LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
06-23-2013, 02:59 | #1 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | [Guide] All LG Mobile phones Hard Reset Procedures Lg Optimus G Eclipse E970 Hard Reset if you perform a hard reset,all user applications and user data will be deleted please remember to back up any important data before performing a hard reset 1.turn the phone off 2.press and hold volume down + power + lock key at the same time 3.release the keys when the factory hard reset screen appears 4.read the warning and press the power/lock key to confirm.press any other to cancel 5.press the power/lock key to confirm once more or press any other to cancel 6.your device will perform a hard reset |
The Following 4 Users Say Thank You to Braycel For This Useful Post: |
06-23-2013, 03:03 | #2 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,912 | Factory Reset the LG Optimus S The factory reset clears all user data and 3rd party applications, restoring the device to it's original factory settings. It's often recommended following a software update to help resolve or clear compatibility issues Prior to performing the reset, it is recommended to backup your personal data (see below) and then remove the SD card. Note: This will not remove Operating System software from your device (Froyo, Gingerbread, etc.) Factory reset steps: 1. From the main home screen, select Menu 2. Select Settings, then select Privacy 3. Select Factory Data Reset 4. Select Reset phone 5. Enter the password if prompted, and select Erase Everything If the device is frozen, follow these steps: 1. Remove and reinsert the battery 2. The device will power on 3. Hold Volume down, Home, and Power buttons until the reset screen appears 4. Select wipe data/factory reset (using volume down) and press Menu 5. Select Yes and press Menu |
The Following 3 Users Say Thank You to Braycel For This Useful Post: |
06-23-2013, 03:06 | #3 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,912 | Hard Reset LG Optimus L7 P700 to Restore Factory Settings You can hard reset your LG Optimus L7 P700 to restore the factory default settings. Caution: If you perform a hard reset, all user applications and user data will be deleted. This cannot be reversed. Remember to back up any important data before performing a hard reset. Switched off your phone then press and hold the Volume down key + Power key with your left hand. When the LED on the bottom of the phone lights up, touch and hold the Menu key with your right hand. You need to do this immediately, before the screen displays the LG logo. Make sure your left hand is still holding the Volume down and Power keys. Then release the power key at vibration time. When the LG logo is displayed on the screen, continue to hold the keys for around 2 seconds, and then release all them at the same time, before the LG logo disappears. Leave your phone for at least a minute while the hard reset is carried out. You will then be able to switch your phone back on. |
06-23-2013, 14:35 | #4 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,912 | Hard Reset LG P705 1 - Open the version of Vygis LGI_1_9XSD 2 - Mark model KP100 3 - Connects only in ports & settings 4 - Click on reset phone with him and connected with the cable GS102 |
The Following 2 Users Say Thank You to Braycel For This Useful Post: |
10-13-2013, 08:16 | #11 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2045288 Status: Offline Thanks Meter: 1 | Is hard reset the same as unlocking phone? I need to unlock my Lg Optimus 5 E 610! I need that code, so, if anyone can help me! Thank you! |
The Following User Says Thank You to Dragoinis For This Useful Post: |
