Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 05-10-2016, 18:19   #1 (permalink)
Member: 2569947
I beg for help, LG L70 Dual D325 bricked, secure booting error.
Hello,
I simply did a reset on my LG L70 Dual D325 using the settings menu. Now it is showing secure booting error and then Demigod Crash Handler: DBI Err Fatal !
1st screen:
ERROR: boot certification verify
Secure booting error!
Cause: boot certification verify
2nd screen(purple background):
DemiGod Crash Handler : DBI Err Fatal!
Board Rev.: 1.0
Ram dump mode.
Option : SD card ram dump mode.
Push below files to sd card before test.
rdcookie txt, rtcookie txt
Please do following action.
1) Ram dump Mode. Please connect USB.
2) Get the ram dump image using QPST Configuration.
3) If sdcard ram dump enabled just wait for reboot.
4) Collect ramdump files from your pc or sdcard.
5) Send e-mail to W5 BSP Global at lge com
I have not done any modification to my phone at all. No rooting, no flashing, no OS upgrade, nothing.
I tried hard reset, no luck.
I tried searching forums but couldn't find solution to my problem.
Please guide me
Thanks
Old 05-12-2016, 11:22   #2 (permalink)
Member: 355613
Sonork: 100.1674359
Thanks Meter: 170
TRY
1.Install the USB DRIVER
2.Install and Execute the LG MOBILE SUPPORT TOOL
3.Connect your phone to PC by using the USB Cable
4.Click “Start Updating” n the LG Mobile Support Tool to begin.
If your phone needs to upgrade, the “Start Updating “ button will be enable.
if your phone is not detect. switch off device,then wait for 10 sec. then press vol + button while plug in usb to phone. it will show a firmware update window. u needed to wait for finish download a file about 930 mb from LG.
If Not Done try Repair By eMMC Pinout And Dump.
Old 08-27-2016, 19:13   #3 (permalink)
Member: 243182
Thanks Meter: 31
lg l70 d320tr full dump send me
Screenshot by Lightshot
EasyJtag Suite ver.: 2.2.0.2 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows NT 4.0 (build 1381, Service Pack 5), 64-bit edition.
undefined
Android Explorer ver.: 1.0.0.6
eMMC ODIN ver.: 1.0.0.8
Successefuly connected to box on COM5
Box S/N: 05005015F97230BF, ,FW Ver.: 01.55
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AA56-D1B2 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [JTAG] : ACTIVATED
Z3X EasyJtag Software ver. 2.2.0.2
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 05005015F97230BF, ,FW Ver.: 01.55CMD Pullup Level:2485 mV
CMD Active Level:2567 mVBox IO Level:2800 mV
CLK Rate:7000 khzHiPower mode is off!
Can't init device, Reason: CMD Timeout Error Готово.
Box S/N: 05005015F97230BF, ,FW Ver.: 01.55CMD Pullup Level:2691 mV
CMD Active Level:2763 mV
CLK Rate:7000 khz
Готово.
Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (51 mV) too low , check cables etc.!
CMD Active Level:2206 mV
CLK Rate:7000 khz
Готово.
Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (61 mV) too low , check cables etc.!
CLK Rate:7000 khz
Готово.
Box S/N: 05005015F97230BF, ,FW Ver.: 01.55Warning: CMD Pullup Level (72 mV) too low , check cables etc.!
CLK Rate:7000 khz
Готово.
CLK Rate:7000 khz
Готово.
CLK Rate:7000 khz
Готово.
CMD Active Level:2196 mV
CLK Rate:7000 khz
Готово.
CLK Rate:7000 khz
Готово.
Box S/N: 05005015F97230BF, ,FW Ver.: 01.55CMD Pullup Level:2041 mV
CMD Active Level:2371 mV
CLK Rate:7000 khz
---------- eMMC Device Information ----------
EMMC CID : 65646F4D204D4F52128100000615444C
EMMC CSD : D07FFF320F59007FF6DB80001E40001C
EMMC Manufacturer ID: 0065 , OEM ID: 646F
EMMC Date: 04/2017 Rev.0x81
EMMC NAME: M MOR , S/N: 1557
EMMC NAME (HEX): 4D204D4F522000
EMMC ROM1 (Main User Data) Capacity: 2095982 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: M MOR _ 1557_20160827_2107.extcsd
Готово.
Old 08-31-2016, 19:34   #4 (permalink)
Member: 1980565
Hello I had this problem I used the LG tool to download a file around 3 hours and then it came back to normal. Maybe you should also try this.
I had to clear cache once more and then do this recovery else it would fail.
Page generated in 0.17581 seconds with 8 queries
