Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 01-22-2015, 11:29   #46 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG L90 Dual D410
  1. First power off your phone.
  2. Then press and hold together Volume Down + Power button.
  3. Now if you see logo LG, then release only Power button for 1 second.
  4. After that press again Power button, and hold them until you see the menu system.
  5. You can see now information «Erase all user date restore default settings?», and there will be two buttons: Yes and No.
  6. Please use the Volume Down to active Yes.
  7. Next press Power button.
  8. Afterwards you phone will reset and reboots.
  9. Done!
Old 01-22-2015, 11:30   #47 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG L70 Dual D325
  1. Power off your device.
  2. Then hold and press Volume Down + Power button.
  3. When you see "Factory data reset" menu, then release holded buttons.
  4. Now you will see information to confirm "Erase all user data & restore default settings?".
  5. Press Yes using Volume buttons to scroll, and Power button to confirm.
  6. Good job!
The Following User Says Thank You to Tajammul For This Useful Post:
Old 01-22-2015, 11:31   #48 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG L70 D320N
  1. Press Power button to switch off device.
  2. Then press and hold Volume Down + Power button.
  3. LG logo has to flash, then release keys.
  4. Now phone will start hardreset process so wait patiently.
  5. Done, you can now work on device.
Old 01-22-2015, 11:33   #49 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG E610 Optimus L5
  1. Tap Power button to switch off device.
  2. Press and hold Volume Down + Power button + Home button.
  3. When LG logo will appear on screen release buttons.
  4. Confirm process twice by pressing Power button.
  5. Device will restart, after that you can work on device.
Old 01-22-2015, 11:33   #50 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG GM360 Bali
  1. Phone must be turned off so press and hold Power button.
  2. Now open up dialer by pressing Call key.
  3. Tap this code using keypad: 1809#*360#
  4. Next confirm Factory reset operation by clicking Call key.
  5. Now your phone will restart.
  6. Success! your phone is now after operation and ready to use.
Old 01-22-2015, 11:34   #51 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG P500 Optimus One
  1. Power button to switch off device.
  2. Then press and hold Volume Down + Power button + Home button.
  3. Release them, when LG logo appears.
  4. Confirm process by pressing Power button.
  6. Done, you can work on your device.
Old 01-22-2015, 11:35   #52 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Arrow Hard Reset LG E612 Optimus L5
Old 01-22-2015, 11:37   #53 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG Optimus L3 II E430
First method:
  1. Make sure, that your phone is off.
  3. After LG logo appears release buttons.
  5. Handset now should perform reset.
Second method:
  1. Power on the device.
  2. Next press Menu key, and goto Apps tab -> Settings -> Personal -> Backup & reset -> Factory data reset
  3. Then confirm all informations on your screen.
  4. Well done!
Old 01-22-2015, 11:38   #54 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG GT540 Swift
  1. Power button to switch ON device.
  2. Then press and hold Volume UP + Search button + Home button until see Factory Reset question.
  3. Select OK
  4. Now your phone will restart.
  5. Done, you can work on your device.
Hard Reset by Code:
  • Dial 3845#*54#
  • Now select Factory reset
Old 01-22-2015, 11:39   #55 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG Swift G F180
  2. Press and hold Volume Down + Power button.
Old 01-22-2015, 11:40   #56 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG L40 Dual D170
Second method:
  1. Power on your device.
  2. From the Home screen select Menu.
  3. Now choose Settings -> Back up and reset -> Reset device -> Delete all.
  4. Confirm all informations, and wait until your phone will reset and reboots.
  5. Success!
Old 01-22-2015, 11:41   #57 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG Optimus L3 II E425
First method:
  2. Then press and hold Volume Down + Home button + Power button.
  3. Release them, when Home button will blink.
  4. Now your phone will reboots.
Second method:
  1. Make sure, that your phone is on.
  5. Success!
Old 01-22-2015, 11:42   #58 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG LG730 Venice
First method:
Second method:
  2. Next press and hold Volume Down + Power button until you see white descriptions.
  3. Then press only Power button.
  4. If you see next warning, then press Power button.
  5. Now you will be in Recovery mode.
  6. From the menu select option "wipe data/factory reset" using Volume buttons to scroll, and Power button to confirm.
  7. After that choose "Yes -- delete all user data".
  8. To finish operation select option "reboot system now".
  9. Good job!
Old 01-22-2015, 11:43   #59 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG MS769 Optimus L9
First method:
Second method:
  2. Next from the Home screen tap Apps icon, and press Settings -> Backup & reset -> Factory data reset -> Reset phone -> Erase everything.
  3. Confirm your choice and wait to finish operation.
  4. Good job!
Old 01-22-2015, 11:43   #60 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 425
Thumbs up Hard Reset LG L35G SIM4
Page generated in 0.60220 seconds with 8 queries
