Lg 3d p920 hard reset HI I WAS TRY THIS Caution if you perform a full reset, your LG Optimus 3D P920 returns to its default settings and looses all information that is not recorded in ROM. To perform a factory (hard) reset:
just need to press 3d button it will wipe data |
so simple i used z3x select ks360 connect phone to port of z3x with cable gs do factory setting and ur done ! wbr |
it not ks360 did u even see tht 3d model i dnt think it work with tht selecting ks360 |
i know that man i told just select ks360 or also kp500 if u want , turn on phone connect it to cable rj45 gs108 and click factory reset i was in same probleme like you cause no hard reset with keys of phone (p920). i made what i said and all is done very good . inshaa ellah you dont loose any thing for test . 100% working . wbr |
dear bro i have lg p920 want to flash in z3x is it possible plz help |
no it not possible now |
Lg 3d p920 hard reset how do I perform a master reset on my LG? Sabareesh |
u must read again To perform a hard reset using the buttons:
thanks for this sir .. i used this method just now ... very useful thread .. thanks a lot |
1. If your LG Optimus 3D P920 is frozen, turn the Power OFF, pull out the battery and reinsert it back again. 2. Hold the Home and Volume Down button 3. Press and hold the Power button until the device turns on, then release buttons when LG logo appears. 4. Follow the on-screen instructions on how to reset your LG Optimus 3D P920 |
1. power off phone and reinsert battery 2. press volume down+3d button+power button together, when phone power on and lg logo comes, leave the bottons together... it is the right and tested trick... |
1. Power Off 2. Press and Hold Volume Down + Power 3. Waiting To Confirm Hard-Reset 4. Press Power 2 Time To Confirm Hard-Reset All Data The Phone Will Be Format! |
Which solution is tested |
