LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
07-31-2016, 20:04 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
1. Insert not allowed SIM card 2. Turn the phone handset display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM unlock code 5. Select "OK" - the phone is unlocked successfully The solution for unlocking - Root: KingRoot PC - Unlock: Install RootExplorer, then compiar the "node.db" "node.db-journal" in the / carriers / apps replace existing files and restart the computer files. - Enable GSM network: Install Shortcut Master (Lite), search com.lge.hiddenmenu.jcm_only.networkmode .. Choose LTE / GSM / WCDMA TO SET APN: - Root explorer APNs-conf.xml we replace the file system / etc folder change permission to rw-r - r-- (0644) reboot We mark 3282 # ## "apn setting" menu "reset to default" and ready. | |
07-31-2016, 20:06 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Other way: 1. Turn on the terminal with or without a SIM card 2. Dial the code 2945 # * (your model number) # For example: If your model is the E400, dial 2945 # * 400 # For example: If your model is P700, dial 2945 # * 700 # 3. By checking this sequence a hidden menu will appear 4. Access Network Lock category, enter the code and press OK 4b.- If the category Barring the terminal indicates "The phone is not personalized" check this other code in the Service Provider category and press OK Phone Freeze 4c.- If the Service Provider category also indicate "The phone is not personalized" means that your mobile is already free, check with SIM cards from other operators. |
08-01-2016, 12:15 | #4 (permalink) | ||
Junior Member Join Date: Apr 2011 Location: alex egypt
Member: 1555499 Status: Offline Thanks Meter: 10 | Quote:
not working any idea to insert code | ||
08-01-2016, 14:24 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | 1. - Turn the terminal on with or without a SIM Card 2. - Dial the code 2945#*(model number)# For example: If your model is D802, dial 2945#*802# For example: If your model is E610, dial 2945#*610# 3. - A hidden menu will appear. Select Network lock 4. - Enter the code and press OK 4b. - If your phone indicates "not personalised", enter this other code the code in the Service Provider category and press Unlock. |
08-01-2016, 14:25 | #6 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Or use this: unlock ls675 - Download - 4shared - Marcelo Olivares |
07-03-2017, 08:38 | #9 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Quote:
Has another methods? | |
