Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 06-15-2014, 21:21   #16 (permalink)
Member: 1567812
can u jst share the link again?
Old 06-15-2014, 21:58   #17 (permalink)
Member: 1567812
f100 stuck on boot and reboots any solution
Old 07-11-2014, 12:04   #18 (permalink)
nyakam's Avatar
Member: 260658
Thanks Meter: 184
i have same f100l stuck on boot and reboot here
Old 08-21-2014, 16:50   #19 (permalink)
Member: 2244211
hmmmmmmm
hi anyone from philippines?
my lg vu f100l keeps on rebooting,
it first shows LG then the LTE-ish
then it goes back to LG then the LTE-ish
so whats my problem?
is it the software? hardware? or battery?
Old 08-22-2014, 14:29   #20 (permalink)
androidlabs's Avatar
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
its 100% hardware issue i have fixed many phones myself you just need to change the battery. and if you put charging cable into phone it will fully power on into the menu with even faulty battery. try it yourself. All you need is to change the battery and your phone will be ok. Good Luck
Br,
Babar Abbasi
Old 09-15-2014, 14:55   #21 (permalink)
Member: 703283
i need flash file with german language where i can find it
Old 09-21-2014, 17:32   #22 (permalink)
Member: 2261588
Help!
Hello sir,
When I try to use the KDZ Update tool, beore the flashing process starts, windows is giving error that "the program has stopped working".
I cannot flash the firmware and my phone is stuck on bootloop at LG logo. Also I cannot access Hard Reset menu.
What should I do? Please help me, sir.
Old 09-21-2014, 17:59   #23 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 677
Originally Posted by petralex View Post
Hello sir,
Update windows framework. Try framework 4.0 or heigher. Good Luck
Br,
Babar Abbasi
Old 10-09-2014, 00:07   #24 (permalink)
Member: 1628342
Sonork: 1592100
Thanks Meter: 38
anyone still have a valid link for lg f100l pls share
Old 10-09-2014, 07:56   #25 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
f100l40b_00 - Download - 4shared - Vann Vathana
The Following User Says Thank You to tolski For This Useful Post:
Old 10-17-2014, 04:47   #26 (permalink)
unlockfahim's Avatar
Member: 967784
Thanks Meter: 77
Need LG F100L usb driver Please Help me anybody
Old 11-07-2014, 08:25   #27 (permalink)
Member: 1541217
Thanks Meter: 32
http://*******/Ws2T7
downloadable.....
thanks more power............
Old 11-11-2014, 07:50   #28 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
software not responding on unpacking...............
Old 11-11-2014, 08:07   #29 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
just wait , Dont close software Or don't do anything , Its auto will be normal
AzimBahar/ParvezAhmed.NET
Old 11-25-2014, 11:30   #30 (permalink)
sm-shahzada's Avatar
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
Originally Posted by ..::One-Man::.. View Post
LG Optimus Vu F100L V29I Firmware Update Done
GIDE - How To Flash
F100L KDz ROM BY AzimBahar
Flashing Started
Its Not Error Wait Until Phone Restarted
How to Flash the LG Optimus Vu:
  1. Then download the firmware updating software KDZ_firmware_updater and extract it to a folder. Install msxml on your windows pc by double clicking it.
  2. Charge the phone to the maximum.
  3. Entry Download mode (Vol- & Power Until come on display Download) & Connect Phone To PC
  4. Disable Usb Modem Driver From Modem Tab (On Device manager )
  5. Open KDZ_FW_UPD.exe
  6. In the software window, select Type as 3GQCT
  7. Select PhoneMode as DIAG
  8. In the ‘KDZ file’ space, browse for the firmware you want to install. (In this case F100L40b_00.kdz)
  9. Click “Launch software update”
  10. The firmware flashing process is now underway. If all goes well, in 5-10 minutes the phone will be flashed with the new firmware.
  11. After booting up fully, detach the phone from the pC.
AzimBahar
bro how much take time this process
Page generated in 0.22198 seconds with 8 queries
