Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 11-30-2013, 16:50   #1 (permalink)
Member: 941075
Thanks Meter: 32
lg f320s pattern lock/hard reset
how to remove pattern lock from lg f320s ? I try vol - and power but nothing. how to hard reset this phone?
Old 06-11-2014, 18:08   #2 (permalink)
Member: 1001721
Sonork: gist68
Old 04-19-2015, 10:53   #3 (permalink)
Member: 1776947
Sonork: 100.1659966:tjjxxs
Thanks Meter: 18
If you are still having issue with the phone try this greenleafmn,
1. First turn off the device.
2. Then you will need to press and hold the Volume Down + Power button.
3. When you see the LG logo appears, while continue to hold the Volume Down key, release the Power button and press the POWER again.
4. When you see the recovery screen let go of all the buttons.
5. Select Yes from the Factory data reset screen. To navigate to the next item option, you can use the Volume Key Up / Down. To make a select press on the Power button.
6. Finally select Yes to start the reset process.
Old 04-30-2015, 14:20   #4 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,492
Exclamation
not work for me... on F320S SK Telecom.
Old 10-21-2016, 14:39   #5 (permalink)
Member: 337100
Sonork: 100.1606722
Thanks Meter: 55
yesss not working on lg f320s sk telecom
pls give another sollution
thanks
Old 01-20-2017, 09:12   #6 (permalink)
Member: 1896725
Sonork: 100.1620487
Thanks Meter: 20
its work i am tested
Old 01-30-2017, 11:32   #7 (permalink)
Member: 1738539
Thanks Meter: 10
https://www.youtube.com/watch?v=7-6x9M_FiWs&t=52s For the Android Pattern unlock--HDBox
Old 06-25-2017, 17:59   #8 (permalink)
Member: 2674250
Thanks Meter: 7
Lg g2 hard reset
Remove battery 10 second
Press Volume down + power relese both when lg log appear.
now press volume up + volume Down thats it.
The Following 7 Users Say Thank You to babar786mobile For This Useful Post:
Old 07-17-2017, 20:43   #9 (permalink)
Member: 2392825
Thanks Meter: 29
how to hard reset all lg mobile
Hard reset All LG mobile 10000% tested
https://www.youtube.com/watch?v=dCobsgiLhm0
Don't forget to Subscribe
Old 08-06-2017, 11:00   #10 (permalink)
Member: 1231601
Thanks Meter: 12
its work f9r f320k wery well thanks alot
Old 08-13-2017, 09:20   #11 (permalink)
Member: 1687169
Sonork: best4best
tour methed not work f320s ..only work from InfinityBox LGS i test f320s
Page generated in 0.32226 seconds with 7 queries
