Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 01-22-2015, 11:44   #61 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG E460 Optimus L5 II
  1. Handset has to be switched off.
  2. Press Volume Down + Power button + Quick button for about 10 seconds.
  3. When LG logo will appear on screen release both buttons.
  4. Device will restart, after that you can work on device.
Old 01-22-2015, 11:48   #62 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG E435 Optimus L2 II
First method:
  1. First please turn off the phone.
  2. Now press and hold Volume Down + Home button + Power button.
  3. Release them, when Home button will blink.
  4. Next your phone will reboots.
Second method:
  1. Power off your cell phone.
  2. Next press and hold Volume Up + Power button for about 5 seconds.
  3. Then release only Power button, but hold Volume key for 5 second.
  4. Now you will be in Recovery mode.
  5. From this menu choose option "wipe data / factory reset" using Volume buttons to scroll, and Power button to confirm.
  6. Afterwards select "Yes -- delete all user data".
  7. To finish operation select option "reboot system now".
  8. Well done!
Old 01-22-2015, 11:49   #63 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG Optimus L7 II P713
  1. First power off your phone.
  2. Then press and hold together Volume Down + Power button.
  3. Next when the led of the bottom of the phone lights on,touch and hold the Menu key with your right hand.
  4. Now if you feel that phone vibrates, then release Power button.
  5. Release all the keys of the phone before Lg logo disappears.
  6. After that your phone will restarts.
Old 01-22-2015, 11:49   #64 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG E450 Optimus L5 II
First method:
  1. Power off your device.
  2. Next press and hold Volume Down + Quick button + Power button.
  3. Release all buttons when LG logo appears
Second method:
  1. First make sure, that your phone is on.
  2. Then from the Home screen tap: Settings -> Back up and reset -> Factory data reset -> Reset device -> Delete all.
Old 01-22-2015, 11:53   #65 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG LN272 Rumor Reflex
  1. Switch on your device by holding Power button for couple seconds.
  2. Open phone's Dialer or go to Standby screen.
  3. Type this code in phone's Dialer: 2945#*#
  4. Now whole operation needs to be confirmed by pressing green Call key.
  5. Let device to restart, after that you can work on it.
Old 01-22-2015, 11:54   #66 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG SU420 Cafe
  1. Power button to switch on device.
  2. Then Call key to open phone's Dialer or go to Standby screen.
  3. Type in this code: 2945#*#
  4. Call key to confirm whole process, after that handset must restart.
  5. Success! phone is ready to use.
Old 01-22-2015, 11:55   #67 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG Optimus F3 LS720
First method:
  1. Check device it must be turned off, to do it press Power button.
  2. Press and hold Volume Down + Power button.
  3. When LG logo will appear on screen release buttons.
  4. Android recovery menu should appear now.
  5. Use Volume Rockers to navigate on wipe data/factory reset and press Power key to select it.
  6. After the data wipe is complete, press the down Volume Key to scroll to reboot system now and press Power key to confirm it.
  7. Done device is ready to use.
Second method:
  1. Switch on you phone.
  2. Next when you are in Home screen, then press Menu key.
  3. Then tap System settings -> Backup & reset -> Factory data reset -> Reset device -> Delete all or Erase everything.
  4. Now your device will reset and reboots.
  5. Success!
Old 01-22-2015, 11:56   #68 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG C395 Xpression
First method:
  1. Power on device.
  2. Start by opening phone's Dialer.
  3. Now type in this code using keypad: 1809#*395#
  4. Confirm whole Data wipe process.
  5. After restart your device will be ready to work on.
Second method:
  1. Turn on your mobile phone.
  2. Now from the Home screen tap Menu icon.
  3. Then tap Settings -> Phone -> Reset Settings -> Master reset.
  4. Confirm warning in your screen -> Yes.
  5. Next if you have any password, then enter it, and wait to finish reset.
  6. Done!
Old 01-22-2015, 11:57   #69 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG LS855 Marquee
First method:
  1. Power button to switch off device.
  2. Then press and hold Volume Down + Power button.
  3. Release them, when LG logo appears.
  4. Confirm process by pressing Power button.
  5. Now your phone will restart.
  6. Done, you can work on your device.
Second method:
  1. Turn on your handset.
  2. Now tap Home key -> Menu key, and goto Settings -> Privacy -> Factory data reset -> Reset phone.
  3. Then enter your password, and tap option Erase everything.
  4. Good job!
Old 01-22-2015, 11:58   #70 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG L60 X147 Dual
  2. Press Volume Down + Power button for about 10 seconds.
  4. Whole process has to be confirmed to do it press Power button twice.
  5. Device will restart, after that you can work on device.
Old 01-22-2015, 11:59   #71 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG LU6800 Optimus Big
First method:
  1. Make sure, that your phone is off.
  2. Press and hold Volume Down and Power button.
  3. When LG logo will flash release keys.
  4. Confirm process twice by pressing Power button.
  5. Handset now should perform Master reset.
Second method:
  1. Power on the phone.
  2. Next make sure, that you are in Home screen.
  3. Then tap Settings -> Privacy -> Factory data reset -> Reset phone -> Erase everything.
  4. Confirm your choice, and wait until your phone will reset and reboots.
  5. Well done!
Third method:
  1. Switch off the phone.
  2. Now press and hold Home button + Volume Down + Power button.
  3. Next follow the instructions to reset your device.
  4. Finito!
Old 01-22-2015, 12:01   #72 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG F220K Optimus GK
First method:
  1. Please first check, that your phone is off.
  2. Then press and hold Volume Down + Home button + Power button.
  3. When LG logo appear, then release holded buttons.
  4. Wait a minute until your phone reboots.
Second method:
  1. Make sure, that your phone is on.
  2. From the Home screen select Menu.
  3. Now choose Settings -> Back up and reset -> Reset device -> Delete all.
  4. Confirm all informations, and wait until your phone will reset and reboots.
  5. Success!
Old 01-22-2015, 12:02   #73 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG L Fino
First method:
  2. Next goto Settings -> Backup & reset -> Factory data reset -> Reset phone -> Erase everything.
  3. Then follow the instructions.
  4. Done!
Second method:
  1. Turn off your device and wait 10 seconds.
  2. Now press and hold Volume Down + Power button.
  3. Then if you see logo LG on your screen, then release holded keys, and immediately press and hold previous keys.
  4. When you see Factory data reset on your screen, then release holded buttons.
  5. Next from the menu choose option "Yes" using Volume buttons to scroll
  6. Success!
Third method:
  1. Switch off your cell phone.
  2. After that press and hold Volume Down + Power button.
  3. Now if you see LG logo on your screen, then release only Power button, and the immediately press and hold Power button again.
  4. Then when Factory data reset appears, then release holded keys.
  5. Select from the menu option "Yes" using Volume buttons to navigate.
  6. Finito!
Fourth method:
  2. Next hold and press Volume Down + Power button.
  3. Release holded buttons when you see LG logo, and then immediately press and hold Volume Up + Volume Down.
  4. If Factory data reset menu appears on you screen, then release holded buttons.
  5. From this menu accept option "Yes".
  6. Good job!
Old 01-22-2015, 12:03   #74 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG LS 970 Optimus G
First method:
  1. Press Power button to switch off device.
  4. You will enter the Android system recovery menu.
  6. After the data wipe is complete, press the down Volume Key to scroll to reboot system now and press Power key to select it.
Second method:
  1. Turn off your device.
  2. Next hold and press Volume Up + Power button until you see warning message.
  3. Confirm this waring by pressing Power button two times.
  4. Now your phone will reset adn reboots.
  5. Finish!
Third method:
  2. Now from the Home screen select Menu.
  3. Then tap Settings -> Back up and reset -> Reset device -> Delete all.
  5. Success!
Old 01-22-2015, 12:04   #75 (permalink)
Tajammul's Avatar
Member: 140477
Sonork: 100.1658502
Thanks Meter: 418
Thumbs up Hard Reset LG L Bello
First method:
  4. Done!
Second method:
  6. Success!
Third method:
  6. Finito!
Fourth method:
  6. Good job!
Page generated in 0.65531 seconds with 8 queries
