LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
05-10-2016, 18:19 | #1 (permalink) |
Junior Member Join Date: May 2016
Member: 2569947 Status: Offline Thanks Meter: 0 | I beg for help, LG L70 Dual D325 bricked, secure booting error. I simply did a reset on my LG L70 Dual D325 using the settings menu. Now it is showing secure booting error and then Demigod Crash Handler: DBI Err Fatal ! Code: 1st screen: ERROR: boot certification verify Secure booting error! Cause: boot certification verify Code: 2nd screen(purple background): DemiGod Crash Handler : DBI Err Fatal! Board Rev.: 1.0 Ram dump mode. Option : SD card ram dump mode. Push below files to sd card before test. rdcookie txt, rtcookie txt Please do following action. 1) Ram dump Mode. Please connect USB. 2) Get the ram dump image using QPST Configuration. 3) If sdcard ram dump enabled just wait for reboot. 4) Collect ramdump files from your pc or sdcard. 5) Send e-mail to W5 BSP Global at lge com I tried hard reset, no luck. I tried searching forums but couldn't find solution to my problem. Please guide me Thanks |
05-12-2016, 11:22 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: InTheSky
Member: 355613 Status: Offline Sonork: 100.1674359 Thanks Meter: 170 | TRY 1.Install the USB DRIVER 2.Install and Execute the LG MOBILE SUPPORT TOOL 3.Connect your phone to PC by using the USB Cable 4.Click “Start Updating” n the LG Mobile Support Tool to begin. If your phone needs to upgrade, the “Start Updating “ button will be enable. if your phone is not detect. switch off device,then wait for 10 sec. then press vol + button while plug in usb to phone. it will show a firmware update window. u needed to wait for finish download a file about 930 mb from LG. If Not Done try Repair By eMMC Pinout And Dump. Last edited by staraswan; 05-12-2016 at 11:29. |
08-27-2016, 19:13 | #3 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 243182 Status: Offline Thanks Meter: 31 | lg l70 d320tr full dump send me Screenshot by Lightshot lg l70 d320tr full dump send me EasyJtag Suite ver.: 2.2.0.2 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows NT 4.0 (build 1381, Service Pack 5), 64-bit edition. undefined Android Explorer ver.: 1.0.0.6 eMMC ODIN ver.: 1.0.0.8 Successefuly connected to box on COM5 Box S/N: 05005015F97230BF, ,FW Ver.: 01.55 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA56-D1B2 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55CMD Pullup Level:2485 mV CMD Active Level:2567 mVBox IO Level:2800 mV CLK Rate:7000 khzHiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55CMD Pullup Level:2691 mV CMD Active Level:2763 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (51 mV) too low , check cables etc.! CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (61 mV) too low , check cables etc.! CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (72 mV) too low , check cables etc.! CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55 Warning: CMD Pullup Level (72 mV) too low , check cables etc.! CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (61 mV) too low , check cables etc.! CMD Active Level:2206 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (61 mV) too low , check cables etc.! CMD Active Level:2196 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (61 mV) too low , check cables etc.! CMD Active Level:2196 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Готово. Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05005015F97230BF, ,FW Ver.: 01.55CMD Pullup Level:2041 mV CMD Active Level:2371 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 65646F4D204D4F52128100000615444C EMMC CSD : D07FFF320F59007FF6DB80001E40001C EMMC Manufacturer ID: 0065 , OEM ID: 646F EMMC Date: 04/2017 Rev.0x81 EMMC NAME: M MOR , S/N: 1557 EMMC NAME (HEX): 4D204D4F522000 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: M MOR _ 1557_20160827_2107.extcsd Готово. |
08-31-2016, 19:34 | #4 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1980565 Status: Offline Thanks Meter: 0 | Hello I had this problem I used the LG tool to download a file around 3 hours and then it came back to normal. Maybe you should also try this. I had to clear cache once more and then do this recovery else it would fail. |
