Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 10-15-2014, 01:33   #16 (permalink)
Member: 2274281
I'm either failing to press 2 buttons at the same time .. or this is not working ..
it does nothing for me
Old 10-17-2014, 18:49   #17 (permalink)
Member: 1086857
Sonork: gsmhiprest
Thanks Meter: 2
some lg e400 does not reset by this method. if thats the case, just hold vol+ and home and power buttons. it will enter into flash mode. now connect the phone to your pc. make sure you have adb and drivers installed on the pc. on your pc keyboard press windows and R keys together. a command prompt will appear. just type: adb reboot recovery. then click on OK. your e400 will reboot and reset. press thanks button if this helps you
Old 10-17-2014, 19:53   #18 (permalink)
ppdavisito's Avatar
Member: 1840836
Sonork: 100.1659703
Thanks Meter: 135
Hard Reset
Vol Down more Power,when the phone power on leave the power button and stay press the Home Button and the Vol down.
Old 01-14-2015, 03:04   #19 (permalink)
Member: 2285747
I done but emergency mode appears.....anybody has an experienced on this situation???
Old 01-14-2015, 03:35   #20 (permalink)
Member: 2285747
When I follow the instruction, emergency mode appears!!!. is that what expected to appear?
Old 01-15-2015, 07:37   #21 (permalink)
Member: 2317848
hard reset lg e400 using menu : Go to menu: Setting > Backup and reset > Factory Data Reset > Reset Device Choose Erase Everything
Old 01-25-2015, 16:25   #22 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 415
here is a little extra info for those who failed to do hard reset by following first post.....when you release power button then again press power button for few seconds.and you will got success.and keep holding other two buttons until android cartoon appears and auto format data.
Old 01-25-2015, 17:16   #23 (permalink)
Member: 2277818
Sonork: hello
Thanks Meter: 6
press & hold Volume Down+Home+Power(Release Power Button after 3-4 seconds) it will reset.
Old 02-21-2015, 11:13   #24 (permalink)
Member: 2257138
Thanks Meter: 9
press volume down ,home button and power, release power button when LG logo appears it will automatically hard reset ,
The Following User Says Thank You to master david For This Useful Post:
Old 04-06-2015, 07:16   #25 (permalink)
Member: 1543538
Sonork: 100.12345
Thanks Meter: 2
Originally Posted by okaish View Post
volumdown+home+charger
10000%
yess..this workzzz
Old 04-25-2015, 15:16   #26 (permalink)
kharimobiles's Avatar
Member: 1814389
Sonork: 100.1621147
Thanks Meter: 30
my problm solve press & hold Volume Down+Home+Power(Release Power Button after 3-4 seconds) it will reset
Old 04-25-2015, 15:18   #27 (permalink)
Member: 1814389
Sonork: 100.1621147
Thanks Meter: 30
press volume- menu power button 100% reset
Old 05-04-2015, 15:02   #28 (permalink)
chinnivardan's Avatar
Member: 892484
Sonork: not using
Thanks Meter: 916
Originally Posted by alex muatha View Post
tested bros.. just press volume down+ home key and connect usb charger n press power shortly.its done
yes this method worked for me
Old 05-15-2015, 13:04   #29 (permalink)
Member: 2387437
good one..................just worked for me. much tanks
Old 05-16-2015, 07:12   #30 (permalink)
Registered User
Member: 1840612
solved
Originally Posted by kalpsh1984 View Post
just relese the all keys when phone vibrates
i'm has solved with with this method
Page generated in 1.97963 seconds with 9 queries
