LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
09-15-2015, 11:04 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2015 Location: faridabad(delhi) Age: 33
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,203 | [guide][new root method for lg devices][guide] [GUIDE][NEW ROOT METHOD FOR LG DEVICES][GUIDE] Code: I am not responsible for bricked devices, dead SD cards, thermonuclear war, or you getting fired because the alarm app failed. Please do some research if you have any concerns about features included in this ROM before flashing it! YOU are choosing to make these modifications, and if you point the finger at me for messing up your device, I will laugh at you. A lot. Prerequisites 1.) Download LG Root 2.) Download LG Drivers 3.) A micro USB cable connected to your PC 4.) Your device must be unencrypted 5.) Before you ask a question, make sure you looked at the pictures in the guide. 1.) Download and unzip the LG_Root.zip in your preferred location I chose the Desktop for my location 2.) Enable ADB debugging on your device Go to Settings > About Phone > Software Information and tap build number until you are presented with "You are now a developer" Exit back to Settings main screen In Developer Options enable USB Debugging (Some devices require enabling PTP for debugging to work) 3.) In the root of LG_Root folder start a command prompt Instructions may vary based on Window's version Inside of LG_Root folder hold shift and right click a blank space you should see "Open command window here" 4.) Now that we have a command prompt running in the root of the folder let's get started. (Commands are copy+paste unless specified) Let's make sure our device is connected Code: adb.exe devices 5.) Great! My device is connected let's continue, we need to get the files onto the device used for this root method. In the same command prompt let's execute another command Code: adb.exe push busybox /data/local/tmp/ && adb.exe push lg_root.sh /data/local/tmp && adb.exe push UPDATE-SuperSU-v2.46.zip /data/local/tmp 6.) Well that was easy , let's continue (Now that we have the files on our device we want to put our device is download mode) (Note this method may vary from device to device) Power off your device When the device is powered off, hold volume up and insert a USB cable connected to the PC Wait for the drivers to install 7.) We're almost done (you've managed to get in download mode) 8.) Let's find which COM port our device is connected to Double click ports.bat (This will give us the COM port in which our device is connected we are looking for the Diag port) You may exit this command prompt when you have your COM port number, keep the other command prompt open 9.) Let's Begin! (Keep the device in Download mode) Let's run Send_Command.exe (It couldn't connect? Make sure you COM port number is correct it varies) Code: Send_Command.exe \\.\COM4 10.) Final Step!!!!!! (We must run the root script) Code: sh /data/local/tmp/lg_root.sh dummy 1 /data/local/tmp/UPDATE-SuperSU-v2.46.zip /data/local/tmp/busybox 11.) We're done You may pull the battery to get the device out of Download mode credit for this guide xda fourm if you like my post just press onlybutton _________________ B.R Abhay_Rana_Singh!!!! Last edited by abhayranasingh; 09-15-2015 at 11:09. Reason: add credit for this post |
The Following 10 Users Say Thank You to abhayranasingh For This Useful Post: |
09-27-2015, 21:36 | #5 (permalink) |
Major Poster Join Date: Mar 2005 Age: 48
Member: 128168 Status: Offline Thanks Meter: 8 | LG Gpad F 7.0 LK430 on ZV3 5.0.1 script done but when i open supersu it says SU binary needs to be updated and it fails every time. tried hard reset but no help. thanks for the share. |
09-28-2015, 00:13 | #6 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1902771 Status: Offline Sonork: [email protected] Thanks Meter: 2 | Is this work fr lg e988 |
