[guide][new root method for lg devices][guide] [GUIDE][NEW ROOT METHOD FOR LG DEVICES][GUIDE] https://www.mobigyaan.com/images/sto.../lg-logo-1.jpg Code: I am not responsible for bricked devices, dead SD cards, Prerequisites 1.) Download LG Root 2.) Download LG Drivers 3.) A micro USB cable connected to your PC 4.) Your device must be unencrypted 5.) Before you ask a question, make sure you looked at the pictures in the guide. 1.) Download and unzip the LG_Root.zip in your preferred location I chose the Desktop for my location http://i.imgur.com/xkBEnEt.png 2.) Enable ADB debugging on your device Go to Settings > About Phone > Software Information and tap build number until you are presented with "You are now a developer" Exit back to Settings main screen In Developer Options enable USB Debugging (Some devices require enabling PTP for debugging to work) 3.) In the root of LG_Root folder start a command prompt Instructions may vary based on Window's version Inside of LG_Root folder hold shift and right click a blank space you should see "Open command window here" http://i.imgur.com/JNudOyR.png http://i.imgur.com/JMNTakw.png 4.) Now that we have a command prompt running in the root of the folder let's get started. (Commands are copy+paste unless specified) Let's make sure our device is connected Code: adb.exe devices 5.) Great! My device is connected let's continue, we need to get the files onto the device used for this root method. In the same command prompt let's execute another command Code: adb.exe push busybox /data/local/tmp/ && adb.exe push lg_root.sh /data/local/tmp && adb.exe push UPDATE-SuperSU-v2.46.zip /data/local/tmp 6.) Well that was easy , let's continue (Now that we have the files on our device we want to put our device is download mode) (Note this method may vary from device to device) Power off your device When the device is powered off, hold volume up and insert a USB cable connected to the PC Wait for the drivers to install 7.) We're almost done (you've managed to get in download mode) http://i.imgur.com/HR3cXz4.png 8.) Let's find which COM port our device is connected to Double click ports.bat (This will give us the COM port in which our device is connected we are looking for the Diag port) You may exit this command prompt when you have your COM port number, keep the other command prompt open http://i.imgur.com/SoUGF5o.png 9.) Let's Begin! (Keep the device in Download mode) Let's run Send_Command.exe (It couldn't connect? Make sure you COM port number is correct it varies) Code: Send_Command.exe \\.\COM4 10.) Final Step!!!!!! (We must run the root script) Code: sh /data/local/tmp/lg_root.sh dummy 1 /data/local/tmp/UPDATE-SuperSU-v2.46.zip /data/local/tmp/busybox 11.) We're done You may pull the battery to get the device out of Download mode credit for this guide xda fourm if you like my post just press onlyhttp://forum.gsmhosting.com/vbb/imag...ost_thanks.gifbutton _________________ B.R Abhay_Rana_Singh!!!! http://img40.imageshack.us/img40/606...bulletfast.gif |
Useful, keep it up dear brother. |
which lg models and andriod versions are supported in this tool ? |
Thanks for share.... |
LG Gpad F 7.0 LK430 on ZV3 5.0.1 script done but when i open supersu it says SU binary needs to be updated and it fails every time. tried hard reset but no help. thanks for the share. |
Is this work fr lg e988 |
