Hard Reset LG P705 how to a hard reset of LG p705 i can't find my solution that's y i post here |
1. When the phone is switched off, press and hold the Volume down key + Power key with your left hand. 2. When the LED on the bottom of the phone lights up, touch and hold the Menu key with your right hand. You need to do this immediately, before the screen displays the LG logo. Make sure your left hand is still holding the Volume down and Power keys. Then release the power key at vibration time. 3. When the LG logo is displayed on the screen, continue to hold the keys for around 2 seconds, and then release all them at the same time, before the LG logo disappears. Leave your phone for at least a minute while the hard reset is carried out. You will then be able to switch your phone back on. |
Thank you nang |
I used this method and it worked for me 1 - Open the version of Vygis LGI_1_95SD 2 - Mark model KP100 3 - Connects only in ports & settings 4 - Click on reset phone with him and connected with the cable GS102 |
100 % work Hard Reset LG P705 - YouTube |
thanx Quote:
thanx |
im_tested..............................good_workin g............. |
first remove battery then hold vol up+down and insert cable wait a few minute... then show android engine.. after 2min press power button.... select wipe data reset.... when complette then select reboot system now... 100% tested |
Made by hand! It's important to know, "menu key" is not the center key, is the lighted sensor on the right. Instructions are correct, just confused the key to press. |
COMFIRM WORK Thanks. |
