LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
02-06-2017, 13:19 | #1 (permalink) |
Insane Poster Join Date: Oct 2013 Location: Bangladesh
Member: 2038498 Status: Offline Sonork: 100.1668482 Thanks Meter: 24 | How to unlock lg-h345 Selected port: COM108 Selected model: H345 Reading info... Model ID: LG-H345 IMEI: 359562-06-627614-4 Android version: 5.1.1 Battery level: 21% SW Version: H34510f Mode: Normal Performed by 2.5.7 Software version. |
The Following User Says Thank You to ihkomol For This Useful Post: |
02-06-2017, 13:21 | #2 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2681545 Status: Offline Thanks Meter: 2 | . - Make sure you have an active data connection via 3G/4G/LTE or Wi-Fi. 2.- From the Application list, tap Device Unlock, the application is located in the MetroPCS folder. 3.- Choose the Permanent Unlock. 4.- Restart the device. Alternative instructions: 1. - Turn the terminal on with or without a SIM Card 2. - Dial the code 2945#*(model number)# For example: If your model is D802, dial 2945#*802# For example: If your model is E610, dial 2945#*610# 3. - A hidden menu will appear. Select Network lock 4. - Enter the code and press OK 4b. - If your phone indicates "not personalised", enter this other code the code in the Service Provider category and press Unlock. |
09-16-2019, 16:25 | #6 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | Welcome to Octoplus/Octopus Box LG Software version 2.9.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: H345 Reading info... Model ID: LG-H345 IMEI: 359562-06-242477-1 Android version: 5.1.1 Battery level: 39% Trying to enable Diagnostics ports... Found model EAAAANVZ: ÿd at port COM48 Checking root access... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please, reboot the phone and try again. Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: H345 Reading info... Model ID: LG-H345 IMEI: 359562-06-242477-1 Android version: 5.1.1 Battery level: 39% Mode: Normal Firmware compiled date: Apr 22 2015 Firmware compiled time: 05:00:00 Firmware released date: May 21 2015 Firmware released time: 17:05:03 SW Version: MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1 IMEI: 359562-06-242477-1 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Trying second method... -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: H345 Reading info... Model ID: LG-H345 IMEI: 359562-06-242477-1 Android version: 5.1.1 Battery level: 39% Mode: Normal Firmware compiled date: Apr 22 2015 Firmware compiled time: 05:00:00 Firmware released date: May 21 2015 Firmware released time: 17:05:03 SW Version: MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1 IMEI: 359562-06-242477-1 SPC: 000000 Checking root access... Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: freeboy08 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: H345 Reading info... Model ID: LG-H345 IMEI: 359562-06-242477-1 Android version: 5.1.1 Battery level: 39% Mode: Normal Firmware compiled date: Apr 22 2015 Firmware compiled time: 05:00:00 Firmware released date: May 21 2015 Firmware released time: 17:05:03 SW Version: MPSS.DPM.2.0.c11-00021-M8936FAAAANUZM-1 IMEI: 359562-06-242477-1 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: freeboy08 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Sending data to server... Sending exploit...OK Executing exploit...OK Calculating. Please Wait...OK Calculating. Please Wait...OK Executing exploit...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.9.5 Software version. |
The Following 3 Users Say Thank You to Freeboy08 For This Useful Post: |
