev / block / mmcblk0p1 1970-01-01 10:45 modemst1 lrwxrwxrwx root root -> / dev / block / mmcblk0p10 1970-01-01 10:45 modemst2 lrwxrwxrwx root root -> / dev / block / mmcblk0p11 lrwxrwxrwx root root MPT 1970-01-01 10:45 -> / dev / block / mmcblk0p26 1970-01-01 10:45 lrwxrwxrwx root root pad -> / dev / block / mmcblk0p9 1970-01-01 10:45 Pad1 lrwxrwxrwx root root -> / dev / block / mmcblk0p12 1970-01-01 10:45 pad2 lrwxrwxrwx root root -> / dev / block / mmcblk0p19 1970-01-01 10:45 persist lrwxrwxrwx root root -> / dev / block / mmcblk0p14 1970-01-01 10:45 rct lrwxrwxrwx root root -> / dev / block / mmcblk0p33 1970-01-01 10:45 lrwxrwxrwx recovery root root -> / dev / block / mmcblk0p15 1970-01-01 10:45 lrwxrwxrwx root root rpm -> / dev / block / mmcblk0p6 1970-01-01 10:45 rpmbak lrwxrwxrwx root root -> / dev / block / mmcblk0p31 1970-01-01 10:45 sbl1 lrwxrwxrwx root root -> / dev / block / mmcblk0p2 SNS root root lrwxrwxrwx 1970-01-01 10:45 -> / dev / block / mmcblk0p22 lrwxrwxrwx root root spare 1970-01-01 10:45 -> / dev / block / mmcblk0p37 1970-01-01 10:45 ssd lrwxrwxrwx root root -> / dev / block / mmcblk0p18 lrwxrwxrwx root root system 1970-01-01 10:45 -> / dev / block / mmcblk0p34 1970-01-01 10:45 tombstones lrwxrwxrwx root root -> / dev / block / mmcblk0p36 tz root root lrwxrwxrwx 1970-01-01 10:45 -> / dev / block / mmcblk0p8 1970-01-01 10:45 tzbak lrwxrwxrwx root root -> / dev / block / mmcblk0p32 1970-01-01 10:45 userdata lrwxrwxrwx root root -> / dev / block / mmcblk0p38 1970-01-01 10:45 lrwxrwxrwx root root ve -> / dev / block / mmcblk0p23 |
06-30-2015, 08:47 | #4 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Synthesis link Download firmware - KDZ - tot ... LG G2 F320, D802 ... The power grab and download LG G2 KDZ: 1. Enter your IMEI information here will place the latest firmware LG IMEI²éѯ 2. Go to this link and find the right firmware you need. For example, your search is going to LG its F320K F320K line to get the download link and KDZ LG G2 Firmware List 3. Direct download link KDZ in this page: http://inclu.net:82/LG/LG%20G2/ LG D802 http://inclu.net:82/LG/LG G2 / G2_D802 / LG F320K http://inclu.net:82/LG/LG G2 / KT / LG F320S http://inclu.net:82/LG/LG G2 / SKT / LG F320L http://inclu.net:82/LG/LG G2 / LG U + / |
06-30-2015, 08:50 | #5 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | G2 guide up 4.4 KitKat update. There are two ways to update your G2 to 4.4 However my advice you should not hurry this time to 4.4 a few reasons as follows: - After the version 4.4 make sure LG will also continuously update patch. See his K medium to 4.4 V20A has 1 update then. - Recovery is not yet available Method 1. Download this file KDZ 4.4 kitkat on: F320S 20A: ??? ??-????? F320L 20B: ??? ??-????? 20A F320K ??? ??-????? KDZ conduct follow all instructions in the post number # 2 Method 2. Download these files after the original ROM and flash through Recovery LG F320K https://docs.google.com/file/d/0B0fH...l4Y2pma0U/edit LG F320S https://docs.google.com/file/d/0B0fH...ZyZjRlSlU/edit LG F320L Showing update again LG D802 No Note, after flash this one where no Root should need more flash anymore Root update packages: http://download.chainfire.eu/372/Sup...erSU-v1.86.zip Guide downgrade G2 back 4.2 JB Option 1: If you can not like 4.4 for G2 back to 4.2 by KDZ KDZ file of 4.2.2 or follow this guide Method 2: am update - Note that doing it this way you should have any Backup 4.2.2 ROM zip ROM 4.2.2 or any of the internal memory or the memory card - Download files to run the batch file after corresponding with your version to update the system partition to 4.2, it will update the Recovery anymore. Then this tool it automatically in Recovery - Then you can go to Flash the ROM Recovery 4.2 any to return 4.2 Downgrade LG G2 Download and unzip tool and choose the .bat file matching your versions. Pass decompression LGViet.com https://drive.google.com/file/d/0B6o...it?usp=sharing |
06-30-2015, 08:51 | #6 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Guide Flash ROM for LG G2 F320 International S / L / K This method applies only to whiff STOCK ROM, genres CM, MIUI or AOSP other background not apply Basically international Flash ROM for G2 F320 is simple: Step 1. - Search ROM D802 any you like, this example in such ROM Flex http://lgviet.com/forum/threads/tong...g-g2-d802-d801 -d800-f320.10626 / Step 2 - Download to your computer, but not the flash immediately but open it with winrar or 7zip on the computer. Boot.img deleted (or kernel.img) Then copy and memory cards or internal memory Step 3 - Upload Wifi and fix your memory card lamhoang_vt in terms https://www.dropbox.com/s/os4ugk7bxz...fi-the-nho.zip Then copy and memory cards or internal memory Step 4 - Proceed as the ROM Other flash after flash do not have to reboot quickly that flash always file Patch-fix-wifi-the-nho.zip in step 3. ROM and reboot 4wipe is international. |
06-30-2015, 08:51 | #7 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | The general information 1. Summary of the LG G2 Modem See source link and download here. - Sources from the XDA Flashable Modem Zips [All G2 Variants] | LG G2 | XDA Forums 2. MOD improve quality and camera functionality for viewing here: [APP][DRIVER] XCam LG v6.2.4 [G2] | LG G2 | XDA Forums Had version 2.0 for LG G2 4.4.2 I got you |
06-30-2015, 08:52 | #8 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Root LG G2 Guide 4.4 Method 1. Use IORoot Download tool ioroot here: http://*******/KZ4YtX Perform the following steps: - On Usb debugging, plug the cable in MTP mode or LG Software - Unzip the file and run ioroot root.bat in directory ioroot19 - Press 1 to continue pressing any key - Immediately after the press it will make you stop is not pressed again, withdrawing cab, on the Developer options (Options developers), tick and untick to Troubleshoot usb (usb debugging). - Then plug the cab and press continue - It will make you careful not to lose the warranty, it warned shelf alone, was playing as hard and plays hard. Click to continue, finishing off then restart the computer. Open up to update su binary Superuser. Accomplished This is me performing on LG G2 Root F320K 4.4 kitkat V20F (top). Performed by hoangnova from LGViet.com Source: [ROOT] Root your G2 [ATT|VZW|TMO|KT|RGS|BELL… - Pg. 87 | LG G2 | XDA Forums |
06-30-2015, 08:52 | #9 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Guidelines for LG G2 KDZ in some cases soft brick, can not KDZ in Post # 2 ways. Or when KDZ stopped at 5%, 15%, did not finish the KDZ. Or go KDZ KDZ has repeatedly been bootloop (hang LOGO). You follow the instructions in # 2 of this thread: M?i th? v? LG G2: root, recovery, kdz, c?u soft brick - Ch? dành cho 4.2.2 | C?ng ??ng LG Vi?t However in step 4, you selected as in this figure will succeed. Basically, you do not choose the Type is 3GQT which college to choose CDMA, Flash Tools will then add a button is "web CSE upgrade test". Click the button to run the original firmware offline. Good luck! |
08-22-2015, 21:02 | #10 (permalink) |
Junior Member Join Date: Apr 2012 Location: your heart
Member: 1745074 Status: Offline Sonork: imranlocutorio Thanks Meter: 1 | Hello every 1, I have unlocked my G2-802 Movistar spain with Octoplus Box, Now touch screen isn't working , I have flashed it with various firmwares but still same result ,Could any one help me how to fix this problem. if anyone has a offical firmware please share it or any other solutions. thanks |
09-13-2015, 18:18 | #11 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Pakistan,Bahawalpur
Member: 329994 Status: Offline Thanks Meter: 14 | hey guys,i have Lg g2 d800.i installed custom rom on it lollipop now it,s touch stoped working i tried many firmwares but no luck,when i installed lollipop in my phone it was working fine but when i get up in morning i seen it,s touch ws not working.i changed it,s 3 touch with complete panel but no luck can any1 help me please? |
09-13-2015, 19:04 | #12 (permalink) |
Member: 329994 Status: Offline Thanks Meter: 14 | Lg g2 D800 touch no working after upgrade to lollipop hey guys,i have Lg g2 d800.i installed custom rom on it lollipop now it,s touch stoped working i tried many firmwares but no luck,i can put it in download mode i did hardreset it many times,i have it,s old firmware backup but now phone is not rooted also and touch also not working,when i installed lollipop in my phone it was working fine but when i get up in morning i seen it,s touch ws not working.i changed it,s 3 touch with complete panel but no luck can any1 help me please? |
02-25-2016, 18:42 | #14 (permalink) |
Freak Poster Join Date: Jan 2014 Location: pakistan
Member: 2114397 Status: Offline Thanks Meter: 157 | hello Faheem sir i flash lg ls980 with TOT file by Lg flash tool .flashed successfully but now show on screen insert sim emergency .have you any solution plz guide me |
03-06-2016, 19:41 | #15 (permalink) |
Freak Poster Join Date: Jan 2007 Location: ALGERIA
Member: 431529 Status: Offline Thanks Meter: 18 | problem with D802 sir i managed to flash D802 with LG Flash tool 2014 in KDZ format but after flashing finished phone says Service disabled no imei no network sometimes reboots itself no i stuck with it is there any chance with repair efs and imei or ???? thanks in advance |
