LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
02-11-2015, 11:18 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 329729 Status: Offline Thanks Meter: 1 | LG G3 D855 Dead No Power No Download Mode i have tow LG D855 No power When i connect to pc i see my phone but i can't flashed with OCTOPUS NO DOWNLOAD MODE - NO RECOVERY MODE 1 - Qualcomm HS-USB QDloader 9008 2 - LGE Androidnet USB Serial Port How i can fix That Last edited by alhabshy; 02-11-2015 at 11:26. |
The Following User Says Thank You to alhabshy For This Useful Post: |
02-26-2015, 18:22 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | LG G3 revive = No success ... I can't achieve reviving of dead LG G3 ( EU variant 16 Gb ) turkcellgsm solution just do not work: Boot repair via SmartBootDiagv1.3.1_Oversea_SVC_20141106 seem to be OK: Code: >> ---------------------------- Start Logging ---------------------------- >> USB Status : Qualcomm HS-USB QDLoader 9008 (COM24) >> Ready to access the target board... >> BootLoader File : All EU Global_XXXX_XXXX.mbn >> 1. Model : All EU Global , 2. Suffix : XXXX , 3. Operator : XXXX >> Bootloader : All EU Global_XXXX_XXXX.mbn >> AP Chip : MSM8974_G3 , BootLoader : All EU Global_XXXX_XXXX.mbn >> Trying Connection To Device with sahara protocol for AP Chip. >> Successfully Connection To Device with sahara protocol for AP Chip. >> connected with Sahara Protocol successfully. >> Loading flash to SYS_IMEM. >> Loading 0 Kbytes to SYS_IMEM. >> Loading 4 Kbytes to SYS_IMEM. >> Loading 8 Kbytes to SYS_IMEM. >> Loading 12 Kbytes to SYS_IMEM. >> Loading 16 Kbytes to SYS_IMEM. >> Loading 20 Kbytes to SYS_IMEM. >> Loading 24 Kbytes to SYS_IMEM. >> Loading 28 Kbytes to SYS_IMEM. >> Loading 32 Kbytes to SYS_IMEM. >> Loading 36 Kbytes to SYS_IMEM. >> Loading 40 Kbytes to SYS_IMEM. >> Loading 44 Kbytes to SYS_IMEM. >> Loading 45 Kbytes to SYS_IMEM. >> Successfully Loaded to SYS_IMEM.(Total 45 Kbytes) >> Flash Image was normally loaded to SYS_IMEM. >> Checking for device status. >> [Verifying Hello Protocol] >> Sending Hello request 0 time(s). >> SendSync EHOST_HELLO_RSP OK. >> Hello Response OK. >> Got Hello response for Hello request. >> [Verifying Security Protocol] >> Security Response OK. >> Connected to flash bootloader. 1> ---------------------------------------------------------------------- >> PBL SOFTWARE HISTORY 1> ---------------------------------------------------------------------- >> 1.Smart Boot Diagnosis Tool v1.3.1 <Analysis Tool for Booting failure> >> 2.PBL_VERSION_NUMBER [fc021834] = 1c6c6162 1> ---------------------------------------------------------------------- 1> ---------------------------------------------------------------------- >> SECURE_BOOT_INFORMATION 1> ---------------------------------------------------------------------- >> [QFPROM - AP Anti-rollback Region of OEM Region ] >> QFPROM_AP_ANTIROLLBACK_1 [0xFC4B80B8] = 0x00000000 >> QFPROM_AP_ANTIROLLBACK_2 [0xFC4B80BC] = 0x00000000 >> QFPROM_AP_ANTIROLLBACK_3 [0xFC4B80C0] = 0x00000000 >> QFPROM_AP_ANTIROLLBACK_4 [0xFC4B80C4] = 0x00000000 1> ---------------------------------------------------------------------- >> QFPROM_DEVICE_SN_1 [0xFC4B81F0] = 0x0D0E9CF2 >> QFPROM_DEVICE_SN_2 [0xFC4B81F4] = 0x8800000B 1> ---------------------------------------------------------------------- >> QFPROM_MSA_ANTIROLLBACK_1 [0xFC4B80C8] = 0x00000000 >> QFPROM_MSA_ANTIROLLBACK_2 [0xFC4B80CC] = 0x00000000 1> ---------------------------------------------------------------------- >> [QFPROM QFuse INFO] >> QFPROM_OEM_ID_LSB [0xFC4B80F0] = 0x00310000 >> QFPROM_OEM_ID_MSB [0xFC4B80F4] = 0x00000000 >> QFPROM_SECURE_BOOT_ENABLE_LSB [0xFC4B83F8] = 0x00202020 >> QFPROM_SECURE_BOOT_ENABLE_MSB [0xFC4B83FC] = 0x00000000 >> QFPROM_JTAG_DISABLE_LSB [0xFC4B80E8] = 0x3FC000C0 >> QFPROM_JTAG_DISABLE_MSB [0xFC4B80EC] = 0x040001FE 1> ---------------------------------------------------------------------- >> JTAG_ID [0xFC4BE0E0] = 0x107B40E1 >> OEM_ID [0xFC4BE0E4] = 0x00310000 >> SERIAL_NUM_MSB [0xFC4B81F4] = 0x8800000B >> SERIAL_NUM_LSB [0xFC4B81F0] = 0x0D0E9CF2 >> [SECURITY INFO] >> OEM_CONFIG_ROW0_LSB_ADDR [0xFC4B80E8] = 0x3FC000C0 >> OEM_CONFIG_ROW0_MSB_ADDR [0xFC4B80EC] = 0x040001FE >> OEM_CONFIG_ROW1_LSB_ADDR [0xFC4B80F0] = 0x00310000 >> OEM_CONFIG_ROW1_MSB_ADDR [0xFC4B80F4] = 0x00000000 >> FEAT_CONFIG_ROW0_LSB_ADDR [0xFC4B80F8] = 0x00B08010 >> FEAT_CONFIG_ROW0_MSB_ADDR [0xFC4B80FC] = 0x00000000 >> FEAT_CONFIG_ROW1_LSB_ADDR [0xFC4B8100] = 0x00000001 >> FEAT_CONFIG_ROW1_MSB_ADDR [0xFC4B8104] = 0x0004785F 1> ---------------------------------------------------------------------- >> Start Address : 0xfc102140 >> End Address : 0xfc102c80 1> ---------------------------------------------------------------------- >> PBL_APPS LOG 1> ---------------------------------------------------------------------- >> PBL_LOG_COUNT=15 >> LOG_CODE :: 0xef010800 [ DECODED : 0x00010800 ] >> TIMESTAMP :: 0x0002ee88 >> LOG_CODE :: 0xef0f0203 [ DECODED : 0x000f0203 ] >> TIMESTAMP :: 0x0002f52d >> LOG_CODE :: 0xef010802 [ DECODED : 0x00010802 ] >> TIMESTAMP :: 0x00032aaf >> LOG_CODE :: 0xef010804 [ DECODED : 0x00010804 ] >> TIMESTAMP :: 0x000340f4 >> LOG_CODE :: 0xef010806 [ DECODED : 0x00010806 ] >> TIMESTAMP :: 0x0003443f >> LOG_CODE :: 0xef010808 [ DECODED : 0x00010808 ] >> TIMESTAMP :: 0x000344eb >> LOG_CODE :: 0xef01080a [ DECODED : 0x0001080a ] >> TIMESTAMP :: 0x00034583 >> LOG_CODE :: 0xef0f0300 [ DECODED : 0x000f0300 ] >> TIMESTAMP :: 0x000345e6 >> LOG_CODE :: 0xef01080c [ DECODED : 0x0001080c ] >> TIMESTAMP :: 0x0003461b >> LOG_CODE :: 0xef5d0200 [ DECODED : 0x005d0200 ] >> TIMESTAMP :: 0x000346ea >> LOG_CODE :: 0xef5d0400 [ DECODED : 0x005d0400 ] >> TIMESTAMP :: 0x00275f9f >> LOG_CODE :: 0xef5d0201 [ DECODED : 0x005d0201 ] >> TIMESTAMP :: 0x00276005 >> LOG_CODE :: 0xef0f0600 [ DECODED : 0x000f0600 ] >> TIMESTAMP :: 0x002a26cd >> LOG_CODE :: 0xef0f0500 [ DECODED : 0x000f0500 ] >> TIMESTAMP :: 0x0f31f1fd >> LOG_CODE :: 0xefa00502 [ DECODED : 0x00a00502 ] >> TIMESTAMP :: 0x0f34ae28 1> ---------------------------------------------------------------------- >> < PBL DUMP LOG > 1> ---------------------------------------------------------------------- >> 1> PBL_GENERAL_LOG_FUNC_EXEC 1> PBL_FUSE_LOG_DEFAULT 1> PBL_GENERAL_LOG_DEFAULT 1> PBL_GENERAL_LOG_DEFAULT 1> PBL_GENERAL_LOG_DEFAULT 1> PBL_GENERAL_LOG_DEFAULT 1> PBL_GENERAL_LOG_DEFAULT 1> PBL_FUSE_FAST_BOOT 1> PBL_GENERAL_LOG_DEFAULT 1> PBL_SDCC_LOG_DETECT_PORT_ACCESS_ERR 1> PBL_SDCC_LOG_CARD_TYPE_ERR 1> PBL_SDC_LOG_DEFAULT 1> PBL_FUSE_USB_ENUM_TIMEOUT 1> PBL_FUSE_AP_SW_REV 1> PBL_AUTHENTICATION_LOG_DEFAULT >> Logged Time : 2015-02-26 19:16:10...successfully Completed. >> Saved Log File(LOG_All EU Global_XXXX_XXXX_20150226_191610.txt) successfully. Any advice is welcome WBR, DebeliaMark, BG |
